Old 04-07-2006, 09:08 PM   #16
backdrifter OP
Wannabe rider
backdrifter's Avatar
Oddometer: 1,364
Originally Posted by pitbull doug
Hey I was wondering what main jet your running with the akro.Or what seems to make it run best. Being a cheapass I was considering just the slip on muffler w/o the header,what ya think? Also with insert on a sparky test it seems that the stick they stick in to check would hit the insert making them believe it was a sparky of course w/o a visual check,which is unlikely.Whadda think
thanks pitbulldoug
00 300exc
03 525 mxc
06 640 adv next week yea!! about time!!
Right now I'm running a 175 main (FCR-41 carb), but the plug looks a little lean. I'm going to go one or two jet sizes up. As for the insert, it is a straight-through pipe. If someone tried to stick something into it, it would keep going. There is no bend or screen in the insert, so it would not pass a sparky test. Good thinking though! I'm sure you could always rig up a screen in the insert somehow...
"We are very good at preparing to live, but not very good at living."
-Thich Nhat Hanh
1973 BMW R60/5:
http://www.advrider.com/forums/showthread.php?t=608166
backdrifter is offline   Reply With Quote
Old 04-10-2006, 01:15 PM   #17
Trailsurfer
Oddometer: 61
Thanks backdrifter, good info!
Trailsurfer is offline   Reply With Quote
Old 04-11-2006, 01:11 AM   #18
cat
cat's Avatar
Oddometer: 1,323
Originally Posted by backdrifter
AHA!!!!
Targa Accessories! Finally remebered. Here is there website:
http://www.targa-acc.com
You have to do some searching to find it. Search for "taillights" under the category drop down menu. I got Part No: 07-5000B for mounting to the license plate. They also have a swivel base mount one. Looks like they are $33.50.
Good luck!
Thanks! That could be useful. It looks like it has more LEDs than the cheapo Baja Designs one. You could even use two, one below the other.
cat is offline   Reply With Quote
Old 04-11-2006, 06:27 AM   #19
backdrifter OP
Wannabe rider
Oddometer: 1,364
Yep, absolutely! If you're just looking for bright LED's, check out Custom Dynamics. They're more expensive, but they are smaller and brighter. I used them on my last bike and really liked them. I went with the one from Targa this time because it was cheaper and mulit-function.
-Thich Nhat Hanh
1973 BMW R60/5:
Times are GMT -7.   It's 09:32 PM.
