Old 04-05-2006, 05:17 PM   #31
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 20,491
Originally Posted by markgsnw
typically, you use a relay so that a small current through a switch (in this case, the horn button) controls a larger current through the relay circuit. As R_W points out, running a larger current though a switch than it is rated for will toast the switch and perhaps the wiring as well.
Same reason why you want to use a relay with auxilary lights...small current goes through the switch, large current/large wiring for the lights. Relays and fuses are cheap, switches are not, wiring fires are very expensive.
I understand the concept of a relay (I studied lectronics at trade school many moons ago) but I am still curious as to what effect NOT using a relay will have on the horn itself, all other things equal.
Just curious s'all
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 04-05-2006, 05:33 PM   #32
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
The switch is not equal to the relay. That is way you should use the relay. Like using a wire rated at 1 amp in a 10 amp circuit. A dim glow will result?
Frank Warner is offline   Reply With Quote
Old 04-05-2006, 06:49 PM   #33
peterb
Long Distance Adventurer
peterb's Avatar
Oddometer: 225
nautilus
this seems to be hangin' around, so I'll chime in. Yep, they sucked for 3 different horns - THAT ANDREW MADE RIGHT EACH TIME!!!
But, I got a newer model/design that has been installed by my mechanic and is approx 1 year old now and it is FINE, LOUD, and just what I bought it for.
My mechanic says no further electrics are needed - relay, fuse, et al. He must be correct.
peterb www.peterpldma.com
2000 BMW 1150 GS with >160k miles and more to come...
2007 BMW R1200RT - new 4/08 with >130K smiles ...
peterb is offline   Reply With Quote
Old 04-05-2006, 07:08 PM   #34
Whammo
Nature's toothbrush
Whammo's Avatar
Oddometer: 2,065
Can you tell when you're being ignored??
Originally Posted by sti_rx7
Forget about expensive Stebel horns!!!! Go to your local auto parts store and buy some cheaper. The ones made by Wolo are supposed to be the same ones as the Fiamms only with different coloring and labels. They are trumpet shaped and I've replace all my bikes horns with these. They are loud as anything out there. I like to low tone because sound like a semi horn. Everybody jumps when they hear this I can't imagine two of these paired up. I never ran a relay or separate fuse and so far worked great on my BMW's, KLR, FJR, Cagiva and have one sitting in the garage waiting for the KTM 950. Cost about $12.
At $35, they're not all that expensive. You mean you can spend less money and get a loud horn? Gee.
Some of us like the Nautilus and are just interested in making it work better for us, that's all.
"Faster is always better...until it isn't."
Whammo is offline   Reply With Quote
Old 04-05-2006, 07:25 PM   #35
Bonebag
ADDvrider
Bonebag's Avatar
Location: Wisconsin..Hot,Cold and everything in Between
Oddometer: 5,168
A set of horns from a Linconl Continental should run you about 10.00 from a local boneyard..have fun...super loud.
Bonebag is offline   Reply With Quote
Old 04-05-2006, 11:15 PM   #36
bigrichard
bigrichard's Avatar
Oddometer: 2,242
I've got one of those gizmos that measures electrons
What's the range of values the horn can live with?
bigrichard is offline   Reply With Quote
Old 04-06-2006, 05:27 AM   #37
Mercury264
Mercury264's Avatar
Oddometer: 20,491
I know the switch is not equal to the relay what I meant was when all things such as cable length, gauge of cable used etc. was the same. I understand the effects on the switch, cable etc. when NOT using a relay or using the wrong gauge but if the only difference is using a relay or not, what effect does this have on the horn (and the horn alone).
Nobody seems to have an answer. I'm curious as I have other electrical devices that I dont use a relay with.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 04-06-2006, 05:57 AM   #38
NJ_Bob
Occasional Adventurer
NJ_Bob's Avatar
Oddometer: 2,501
Originally Posted by bigrichard
Even I can see that not supplying enough current might keep it from producing max sound but how does that "burn it up much faster"?
I think the use of the relay and installing it properly assures that you have done it right.
The absence of the relay may be a good clue that the wiring was insufficient.
Electrically, there is no difference to the horn if the power passes through a relay or not - assuming that the wiring/switch can handle the current.
These Stebel horns are much louder than any car horn. They're ridiculous. If you don't think so, I would suspect that the one you heard was not getting full power or wired wrong.
Bob Naumann - W5OV - Sachse, TX - K1300GT - IBA #19100
NJ_Bob is offline   Reply With Quote
Old 04-06-2006, 09:02 AM   #39
Mercury264
Mercury264's Avatar
Oddometer: 20,491
That was my exact thought. Using a relay is good and not using one is bad
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 04-06-2006, 04:52 PM   #40
Ayrshire Bull
why the hell not?
Ayrshire Bull's Avatar
Oddometer: 1,307
[QUOTE=bigrichard]I've got one of those gizmos that measures electrons QUOTE]
a flux capacitor?
Ayrshire Bull is offline   Reply With Quote
Old 04-06-2006, 05:20 PM   #41
markgsnw
WTF?
markgsnw's Avatar
Oddometer: 3,471
[QUOTE=Ayrshire Bull]
a flux capacitor?
aye, pass a few o'them electron buggers over here
http://vasaphoto.wordpress.com/
2011 Moto Guzzi Norge 8V GT
markgsnw is offline   Reply With Quote
Old 04-06-2006, 05:22 PM   #42
markgsnw
WTF?
markgsnw's Avatar
Oddometer: 3,471
a relay is just a switch, so all other things be equal, there's no difference.
but I suppose the point is, all other things aren't equal in this situation.
Old 04-06-2006, 08:38 PM   #43
bigrichard
bigrichard's Avatar
Oddometer: 2,242
a flux capacitor?
No, a yardstick :grinner
Old 04-06-2006, 09:20 PM   #44
Frank Warner
Traveller
Oddometer: 6,593
Yer a cat killer.
The loud horn draws what ?20 amps. The standard horn draws 10? The standard horn switch mght be rated for 15 amps. Put 20 amps through something rated at 15 amps and ?
One switch does not mean it will do the same job as another switch - some are for switching low power, others for high power, some for low voltage, others for high voltage. Like motorcycles - some are good for pizza delivery, others are not.
Old 04-11-2006, 07:51 PM   #45
Flash412 OP
Elk Biffer
Flash412's Avatar
Oddometer: 7,469
Electrical Stuff 101
It ain't the RELAY that makes it work right. It is the fact that your stock horn wiring is very small gauge wire. If you run 10 gauge wire from the battery to the relay to the horn to ground, ANY horn will be louder than if you simply use the stock wiring.
Why? Because of the voltage drop occurs when you pass high current through small wire. Let's say your small wire has a total of one ohm of resistance in the horn circuit. Your horn will not work very well. Why? Because a horn drawing 10 Amps running through one ohm drops (V=I*R) ten volts. This is why your air horn requires a relay (and FAT wiring). If you run a DC motor with voltage that is too low, the contacts arc and burn rather than simply rotate the motor. Horn lifetime is greatly reduced.
FWIW, I wired my horn to a relay and ran 10 gauge wire from the battery, through a fuse to the relay to the + terminal of the horn. Then I ran 10 gauge wire from the - terminal to a good solid frame ground. There is NFW I installed it electrically wrong or physically oriented wrong. Now that I found my receipt, I emailed Andrew and got a very strange autoreply or bounce message, I can't tell which.
Click here for Gathering Speed - Tales of Motorcycles and Life
60 countries/6 continents, 40/6 on motorcycles, so far, and counting...
50 US states, 49 via moto. ɹǝpun uʍop uǝǝq ı
Helmet laws interfere with natural selection.
If you TRULY believe that God knows better than man, don't vote, PRAY.
Flash412 is offline   Reply With Quote
Times are GMT -7.   It's 12:04 AM.
