Old 03-07-2006, 09:12 AM   #1
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
LC4 Airbox Mods
I have searched the threads and checked the index but still have questions. I have a new airbox that will be going into my 99 640 LC4 e. the current one has the whole top cut off. It sounds like the agreed mod is just to put in the airbox screen with the snorkel left in place. i can't find the screen, i can't even find a picture of one. i have seen ones like this.
but that doesn't look like what would fit mine. sorry to beat a dead horse here but i just couldn't find what i was looking for.
as it is right now it has an idle jet @ 52.5 (i think), main at 150, sxc exhaust, and lives at 7500 ft. rides down to 5000 and up to 12000. what would be the best way to go mostly regarding the air box.
thanks
scott
Officially motor free
9 cycles with pedals
fire_strom is offline   Reply With Quote
Old 03-07-2006, 10:18 AM   #2
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
KTM part number 58406003200 FITMENT: LC4 98-06
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 03-07-2006, 10:20 AM   #3
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Creep is just too quick....
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 03-07-2006, 10:28 AM   #4
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Quick?... the post sat here for an hour before I got to it. My dead Pa' could have got to it before you.
So... how's tricks?
Old 03-07-2006, 10:31 AM   #5
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
thanks creep, and good try chrisC .
does that replace 4, 14 or both? or do you just cut through them?
thanks
scott
Old 03-07-2006, 10:44 AM   #6
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
thanks
scott
It replaces 14 & 4... there is a gap between 14 and 2 for air to flow thru. 4 is just a "peel and stick" gasket for 14.
Some SuperMoto guys don't run 2 (outer cover)... for us off-roady types, it kinda functions as a spash guard, lean back, knee gripper, kinda thingy.
C
So... how's tricks?
Old 03-07-2006, 10:49 AM   #7
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
thanks again,
so thats it right?, race cover w/ snorkel in. are folks drilling holes in 2 or cutting to match the screen? anyone got pictures?
scott
Old 03-07-2006, 11:11 AM   #8
Jeff620RXC
Jeff620RXC's Avatar
Oddometer: 567
That's what SHE said!
Jeff620RXC is offline   Reply With Quote
Old 03-07-2006, 11:15 AM   #9
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
thanks again,
scott
The holes already line up (more or less). Just hang in on and go....
Chris
1943 BSA M20WD
Old 03-07-2006, 11:21 AM   #10
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,236
thanks again,
scott
you want to make your own?
creeper is your man for info on that one; he makes nice side airbox mods.
there are pics burried in the index of his work.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 03-07-2006, 11:35 AM   #11
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
One mill... one billion dollars.
So... how's tricks?
Old 03-07-2006, 11:42 AM   #12
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
purdy creep,
so when you install the screen it seals on the box, and the #2 side cover is spaced off of it and that is where the extra air gets in? the light is beginning to turn on here sorry for the slowness.
scott
Old 03-07-2006, 12:00 PM   #13
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,231
i'm used to the dots like in creeps pic, is there a reason the other style is used by some or most instead of the dots??
2 SPOT is offline   Reply With Quote
Old 03-07-2006, 12:05 PM   #14
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
'Cause it says KTM on the side and it's way bitchener than Creep's Ho-Made unit.
But really, it's just easier than all the hand work if you're lazy (like some of us)
Chris
1943 BSA M20WD
Old 03-07-2006, 12:34 PM   #15
meat popsicle
Ignostic
Oddometer: 14,236
purdy creep,
scott
I can help here; on the stock airbox air enters thru the snorkel only. The 'racing' side airbox cover (KTM part or creepers far superior custom piece ) opens up the side of the airbox to airflow, which on the stock airbox is not open at'all.
The #2 sidecover has the space there to allow airflow to reach your newly opened side of the airbox.
The UNI (mini?) air filters you can buy over the counter. I am not sure if this is why creeper used them but PASSMORE said that they flow well but also can help keep water out a bit longer than the screen used on the KTM part.
EDIT: passy's setup
meat popsicle screwed with this post 03-07-2006 at 12:58 PM
Times are GMT -7.   It's 01:36 AM.
