Old 04-11-2006, 07:31 PM   #1
bmwktmbill OP
Traveler
Oddometer: 5,194
KTM Adventure-Steering head bearing adjustment
Hello,
I looked for a thread on steering head bearing adjustment in the index but darned if I could find one. Anyone got wisdom or a link.
Thanks .
Bill in Tomahawk, WI.
bmwktmbill is offline   Reply With Quote
Old 04-11-2006, 08:42 PM   #2
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,239
Ah, do you have the owner's manual?
Originally Posted by KTM Owner's Manual (2003 640a)
Checking and adjusting steering head bearing *
Check steering head bearing for play periodicaly. To check this put
motorcycle on a stand so that the front wheel is off the ground. Now try to
move the fork forward and backward. To adjust, loosen the five clamp screws
1 of the top triple clamp and turn steering stem bolt clockwise 2 until
there is no more play. Don’t tighten the steering stem bolt all the way,
otherwise the bearings will be damaged. With a plastic hammer, lightly rap
on the triple clamp to avoid tension. Re-tighten the five clamp screws with
15 Nm (11 ft.lb).
WARNING
IF THE STEERING HEAD BEARING IS NOT ADJUSTED TO BE FREE OF PLAY, THE MOTORCYCLE WILL SHOW AN UNSTEADY DRIVING PERFORMANCE AND CAN GET OUT OF CONTROL.
! CAUTION !
IF YOU DRIVE WITH PLAY IN THE STEERING HEAD BEARING FOR LONGER PERIODS, FIRST THE BEARINGS AND THEN THE BEARING SEATS IN THE FRAME WILL BE DESTROYED.
At least once a year, the steering head bearings should be greased
(Motorex Long Therm 2000).
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 04-11-2006, 08:47 PM   #3
meat popsicle
Ignostic
Oddometer: 14,239
pic with numbers for text reference
Old 04-12-2006, 08:52 PM   #4
bmwktmbill OP
Traveler
Oddometer: 5,194
Meat,
Many thanks. I should have thought of that but....it was too simple.
Bill.
Times are GMT -7.   It's 06:13 AM.
