Old 03-22-2006, 02:15 PM   #1
leslyrix OP
Oddometer: 3
Question LC4 Post Carb clean sub-frame hitch.
Greetings to all. This is my first post here, I've come accross a little snag that I'm hoping some of you have come accross before . I've just removed and cleaned the carb ( LC4 640E 03 ). In order to get space to remove said lung I'd unbolted the sub-frame and eased it away from the frame, now having replaced the carb I've found that the sub-frame will not fit back over the two lugs on the frame. Sub seems to be about 4mm too narrow. Has anyone else found this? Is this the time to use a brute forcing tool ?
Any pionters would be greatly appreciated. Cheers. Les.
leslyrix is offline   Reply With Quote
Old 03-22-2006, 02:57 PM   #2
dirtrider
Dusty Adventurer
dirtrider's Avatar
Oddometer: 3,316
Now you've completely ruined the bike.
To save you some grief and sorrow, I will be happy to take it off your hands. I will PM my address for shipping.
Shouldn't be a big deal. Have a helper spread the subframe while you start the bolts. Also, I highly recommend using blue loctite on all bolts to save future heart ache.
2013 Husky TE511
2014 KTM 350 XC-F
2006 KTM Adv 950
2001 KTM 640 LC4 Sold
I only like two kinds of women, foreign and domestic
dirtrider is offline   Reply With Quote
Old 03-22-2006, 02:59 PM   #3
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
Welcome, Les.
And listen to dirtrider. The guy's surrounded by orange!
Arch
Arch is offline   Reply With Quote
Old 03-22-2006, 03:27 PM   #4
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
Ditto on the thread locker!
I rattled two loose enough to break one halfway down Baja
Surly
I pray that you dont look at me
I pray I dont look back...
Where is Surly?
Surly is offline   Reply With Quote
Old 03-22-2006, 04:22 PM   #5
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
And next time... don't pull the subframe. The rubber airbox boot is very flexable and forgiving. Push pull... push pull.
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 03-23-2006, 07:03 AM   #6
Beez
Given to fly
Beez's Avatar
Oddometer: 5,810
Bluhduh
Well, at least you can get your subframe off! I've made several attempts to remove mine over the years and it won't budge.
Here's two suggestions. Try a c-clamp to pull the subframe to the main frame - or - a spreader type clamp to push the subframe out. Some bar clamps can be reversed to act as a spreader.
Good luck.
Beez is offline   Reply With Quote
Old 03-23-2006, 09:39 AM   #7
markjenn
Oddometer: 10,441
Welcome.
Did it act like it was tweaked when you first unbolted and moved it? (A loud, springy boooing sound would be a clue.) Unless you've somehow got something installed wrong (unlikely if you just pivoted it up), I think you probably just need to muscle it to get it lined up.
Any hard spills and these things get tweaked pretty easily.
- Mark
Old 03-23-2006, 10:55 AM   #8
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,698
Many times people forget to loosen the clamp connecting the header to the midpipe. Tilting the subframe will push/pull those pieces.
potatoho is offline   Reply With Quote
Old 03-23-2006, 01:27 PM   #9
leslyrix OP
Oddometer: 3
Thumb
Cheers Guys,
Thanks for all the help. I'm just back from me garage sub-frame re-fixed.It took the Brute forcing tool after all ( a large F clamp in fact ) to squeeze the lugs on the frame together enough to slide the sub-frame over. It seemed a little crude, but the jobbies done.
Thanks agan.Excelent site.
Old 05-19-2007, 07:01 AM   #10
goatherder
Wondering WTF?
goatherder's Avatar
Location: Olympia, WA, or the Aleutian Islands & Bering Sea
Oddometer: 46
Just use a hammer
Thats right, just smack the tabs with a hammer to move them in a tad.
I removed the carb and had the same problem. I used a hammer & brass drift to bend the tabs in a little so they'd fit between the horns of the subrame.
If you loosen the exhaust clamp, then remove the exhaust mount bold that's located close to said clamp, you can remove the two upper subframe bolts and shove downward on the ass end of the bike enough to tilt the top of the subframe aft. Oh...of course you need to loosen the front clamp on the aft carb boot first.
After doing this you can then remove the carb quite easily.
goatherder is offline   Reply With Quote
Old 05-19-2007, 07:19 AM   #11
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,400
C
i agree 100% with creepy, i NEVER pull the sub frame to get the carb out. you dont need too. i can have the carb out, stripped, and re-installed in under an hour, and thats while drinking beer. the only real trick is figuring out the choke nut, once ya got that, the rest is easy.
laters,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 05-19-2007, 07:24 AM   #12
bmwktmbill
Traveler
Oddometer: 5,140
10-4 on the hammer.
Did mine.
No issues.
b.
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Times are GMT -7.   It's 12:41 AM.
