Old 03-19-2006, 09:43 PM   #1
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,247
Guide to changing your chain and sprockets on the LC4
Note: this guide uses a 2003 KTM 640 Adventure as it's model; some specifications on your model and/or it's year may differ. Check your manual!
What you need to do the job:
New chain that is rated to operate a mid-sized DS bike and has enough links. You will need at least 110 for the stock setup; custom sprocket tooth counts might require a different chain length. Some discussion here. I ended up with a ORN6 520x120 MSR/Regina chain.
New sprockets: the front stocker is a steel 16T; the rear is an aluminum 42T. Sprocket size changes and their requirements are discussed ad nasium elsewhere: here is one link.
I was advised to go with steel OEM sprockets by someone I trust, so I did, and ordered a steel rear KTM 42T (P/N 58210051042 approximately $25), although many purchase aftermarket sprockets and are satisfied with them. It is stamped ESJOT - their website says over 80 years of making these in Europe; they probably know what they are doing by now. I purchased a “Genuine Spare Parts” KTM 16T countershaft sprocket for up front (P/N 58033029016 under $20).
Why not aluminum in the rear? I have been trying to find someone who knows why one was put on in the first place... They are over $60 and the talk about town is they do not last nearly as long as the $25 steel sprocket.
Loctite: KTM recommends Loctite 243. Be sure you have some that at least meets that specification because it would be a mistake to reassemble these components without some. A very reliable source says the replacement bolt will come with am encapsulated locking agent already applied. He also believes its a good idea to replace the CS sprocket bolt and crush washer each time you replace the drivetrain. So here are the part numbers, again for an 03 640 Adventure:
CS sprocket bolt and spring washer P/N 590.33.034.044 $4.25
I now note the parts diagram also shows a second washer between the spring washer and the CS sprocket, P/N 0125 100003, which I don't recall after the fact... Never fear; a lil' birdy tells me that this washer at one time may have served the same purpose as the shoulder that is machined onto the OEM (not all the aftermarket folks get this essential part right...) CS sprocket, which the spring washer conforms to for the proper tension load - and give - on all that hard-to-reach stuff on the other end of the shaft.
Tools: You will need combination wrenches and/or sockets, and allen keys to perform this work. To do it properly you will need torque wrenches; an allen head 'socket' to torque the rear sprocket bolts might help depending on how you perform the rear sprocket change. Note: no torque wrenches is a significant liability when working on your drivetrain. I have heard that folks find many useable parts off of wrecked bikes that threw their chain; the fact that those bikes were salvage should catch your attention...
Step One - Disassembly:
Before you do anything else, recognize that the hardest bit of hardware to remove is the countershaft bolt. And the easiest way to do it is to use the rear brake to hold the rear wheel, which holds the chain, which holds the sprocket, which holds the shaft still while you try to bust a nut... free. So do the CS bolt first. I got all setup to use some elbow grease to break it free and the nut came off like it wasn't torqued down properly! Either my wrench is bigger than I thought or it was good timing for this work.
Start here:
And take off the CS sprocket cover (two bolts):
Use a decent sized wrench to break the CS sprocket bolt free. I did this part solo by stepping on the rear brake myself while turning the wrench. There was enough room for me to work; if you are not comfortable have someone help you hold the bike and/or brake.
Once the CS sprocket bolt is loose, it seemed to me the remaining disassembly could occur in just about any order. I removed the rear wheel, then broke the master link and removed the chain and then the CS sprocket, which ironically was freed up first.
Step Two - Additional Checks and Balances:
So here is my CS cleaned up and ready for the new sprocket. Note no dripping! No leaking seal! If yours shows signs of leaking click here.
Cush Drive Rubbers Check. If you haven't already, remove your rear sprocket assembly by simply pulling up on the sprocket with the wheel laying flat and then follow the specifications in the owner's manual:
Originally Posted by KTM Owner’s Manual
Checking the shock absorption rubbers in the rear hub
LC4 models have a damped rear wheel hub. For this purpose, the engine power is conveyed from the rear sprocket via 6 shock absorption rubbers to the rear wheel. These 6 absorption rubbers wear with increasing operation time, and should be checked for wear whenever the rear wheel is dismounted.
For this purpose, lie the rear wheel on a work bench with the rear sprocket upwards, and put the wheel spindle in the hub. Now hold the rear wheel firmly and try to turn the rear sprocket. The rear sprocket may not turn more than maximum 5 mm (0,2 in) measured on the outside. If the play in the chain wheel is larger, all 6 shock absorption rubbers are to be replaced.
Check the shock absorption rubbers for signs of damage and dirt.
! CAUTION !
IF THE SHOCK ABSORPTION RUBBERS ARE NOT REPLACED IN GOOD TIME, THE REAR
SPROCKET CARRIER AND THE REAR HUB WILL BE DAMAGED. ALLWAYS REPLACE ALL
6 ABSORPTION RUBBERS, NEVER SINGLE RUBBERS.
Step Three - Assembly:
Of course what goes up, must come down; and likewise - how the CS sprocket bolt loosens easiest, it also tightens easiest. So hold off trying to tighten down the CS sprocket bolt until you have the rest completed. I did the rear sprocket mounting first.
If you do not have a vise to hold the rear sprocket assembly for the sprocket change, you can use the wheel to hold it for you. But you will need a good surface to setup your rear wheel to remove the sprocket, one that holds the wheel and also protects the rear brake disc on the other side. I used an old Goodyear Eagle "Sports Car Special" slick as my wheel bench; it's perfect for the 18" rear wheel:
There are 6 8mm allen bolts with 13mm nuts (with Loctite) holding it on. It wasn't easy to get them loose, but EDIT: if I was a smart as Rad I woulda remembered to use a bit of heat to make the Loctite release. Luckily for me it released easily enough that I only used an allen key and a small combination wrench. Remember to take your time with the work, particularly when you are doing a job for the first time. When installing the new rear sprocket, I followed a professional wrench's advice on how to properly torque assemblies with multiple fasteners (miss ya Mack ). Click here and then go to Post #85 for the low down.
Torque the M8 fasteners down to 22 ft.lbs. Repeat installing the sprocket when you realize you forgot the Loctite... If you are on your game try combining these steps; I imagine that would be nice. One last FYI on the rear wheel: if you forgot to check your cush drive rubbers, do it now.
I put the CS sprocket on (without trying to torque it's fastener yet) so I could feed the chain through; not sure if it was a necessary step but it does hold the chain loosely and I thought it would be more difficult to put the CS sprocket on with the chain installed, given the tight clearances.
Then install your chain. This is the tedious part for me: measuring out the new chain (use the old one!) and breaking it to the right length, then installing the master link, which used to be easy until they went with these new-fangled 'press-fit' sides.
I bought a Motion Pro Chain Breaker for under $30. I could use it to both break the chain to the correct length and also 'press-fit' the master link so I could install the spring clip. They also make special tools for the pressing, but I hate having too many gadgets and did without. You decide what is best for you; they are not expensive.
You really need some force to press-fit these sides; without some type of tool you will end up breaking the spring clip trying to get it into the NOT uncovered groves. Don't ask me how I know; I don't wanna talk about it.
Chain installed? Finally! Good; now mount the rear wheel so you can tighten the CS sprocket bolt (remember?). Torque down that CS sprocket bolt to 44 ft.lbs of torque, and don't forget to add Loctite first.
EDIT: I had a chain tension adjuster bolt freeze in the swingarm at the end of my second drivetrain's life (~17,000 miles w/ 50/50 road/dirt duty, mostly dusty Mediterranean climate, and only occasional river crossings), so I am adding a recommendation to complete remove your chain tension adjuster bolts each time you change your chain/sprockets, and chase the threads (i.e. clean them) to remove any accumulated crap. This might be enough to save you from $1-200 to the wire-EDM shop to disintegrate the bolt, since it wouldn't budge (it was bending and it's a thick stud!), but my other thought is to protect the threads with an anti-seize. I do not have that all thought through yet - I am working on a thread for anti-seize compounds - but I may be putting something in there to make sure they do not seize again.
I should also mention a tip from a friend on aligning the rear axle; just measure from the swingarm pivot bolt to the rear axle bolt on both sides, both while aligning the axle and once more once you have it tightened down. I find it necessary to do this several times to get the rear axle aligned and the chain tension correct. Don't hurry this part, or you will be back doing this sooner than necessary! Are we there yet? Assembled!
You might have noticed in that last picture I already installed my new rallye CS sprocket cover. I wanted to be able to keep an eye on my CS sprocket bolt (particularly since I tightened it) and a smart fella said to open up the CS sprocket cover so I could. I didn't have a hole saw like him to make a fancy 'port' to view my CS bolt and noticed in a picture how the Rallye version of this part is setup. Here is the KTM 660 Rallye CS sprocket cover:
It looks like they really did just cut the part like I did, although not quite as much... it's a cheap part anyways (~$10) so don't sweat it.
EDIT: When marking your CS sprocket bolt to check for movement, do not waste your time marking the CS sprocket spring washer as a reference point. Why not? Well, I have just learned that under normal circumstances the CS sprocket spring washer can rotate, and this does not indicate the CS sprocket bolt is loose. I did this several times, yes, SEVERAL times... Instead, mark the CS sprocket as a reference point to the CS sprocket bolt mark.
Step Four - QA/QC:
So there she is all ready for more riding! This last section is devoted to due diligence, checking and rechecking your installation for your own sake. Plus I reckon the chain might like an adjustment once it settles in a bit. Primarily this means during the period immediately following the work, until you are satisfied you have performed the work correctly; remember it is impossible to 'assUme" you did the work correctly!
So take the bike on some short rides and then check the fasteners; did they shift? And how is the chain tension? Once you are satisfied with the installation you can pat yourself on the back for a job well done. Then read on for some thoughts of long-term maintenance and the rationale for my choices above; it might help some of you.
One additional note on chain adjustment. I follow the owners manual's method for adjusting the chain; you should too - it works. I do not have a problem with the method, but I do have difficulties adjusting my chain properly. Perhaps it is the 3-D effect of adjusting the chain, getting the axle and swingarm pivot parallel, and tightening everything down that gets me...
And I have found that the adjustment between too loose vs. correctly adjusted is slight. If you chain is too loose you will likely hear it lightly catching on something; that something is the most forward bolt that fastens the upper chain guard onto the swingarm, as the upper run of the chain sags and comes into contact with the bolt head. I found with my setup, the adjustment between this state and (what I believe is) proper adjustment was only 12 hours on the adjuster bolts (one rotation).
Too tight is easy: you won't be able to make the lower chain contact the swingarm 30mm behind the lower rear chain slider. Loosen it or be prepared to pay dearly.
Why did I write this?
I had to change my chain and sprockets recently. And surprisingly enough, this was the first time I did it all myself. I received some good tips from various sources that I thought could be of assistance to folks out there who have not had the opportunity yet. So I wrote up this how-to with you folks in mind.
It has benefited drastically from some very necessary critical reviews; a big thanks for reviewing the drafts and giving me feedback. Things that seem obvious in retrospect were anything but at the time…
Some thoughts that were going through my head during this maintenance:
I had the impression that it is generally well accepted when changing one component of your drivetrain you should change them all. The reasoning I heard was that if one part of a worn drivetrain is left on it will make the new parts wear faster, and therefore it is good practice to change them all at once.
Some do not subscribe to this conclusion. But in order to save needless debate about the utility of changing out the entire drivetrain at once, let me just note that my reviewer’s comment brings up an important point. Namely that many change their gearing repeatedly during the lifespan of the components, going up or down on the front (and back) depending upon the needs of a particular ride. If this is the case for you, you will need to become adept at identifying or measuring the wear tolerances of individual components and changing them as needed, since you will likely never run through one drivetrain (i.e. a set of sprockets and chain).
There are visual cues that I have heard show excessive sprocket wear (tooth cupping is one off the top of my head), and there is a chain stretch maximum specification in the manual. Perhaps others will share their visual cues or tests for excessive sprocket and/or chain wear.
Anyways, on the stock setup that came with my 2003 KTM 640 Adventure, my rear sprocket appeared to be worn out by 7500 miles; the front stock steel CS sprocket looked fine. Here are what my rear and front sprockets looked like:
So I ordered up a new set of sprockets and chain, even though only my rear sprocket appeared to be shot; the front sprocket looked good and I thought the chain should be fine after 7500 miles with decent care (I did not measure chain stretch so I cannot qualify my comment). Waste of money? Perhaps...
By the way, if I was on my game during this maintenance I would have held out for one of these:
(click the pic) It looks like a very nice portable tool for dealing with chains.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle screwed with this post 06-06-2010 at 07:46 AM Reason: fix ESJOT link
meat popsicle is offline   Reply With Quote
Old 03-20-2006, 06:48 AM   #2
Beez
Given to fly
Beez's Avatar
Oddometer: 5,830
Talking Did mine this weekend too.
Timely post, I just did it this weekend too. Mine is a '97 RXC, stock gearing was 16/40 but I mostly used 15/40, it's much better in the dirt. So I figured if 15/40 was good 15/42 would be even better! I can switch back to 16/42 easily enough if there is more street on the ride.
I take the CS sproket off the same way, but one thing I do is write "OFF" and an arrow in the direction to take the bolt off. Some people might not need that but this knucklehead does.
Couple a questions, do you put anti-sieze on the chain adjuster bolts (the ones that go in the swingarm?
My new chain is covered in sticky white grease, what's the best way to clean that off? Kereosene??
Beez is offline   Reply With Quote
Old 03-20-2006, 07:36 AM   #3
meat popsicle OP
Ignostic
Oddometer: 14,247
I don't use anti-sieze on the chain adjuster bolts, although after many years of off-road use (such as on a 97 RXC) I can imagine the hardware gets pretty messed up and some type of lubrication/protection could help. One of these these perhaps?
Regina specifies kerosene for cleaning their chains here. Remember, cleaning your chain is a no smoking task!
Old 03-20-2006, 08:42 AM   #4
rjf
SBS's #1 fan in January
rjf's Avatar
Location: Gosford, NSW, Aust. Scrambler, 640Adv, 300EXC
Oddometer: 4,376
You suck Meat.
Now I have another " that looks Uber cool" (and useful) mod I need to make to my bike. Creep has good idea's like the dab of paint, eh. Just wish I could find '03 KTM silver at the local hardward shop
Central Coast ADVenture bike training courses and 1 on 1 lessons - For details Click HERE
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadslide, thoroughly used up, totally worn out and loudly proclaiming- WOW-WHAT A RIDE!
rjf is offline   Reply With Quote
Old 03-20-2006, 12:43 PM   #5
meat popsicle OP
Ignostic
Oddometer: 14,247
Originally Posted by rjf
You suck Meat.
...pic...
Hack saw and a bit of sandpaper worked for me; took all of a minute. In retrospect I would have started by cutting less off and trying it out first.
I hadn't looked carefully at the Rallye bike pic and cut inside of the 'bubble-like' marks on the cover; if you look carefully KTM did not (cut right thru the marks) and left more material on the cover. I would probably try cutting less than the Rallye first off, then more if necessary; it's not time consuming anyways.
It's a $10 part; I might give her another go.
I have never see anyone post the paint info on the 03...
Old 03-20-2006, 01:24 PM   #6
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Looks good brudder ... easy as fallin' off a log huh.
Might want to track down the guy with the LC4 Index and see of he'll include it.
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 03-20-2006, 01:38 PM   #7
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,632
Thumb Excellent!
Another great guide to DIY Adventuring! Thanks.
I'm guessing, but here are two thoughts:
1. Reduce weight of bike for specifications.
2. At roughly 3:1 final drive ratio, the front sprocket works three times harder than the rear. Steel front, Ally rear would help the final drive to wear out as a set.
Something to add to make it easier for a n00b: when joining the chain, have the join sitting on top of the rear sprocket. The sprocket teeth will hold the two ends of the chain together for you, leaving two hands to fiddle with the link parts.
Actually, it looks rooted. It was worn out long ago! The chain would have to be similarly far gone to match. There is noticable wear on your front sprocket, too.
7,500miles is pretty good from what I've read here. The first set on my bike lasted over 6,000km but were well shagged then. I've replaced them with Chain Gang sprockets and an RK520 GXW chain. So far they've done 4,000km with few signs of wear.
New sprocket teeth are sinusoidal in shape with a chamfered top. The first sign of wear is the chamfer disappearing; it gets progressively worse from there, the gap between the teeth becoming more of a flat-bottomed U-shape.
This occurs in tandem with the chain "stretching". As the teeth wear, the distance between teeth centres increases, stressing the chain links and so they wear, increasing the distance between centres on the chain links (or vice-versa). You can easily test for this by pulling the chain off the rear sprocket, arrowed in the pic below. A new chain on a new sprocket will barely move. A shagged chain could clear the sprocket teeth.
Anyway, hope this helps, thank again for another LC4 guide.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 03-20-2006, 03:04 PM   #8
meat popsicle OP
Ignostic
Oddometer: 14,247
C
Thanks mang,
Easy... yeah it would have been if'n I hadn't worried about quality. I think have a good introductory appreciation to the process, and I am all the more impressed.
You think it's worth induction? Cool - too bad the librarian is tied up with troubleshooting the electrics on his ride. I doubt I will get him on it for a spell.
Old 03-20-2006, 03:17 PM   #9
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Tell me who he is and I'll smack the fuck around for ye'.
So... how's tricks?
Old 03-20-2006, 03:35 PM   #10
meat popsicle OP
Ignostic
Oddometer: 14,247
Some other things I have heard are:
a. Aluminum is more sexy
b. All the kool kids want them
c. Less rotating unsprung mass...
But with the distinct possibility that some will change their drivetrain sprockets up and down more often, due to the needs of the ride, considering the drivetrain as 'a set' is not as useful as learning how to identify wear on the various components. So I am glad you went on below to offer some of your tests for drivetrain wear!
I laid the master on the ground; rear wheel was off. Seem to work ok, but perhaps your way would be easier. Good for folks to have options!
Here is a close up of my CS sprocket:
BTW, my new CS sprocket is directly underneath it I would think that if the teeth were significantly worn I would see the new one. My first guess was it appears to be slightly worn.
...nice pic of the test...
Thank you for the useful tips and comments!
Old 03-20-2006, 03:36 PM   #11
meat popsicle OP
Ignostic
Oddometer: 14,247
I know where he'll be in April...
Old 03-20-2006, 03:39 PM   #12
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
noice yo
Sheet hoss...
I got 5k on mine and the sprocket looks a little funny
I guess I should get a new chain too?
Is Meaties a good un? Any other chain recomendations
Excellent write up!! Stick it in The Index!!
Surly
I pray that you dont look at me
I pray I dont look back...
Where is Surly?
Surly is offline   Reply With Quote
Old 03-20-2006, 04:03 PM   #13
meat popsicle OP
Ignostic
Oddometer: 14,247
Originally Posted by Surly
Sheet hoss...
There is a specification for max chain stretch in the owner's manual that you can check. warewolf's quick check described above might help you decide to look up the spec, count the links, and do the measurement... I guess I should look it up and post it.
Need a chain recommendation? Sounds like vagina.
Old 03-20-2006, 04:08 PM   #14
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
I will look for that when I get home and for a good online vendor for those chains you mentioned (unless you want to make it easy for me and recomend one)
Surly
Where is Surly?
Old 03-20-2006, 06:13 PM   #15
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
Book say 110 links for stock gearing. I ordered the 120 just to be safe since I heard 118 as well. Looked like the ORS might be better
Not as good at the $100 Z ring chains tho'!
Got mine at Parts 411
REGINA GOLD COLOR 520ORS X 120 LINKS 249-1778-MS
$66.24 Nice
$15.05 shipping. OUCH
$81.29 Total
Surly
Where is Surly?
Times are GMT -7.   It's 09:13 AM.
