Old 03-28-2006, 06:01 PM   #1
mlc OP
Mid Life Crisis
mlc's Avatar
Oddometer: 18
Lighter Rear Spring
Hi All,
Has anyone fitted the lighter 130 Nm rear spring to their 950 Adv?
available from http://ktmtwins.com/950adventure/spss62225-130.html
I'm looking at changing my standard 150 Nm spring to soften the back a little and hopefully lower the bike so I can get both feet down.
Any other advice on lowering a 950 Adv will also be greatly appreciated.
Cheers,
MLC
mlc is offline   Reply With Quote
Old 03-28-2006, 07:49 PM   #2
S Won
Oddometer: 746
Factory Connection used a lighter Eibach spring when they rebuilt and lowered my rear WP shock. 110% better than stock. The preload adjustment knob is now usable. Factory Connection also just did the forks and the bike is now much better than it was before. Highly recommended modifications.
S Won
S Won is offline   Reply With Quote
Old 03-29-2006, 01:34 PM   #3
Wayne Weber
why are we stopping?
Oddometer: 3,856
Dropped mine (04 S model) from the 14.0Kg/mm stock to about 11kg/mm Eibach, and everything is better. Handling, plushness, the preload is useful now.
I'm 150 lbs plus gear.
Wayne
04 KTM 950 S
93 KTM 550
93 XT225 Adventure Serow!
00 Weber Rally Twin (www.rallytwin.com)
Gas Gas 270
2 Waterbuffalo's (Sold!)
Wayne Weber is offline   Reply With Quote
Old 03-29-2006, 02:50 PM   #4
Doug Matson
Doug Matson's Avatar
Oddometer: 2,031
Wayne what was the part number of the spring? Can you now get the right sag?
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
67' Triumph Bonneville
70' CB 350
65' CB 160
Doug Matson is offline   Reply With Quote
Old 03-29-2006, 08:08 PM   #5
motoman250f
Oddometer: 444
I'm ready to order one from ktmtwins and give it a shot. Im trying to gain the same thing you are, lower sag for better reach and not so stiff a rear end. as soon as they get back to me on if it will fit on the 04 950 standard I'll pull the trigger.
motoman250f is offline   Reply With Quote
Old 03-29-2006, 08:24 PM   #6
neduro
Addict
neduro's Avatar
Oddometer: 12,010
Wayne doesn't set sag, just like he doesn't change tires or do maintenance. He thinks it's a sign of weakness.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 03-30-2006, 04:32 PM   #7
mlc OP
Mid Life Crisis
mlc's Avatar
Oddometer: 18
I went ahead and ordered the lighter spring from ktmtwins, very efficient over the internet with a few emails exchanged. It should arrive in Singapore next week sometime , I'll let you know what difference it makes as soon as I get it fitted.
Cheers,
MLC
Old 03-30-2006, 06:11 PM   #8
turbotiger
What's my credit limit?
turbotiger's Avatar
Oddometer: 180
Has anyone who rides two-up didled around with a non-stock spring?
turbotiger is offline   Reply With Quote
Old 03-30-2006, 07:26 PM   #9
Venturer
AKA klakeman
Venturer's Avatar
Oddometer: 696
Guys - I would not recommend going to a lighter spring to reduce the height. This will greatly increase "sag" and will affect the handling. (Think of a car with worn rear shocks that is riding ride soft and low.)
Shortening the travel of both the front and rear suspension is the safer and better solution. This is done by limiting the travel of the suspension. You want your bike to be balanced with the spring rates set for your body weight. By shortening the travel (requires modification of the shock), you achieve lower height, with less suspension travel... but with good, useable and balanced suspension.
I recommend that you speak to a suspension specialist before spending money on softer spring.
Hope this helps.
Kirk
Kirk
'05 KTM 950; '11 KTM 350 XCF; '08 KTM 250 XCF-W; '05 Montesa 250 4RT Trials
Venturer is offline   Reply With Quote
Old 03-30-2006, 09:20 PM   #10
Doug Matson
Oddometer: 2,031
The problem is when your only 150 to 160lbs with no preload on the stock spring the sag is just over 2". The lighter spring is for us skinny guys who want to be able to use the preload ajuster as it was intended. All my dirt bikes with me on them have around 3 to 4" of race sag. I would like to have the sag set to arund 3" using some of the adjuster.
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
70' CB 350
65' CB 160
Old 03-31-2006, 03:39 AM   #11
mlc OP
Mid Life Crisis
mlc's Avatar
Oddometer: 18
I agree, at only 5'4'' and 140 lbs.....the 950 is a handfull
The lighter spring has to help.
And even if it doesn't......it's still the best bike out there
Old 03-31-2006, 06:27 AM   #12
LKN4DRT
Mended
LKN4DRT's Avatar
Oddometer: 714
I weigh 140 and ride stock spring/preload. If I back off the preeload the bike won't handle very well even on the street. You probably need to do both ends at the same time.
Nine five O A
Six nine O E
Five three O
Four five O
Five O O
LKN4DRT is offline   Reply With Quote
Old 03-31-2006, 10:17 AM   #13
Doug Matson
Oddometer: 2,031
I agree I have never done just the rear of any of my bikes, they have to be balanced front to rear. The stock front end on my 950 has been soft from day one. When I get the softer spring I will have both front and rear done.
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
70' CB 350
65' CB 160
Old 04-10-2006, 07:57 PM   #14
motoman250f
Oddometer: 444
ktmtwins rear shock spring
Cheers,
MLC
Dude,, just got my spring and it's correct for the new lowered machines 05.5/06 but the older 03/04/05 need a 255 not a 225. So obviously the spring that comes from ktmtwins won't fit any of the older shocks. the stock on my 04 standard is 255/140.. now the search for a 255/120 or so. maybe mr wayne weber can tell us what part number he ordered from eibach.
Old 04-10-2006, 08:27 PM   #15
Louge
silence of the limbs
Louge's Avatar
Oddometer: 1,554
155lbs with zero rear preload and the .48 fork springs cranked down.
Just how deep do you believe?
Will you bite the hand that feeds?
Nine Inch Nails
Louge is offline   Reply With Quote
Times are GMT -7.   It's 12:10 AM.
