Old 03-29-2006, 09:02 AM   #1
CityClip OP
Upgraded to Scooterdom
CityClip's Avatar
Oddometer: 843
Husky SM610 - Sudden Vibration
I took in my SM610 for the break-in service today. The dealer did the service, no problem and I started riding home. After about 40 miles my bike very suddenly and distinctly started to vibrate. I thought I hit some grooved pavement or some kind of washboard surface in the road. I looked down and saw nothing. I then thought that something was caught in the wheels. I stopped the bike and found nothing. I revved the engine while it was in neutral and found that the vibration was coming from the engine. I called the dealer and gingerly rode back. He examined the bike and suggested a carb adjustment. He adjusted the carb which made the engine run slightly smoother, but the problem didn't go away. The vibration feels much like the vibes on a KTM LC4 or my Honda XR400, not the smoothness SM610 that I bought the bike for (I would have gotten a KTM 640 SM otherwise). It's as if the counterbalancer disappeared. Also, the vibration modulates. The mirrors shake all over the place and the grips and footpegs transmit lots of vibration. It definitely feels like something is wrong with the bike. The dealer suggested I ride home and let him know if there was any improvement. He said he didn't know what else to do. There was no improvement on the ride home. Other than the vibration, there is nothing wrong with the bike. The motor is strong, and runs quite well (especially after the carb adjustment).
So, any ideas on what this could be?
Thanks.
CityClip
Yellow 2007 Vespa GTS 250ie
Totally :ymca looking yet totally
CityClip is offline   Reply With Quote
Old 03-29-2006, 09:16 AM   #2
dirtypumpkin
"Monster Truck Bike"
dirtypumpkin's Avatar
Oddometer: 13,974
Well that sucks!!! What all did they do to it?
Didnt develop until 40 miles into your ride home?
Out of balance rims, tire pressure change, low on oil, axle missaligned after chain adjustment?
Just grasping at straws, hard to know what they did.
dirtypumpkin is offline   Reply With Quote
Old 03-29-2006, 09:34 AM   #3
digitaldan01
digitaldan01's Avatar
Oddometer: 84
Motor mounts tight ?
Little by little, one travels far
J. R. R. Tolkien
digitaldan01 is offline   Reply With Quote
Old 03-29-2006, 10:36 AM   #4
CityClip OP
CityClip's Avatar
Oddometer: 843
The problem didn't start until I was 40 miles into my ride home. And, the problem started suddenly. And the bike vibrates even when it is not moving.
CityClip screwed with this post 03-29-2006 at 12:05 PM
Old 03-29-2006, 10:51 AM   #5
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,239
Broken balancer shaft drivechain? (or is that gear driven?)
Max Kool is offline   Reply With Quote
Old 03-29-2006, 10:57 AM   #6
digitaldan01
Oddometer: 84
Originally Posted by CityClip
He said he didn't know what else to do. Thanks.
CityClip
This worries me even more than the problem itself. But it's worth checking everything over.
J. R. R. Tolkien
Old 03-29-2006, 11:14 AM   #7
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,865
...and if chain-driven, does said chain have a tensioner?
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 03-29-2006, 11:44 AM   #8
ilmostro
Under Da Sea
ilmostro's Avatar
Oddometer: 29,256
+1
I've got stay the fuck out of it written on a stone tablet in my bedroom. - Con Stapleton
ilmostro is offline   Reply With Quote
Old 03-29-2006, 04:22 PM   #9
Chadleys1
working on it
Chadleys1's Avatar
Oddometer: 564
Give the bike a good nut and bolt check.
Sounds like something wasn't torqued properly at assembly and worked loose on your way home. I am not too familiar with this bike, yet, but I also think motormounts would be a good place to start.
Take your time, and don't freak out, you will find it.
PS I am about to be in the same boat as you, riding my 610 Husky home this Friday. Mine is a TE.
Good Luck and let us know what happens.
Chadleys1 is offline   Reply With Quote
Old 03-29-2006, 04:56 PM   #10
RRob
RRob's Avatar
Oddometer: 642
Originally Posted by Chadleys1
Give the bike a good nut and bolt check...
Focus on what may have been adjusted today at the dealer. Keep it simple.
RRob is offline   Reply With Quote
Old 03-31-2006, 10:19 PM   #11
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,239
Check this article, exactly the same problem?
Old 03-31-2006, 10:56 PM   #12
Django Loco
Django Loco's Avatar
Oddometer: 3,785
I would be a bit suspect of your dealer. First of all, someone there should
have ridden the bike. Secondly, counter balancers coming apart internally
are a known problem. They should know about this.
Its not that hard of a fix if it doesn't come completley apart.
I would not ride the bike at all until repaired. That kind of vibe
is NOT normal. I just can't believe your dealer sent you home
Good luck in getting it squared away. Neat bike.
Django Loco is offline   Reply With Quote
Old 04-03-2006, 08:48 AM   #13
CityClip OP
CityClip's Avatar
Oddometer: 843
Thanks. I'm out of town until April 9. I'll definitely check this stuff out. Especially the counterbalancer thing when I get back. Thanks. -- just read the description of the problem, if it´s not the same problem, I´ll eat my hat. I've already e-mailed my dealer...
CityClip screwed with this post 04-03-2006 at 08:57 AM
Old 04-03-2006, 02:17 PM   #14
buffallodan
buffallodan's Avatar
Oddometer: 1,709
Cityclip could you document the repairs with photos so those of us who are noobs can be sure to check the right thing ...I would like to share the pics with my dealer too so he's sure to check all the 610's on service day...
buffallodan is offline   Reply With Quote
Old 04-03-2006, 09:07 PM   #15
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,380
not to burst your Bubble...
but I use to have a 1994 610 Husky that I use to call Sergey Molotov and not exactlly because I like Russian Vodka...
I think in a period of 18 months I dump about $8000 dollars on it starting with the $2000 i pay for her in the first place, blow up two engines, (One of them Build by Dale Lineaweaver pretty much the best husky/huzaberg tuner and engine builder that is) crack the subframe two times, found a crack on the lower triple clamp, lost bolts faster than I can screw them (Became really good with the safety wire).... and a few other related things do to the questionable metalurgics of Cagiva
anyway my memories of the Husky are closser to a "Black hole" were you keep trowing money at them with out much benefit, not to mension a few wasted Left boot soles trying to start the freaking thing...
Hopefully I was just unlucky and also the materials and engine arquitecture is being Improve or the Russian nickname will keep making sense for a long time..
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Times are GMT -7.   It's 10:57 PM.
