Old 11-01-2009, 01:18 PM   #91
schmidtle
Smitty
schmidtle's Avatar
Oddometer: 71
I'll Second that Emotion
I knew that these horns were sensitive to dirt, water and vibration, so I took EXTRA PRECAUTIONS when mounting mine. I mounted it per the instructions and installed the recommended fuse and relay.
I've had it installed for ~3 months and its deader n' dog shit.
I'm going to order a Honda GL1800 horn for mine. They're super loud and last forever.
schmidtle is offline   Reply With Quote
Old 11-01-2009, 02:15 PM   #92
VStromTom
Oddometer: 1,579
Got one on my VStrom, had it for about 4 yrs now, ridden in cold, toad strangler rains, etc, has always worked, never not worked. Maybe I am just lucky? Doubt it.
VStromTom is offline   Reply With Quote
Old 11-01-2009, 02:15 PM   #93
shikataganai
moof
Oddometer: 348
I killed my Stebel after about 2 weeks. Admittedly it wasn't mounted well and likely ingested both dust and water. We shall see how the replacement does...
shikataganai is offline   Reply With Quote
Old 11-12-2009, 04:23 AM   #94
shikataganai
moof
Oddometer: 348
the replacement came, and was faulty from the get-go. i'm done with stebel.
note the asymmetry of the two contacts. namely, the negative contact is "pushed in" and is missing a corner. methinks it was misaligned when the machine that squares off the corners came along to do its thing.
thankfully, twistedthrottle.com has a lenient return policy, so the horn and the wiring harness are on their way back to them for good.
Old 11-12-2009, 04:55 PM   #95
Southernmost_Paul
Southernmost_Paul's Avatar
Oddometer: 323
I like the ones I have, I don't use them very often.. I hope they still work. Will have to run a fleet test this weekend.
Southernmost_Paul is offline   Reply With Quote
Old 08-31-2011, 05:15 AM   #96
David_in_TX
David_in_TX's Avatar
Oddometer: 117
New improved Stebel Nautilus.
Looks like Stebel is coming out with a new improved air horn. They are
advertising that this is: "More water proof than Nautilus Compact".
http://www.stebel.it/stebel2009/prod...pologia=TUNING
1997 KLR650
http://www.facebook.com/David.Roy.Nichols
David_in_TX is offline   Reply With Quote
Old 08-31-2011, 09:08 PM   #97
Ko
Observant as never
Ko's Avatar
Oddometer: 1,110
Hmm, mine was on the bike for about 60 thousands km... broke the first bracket was mounted on this year right after I crossed in Labrador, now I used a beefier one.
It is mounted as per instructions, but it's still exposed to water/dust, and unfortunately mud from time to time
no snowflake ever feels responsible for the avalanche...
Ko is offline   Reply With Quote
Old 08-31-2011, 09:10 PM   #98
Ko
Observant as never
Ko's Avatar
Oddometer: 1,110
The exterior looks pretty identical to the original one...
Old 09-13-2011, 10:14 AM   #99
Kebo Biru
Kebo Biru's Avatar
Oddometer: 12
hmm...it seems many user have a problem with this horn. I use Stebel Nautilus for 4 years and till now it's still OK. Even in hard rain, dusty road and mud condition, the horn sounds still loud. At least better than i kick the rearview mirrior of car
I try to share how to fix and maintain this horn ( sorry my bad english, hope you understand ) :
1. Pull out the complete dynamo from the plastic cover, using flat screw driver by slowly.
2. Open the dynamo from the tube ( use flat screw driver ).
3. You will see naked part of dynamo.
4. Spray the tube and air channel with air compressor. The dirt will get out...
5. You can spray with WD-40 the tube of dynamo and angker of dynamo ( sometimes many rust in both place ).
6. Install back the dynamo to the tube.
7. Connect the positive and negative probe of dynamo to battery, the dynamo will energized. Keep it energized untill the WD-40 include the dirt out. Usually 1 -2 minutes energized.
8. Put in back the plastick cover to dynamo. Please be carefull of crack the plastic.
9. You can add some of power glue to fix the cover with dynamo body.
Soonest i will send the pictures ( still try to find out where i put the picture... )
If you have question or maybe confuse, do not hesitate to ask me. I will glad to answer it.
HTML 2251 - South Jakarta
D' Banditos - Soul Of South
NUSANTARIDE ~ Ride The Archipelago
Safety is Nothing, Skill is Everything....
Kebo Biru is offline   Reply With Quote
Old 09-13-2011, 11:48 AM   #100
Smoke Show
Smoke Show's Avatar
Oddometer: 110
Mine is going on 5 years and still scares the crap out of half asleep motorsists. Mounted on my GS and seen it's fair share of dust, mud, rain and even snow! What gives???
06 R1200GS
03 250 EXC-F
06 CRF-50F
Smoke Show is offline   Reply With Quote
Old 09-13-2011, 11:58 AM   #101
Speedo66
Transient
Oddometer: 6,936
I had a Stebel on 2 cars. One went through 2 horns and is on the third, the other is still on the original one. Same mounting location on both.
My advice if you want one is to buy it from Griot's Garage. http://www.griotsgarage.com/product/...rrivals&page=1 They currently have free shipping until Oct. 17, they charge the same $40 as everybody else, and have a lifetime warranty on anything they sell.
They replaced the horn free twice for me with no questions asked.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 11-14-2012, 04:05 AM   #102
VladM
Oddometer: 49
Long term update:
Over 130,000Km on my Bandit and the horn is still blowing hard (i.e. not sucking :) ). It is pretty well protected from the elements, but it has survived a lot of washes and some pretty terrible torrential downpour rides. As far as vibrations go, it's mounted solidly on the fairing frame with two anchor positions (both held with zip ties and hose clamps). Those who know the 1200 Bandit know that vibrations don't get much worse than that.
All in all, I'm quite happy. The horn has lost a bit of it's loudness over time - it recently measured 110dB from 1.5m away. I just found these that look like perfect clones for less than half the price, so I'll get one for the car and my wife's scooter:
http://dx.com/p/110db-snail-compact-...d-black-155338
http://dx.com/p/snail-style-car-elec...ver-12v-154940
VladM is offline   Reply With Quote
Old 11-14-2012, 06:25 PM   #103
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,433
I run twin electrics.. hi and lo, sounds like a Buick and commands instant awareness. Fiamm Highway Blasters
Old 11-14-2012, 08:05 PM   #104
Renegade_Azzy
Kamen Rider
Renegade_Azzy's Avatar
Oddometer: 904
I wonder how many have a spider nest in them? Perhaps a little piece of screen is in order. Might do that with mine, been on there for... I think about 4 months, come in handy a few times, no issues.
___
AzzysDesignWorks.com Need laser cut acrylic for a project? Engraved metal? No problem. Shoot me a PM
Current bikes; '99 R1100GS ABS, '80 CM400A Hondamatic
Renegade_Azzy is online now   Reply With Quote
Old 11-15-2012, 06:31 AM   #105
worwig
Oddometer: 1,304
This is what I put on my bikes. When someone starts into my lane, they hear a Buick and get away. The 'screaming girl' sound that the Nautilus makes just confuses them, so I removed it and went back to the Fiamms.
Hog mountain Weather
worwig is offline   Reply With Quote
Times are GMT -7.   It's 12:15 AM.
