Old 12-02-2008, 01:41 PM   #61
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,276
thanks. i'll pull my shaft this weekend and get back in touch with you.
Originally Posted by HPMGuy
I am building up a batch of cores this week, one will be waiting....
bmwblake is offline   Reply With Quote
Old 01-10-2009, 12:07 PM   #62
gildo
Oddometer: 3
Originally Posted by Klasjm
Photos at reply #44
Thanks for the photos!
I recently had the bearings replaced for the second time (before I'd seen Guy's work) by Phil Kingston at Euro Classics (UK).
Clean job though no grease nipple or proper replaceable fit for bearings at 80.
Next time the bearings need replacing I'll know where to go.
Giotto
gildo is offline   Reply With Quote
Old 02-11-2009, 08:55 AM   #63
Jim Moore
Jim Moore's Avatar
Oddometer: 13,237
Hey HPMGuy,
Can you replace / rebuild the u-joints for an R11XX series driveshaft, R1150GS in particular in my case?
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 06-13-2009, 09:59 PM   #64
Farnsrocket
Manos arribas!!!
Farnsrocket's Avatar
Oddometer: 3,983
Crackhead retards keep me steadily employed.
I can't leave good enough alone.
Farnsrocket is offline   Reply With Quote
Old 06-15-2009, 11:08 AM   #65
HPMGuy OP
Oddometer: 264
Soon........I am getting a lot of calls requesting the rebuilds on the later models. Not only are the joints failing, but for the crowd with the heavy right hand, the damper section is spinning also.....it's not just the CHP guys anymore.....
Guy
Originally Posted by Jim Moore
Hey HPMGuy,
HPMGuy is offline   Reply With Quote
Old 06-16-2009, 07:19 AM   #66
GB
Mod Squad
GB's Avatar
Oddometer: 55,995
HPMGuy,
Your attached picture in post 1 is gone, (due to previous server limitations). You might want to add some pics, or ask if you can use the pics posted in post #44
Old 06-16-2009, 11:03 AM   #67
HPMGuy OP
Oddometer: 264
Originally Posted by Gadget Boy
HPMGuy,
Thanks for the heads up, I updated the first post.
Old 05-17-2011, 07:08 PM   #68
Klasjm
R100gs
Klasjm's Avatar
Oddometer: 2,248
Originally Posted by gildo
I'd like to see some pictures of the re-manufactured shaft if possible (can't see the ones on your initial message for some reason).
G
Photos at reply #44
Great workmanship! Thanks
The shaft is still working perfect.
Jim
Jim Klas
BMW MOA Ambassador
Enjoy the travel photos at: klasjm.smugmug.com
Klasjm is online now   Reply With Quote
Old 05-17-2011, 07:15 PM   #69
boxer odyssey
to excess and beyond
boxer odyssey's Avatar
Oddometer: 138
Mines still great too. I have a r100gs one that's done about 15,000km I think. I re-greased at 10,000km and all was well.
boxer odyssey is offline   Reply With Quote
Old 09-23-2011, 12:00 AM   #70
Clancy
Clancy's Avatar
Oddometer: 5,920
G'day, I've only just discovered this thread, mainly because I went looking for info on K1100 drive shafts.
I had a shaft failure on a '93 K1100 yeasterday, pulled it apart today and discovered that the universal joint had failed, with the obvious results
Do you do relacement shafts for my model? preferably heavy duty as it's pulling a sidecar.
Thanks.
Clancy
And he sees the vision splendid of the sunlit plains extended,
And at night the wondrous glory of the everlasting stars.
Clancy is offline   Reply With Quote
Times are GMT -7.   It's 02:30 AM.
