Old 06-23-2008, 08:51 PM   #46
squish
Out of the office.
Oddometer: 6,371
Yet another happy customer.
I just got the shaft into the bike.
After getting some tips and tricks from fellow inmates seems my swing-arm to shaft fit was very tight.
But Guy went out of his way to make sure it's ok.
On vacation for a spell
squish is offline   Reply With Quote
Old 07-03-2008, 01:21 PM   #47
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 332
Another Satisfied Customer
Put your shaft in the bike and rode to Montana, about 3k round trip. The old shaft was out of phase by about 10 degrees, and I sent it to you for a replacement. Prompt receipt, no problems at all. Nice to know I can grease the u-joints once a year along with the spline lube, and replace them when they do wear out.
ridepjride is online now   Reply With Quote
Old 08-24-2008, 01:50 PM   #48
rkjjeep
rkjjeep's Avatar
Oddometer: 527
need to machine swingarm
others installing serviceable joints require swingarm machining. Does this joint require any grinding on the inside of the swingarm to fit? thanks
rkjjeep is offline   Reply With Quote
Old 08-25-2008, 08:21 AM   #49
HPMGuy OP
Oddometer: 264
No, it will not require any grinding/modification to the swingarm. A few customers have reported snug fits, but a little bit of wiggling in the right spot has allowed the shafts to pass through without modification. The swingarm is a casting, so some variance in dimension is expected, but the overwhelming majority will not have any issues, and will find the shaft will slip through just like the original.
HPMGuy is offline   Reply With Quote
Old 09-28-2008, 05:16 PM   #50
Matt the Wanderer
Supremely Not Lost
Matt the Wanderer's Avatar
Oddometer: 265
Balancing?
I see the units have been modified significantly from the stock condition with additions of grease fittings and some welding, so it seems reasonable to wonder if they are still balanced. I doubt that you would be able to feel an out of balance condition over the Airhead's shaking, but the bearings would certainly know the difference and wear out sooner.
Fine looking craftsmanship, btw.
Simple: a tent with one pole, a chair that sets up in 5 seconds, and black coffee. This is good.
Matt the Wanderer is offline   Reply With Quote
Old 10-07-2008, 08:26 AM   #51
HPMGuy OP
Oddometer: 264
I do not balance the shafts...I do not believe it is necessary, but I regularly have customers remark on the reduction of vibration they notice after installing a rebuilt shaft, and the reason is that BMW staked in the u-joints, and were very inaccurate in how they went about it. Sometimes the joints are staked .02-.03" off center in the yoke....now this will cause vibration(not even mentioning the installation tolerances on the stock damper.) When adapting the yokes to use circlips, I correct these errors, and when done the joints are installed within a few thousandths of direct center.
Old 10-24-2008, 02:46 PM   #52
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,074
Repeat customer here... sold my R100GS and replaced it with a 1981 R80G/S... sadly the u-joint was notchy and tight...
So, as of a few days ago my G/S driver shaft is headed down to Guy to have the u-joint replaced.
Thanks for offering this great service Guy!
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 11-10-2008, 08:19 AM   #53
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
do you still have a core that i can use while i send mine in for work?
i'm thinking about heading this off at the pass while i have the cash.
bmwblake is offline   Reply With Quote
Old 11-10-2008, 09:06 AM   #54
HPMGuy OP
Oddometer: 264
Yes, I still offer the exchange service, though I don't have any cores ready to ship at this moment. If you want to do an exchange, I will get a spare in the works, let you know when it is ready, then ship your exchange unit.
Old 11-26-2008, 07:07 PM   #55
Milagro
Milagro's Avatar
Oddometer: 113
Hi HPM Guy,
Do you offer simple u-joint replacement for the old style driveshafts (R75/6?).
Thanks,
Steffan
Bikes:
1975 R75/6
1994 YZ250
2003 Stella
Milagro is offline   Reply With Quote
Old 11-29-2008, 04:32 PM   #56
HPMGuy OP
Oddometer: 264
Hello Steffan,
Yes, I do offer joint replacement for the early shafts. Cost is $170 + shipping.
Thank you for your interest,
Guy
Originally Posted by Milagro
Hi HPM Guy,
Thanks,
Steffan
Old 12-01-2008, 01:01 PM   #57
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
get a spare in the works. i'm pulling a pre-emptive strike on the driveshaft.
Old 12-02-2008, 07:01 AM   #58
gildo
Oddometer: 3
Any photographs of the shaft
Again, well done Guy for coming up with this service!
This is the mod I have been waiting for for some time, having gone through 2 drive shafts (one of which took out the housing as well!!, expensive!)
I'd like to see some pictures of the re-manufactured shaft if possible (can't see the ones on your initial message for some reason).
Also, what is the benefit of reduced damping for the 'intermediate' and off-road biassed urethane damper (I assume I would not actually feel the more 'direct' drive, as you mentioned to an earlier message)
G
gildo is offline   Reply With Quote
Old 12-02-2008, 09:55 AM   #59
HPMGuy OP
Oddometer: 264
I am building up a batch of cores this week, one will be waiting....
Old 12-02-2008, 10:01 AM   #60
HPMGuy OP
Oddometer: 264
Hello G,
I now only offer two types of damper options, standard and heavy duty (used to be intermediate), I have eliminated the off-road. I recommend the standard to everyone unless they are using the bike in an unusual way (very hard), the heavy duty damper uses a higher durometer damper, which is much stronger than the standard, but loses some of its ability to absorb shock.....so more will pass through the drivetrain.
I will respond to your email with a pic.
Guy
G
Times are GMT -7.   It's 04:56 PM.
