Old 04-11-2006, 07:36 PM   #1
bmwktmbill OP
Traveler
Oddometer: 5,218
KTM Adventure-lowering the suspension internal mods
Hello everyone,
My suspension is in a pile and I am ready to tear into it to drop the seat height 2-3 inches by internally modifying the suspension.
Anyone done this? Advice? I tried lowering links but was not happy with the results.
Bill in Tomahawk, WI.
bmwktmbill is offline   Reply With Quote
Old 04-11-2006, 08:01 PM   #2
holycaveman
Oddometer: 14,387
For the shock, There is a couple of ways to do this. The easiest way is add a cushion behind the base valve. This will cause the shaft to ride further up in the shock body. I would only go no more than an inch though.
holycaveman is offline   Reply With Quote
Old 04-11-2006, 08:16 PM   #3
bmwktmbill OP
Traveler
Oddometer: 5,218
Cave,
An inch just doesn't get it. I am 5'10 and travel with a hundred pounds of gear. I hate it when the damn machine falls on me. I gotta get both feet on the ground.
Bill in Hatchet Creek, WI
Old 04-12-2006, 12:51 AM   #4
ErrinV
D Boon!
ErrinV's Avatar
Oddometer: 2,295
What didn't you like about the lowering links? I've just lowered my bike just under 2 inches using the Kouba Links and am pretty happy. I also slid the forks up and put on a lower seat. Now I can comfortably put a foot down. I haven't noticed any drawbacks of having less clearance yet, but maybe I will.
I'll follow this thread to see if there's a better way to lower it.
Errin
Thunderbird 1 - '14 BMW F800GS ADV
"Love comes in spurts!"--Richard Hell
ErrinV is offline   Reply With Quote
Old 04-12-2006, 05:37 AM   #5
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,135
Links
I have a set of Kouba links in my tool box if you want to try them out
PM me your address and I will send them to you
I used them on my Baja trip because the bike felt scary tall with the bags. Dont use them any more tho'
Surly
I pray that you dont look at me
I pray I dont look back...
Where is Surly?
Surly is offline   Reply With Quote
Old 04-12-2006, 06:00 AM   #6
KenR
KenR's Avatar
Oddometer: 1,676
I just had my suspension revalved and resprung. My suspension guy was suprised to find that the Adventure already had spacers in the fork and shock to lower it, installed from the factory. He said without them, the bike would probably be 2" taller - stock!
I wonder if those spacers could simply be made longer to lower it more?
KenR is offline   Reply With Quote
Old 04-12-2006, 06:06 AM   #7
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
Guys, even with just over an inch of lowering, if running knobbies, an LC4 Adventure will bottom hard on big hits. The suspension also works differently because you're already into where the linkage thinks bumps are. I ran the links for a while and then swapped things back after a big desert ride. 'Course, for casual dual-sport usage it won't be much of a problem, but be advised that your suspension will change, and if you're pounding offroad and/or a bigger rider, your knobs will meet your inner fender.
I'd contact Boejangles for a custom scooped out seat instead.
Arch
Arch is offline   Reply With Quote
Old 04-12-2006, 07:51 AM   #8
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,260
So my bike could be 2" taller?!?
Arch, it was my understanding that the WP suspension could be upgraded to suit the rider and their style practically 'without limit'. If a top shelf mountain bike suspension can be setup to absorb 60' drops (I assume or an MX suspension), then ours should be able to be resprung/revalved to accomodate much without bottoming out.
Perhaps I read your post wrong?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 04-12-2006, 09:22 AM   #9
ErrinV
D Boon!
ErrinV's Avatar
Oddometer: 2,295
So did you end up lowering your 640 differently, or is it just stock now? Besides a seat, what are the better ways to lower the bike?
Errin
Old 04-12-2006, 09:51 AM   #10
Buckster
Buckster's Avatar
Oddometer: 1,003
Bend the swing arm and fit a 16" rear wheel.
Buckster is offline   Reply With Quote
Old 04-12-2006, 10:06 AM   #11
meat popsicle
Ignostic
Oddometer: 14,260
That only works on those poser-Aprilia bikes mang.
Old 04-12-2006, 12:49 PM   #12
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
I'm sure the shocks can be made to work shorter, but this ain't about the shock. As with lowering links, a shorter shock changes where your linkage thinks the wheel is in its travel. Remember that it isn't linear. All I know is that on mine, the suspension was more willing to compress with the lowering links in place. I adjusted the shock to fight it, but the thing never felt the same. Always felt like I was into its travel, if that makes any sense. Not horribly so, but I wanted to stop the knobs ripping into the bike's undersides anyway, so I went back to stock.
Again, with dual-sporty tires like stock Saharas, it's probably no worries. Ditto on the rear suspension's travel. For a 90/10 street/dirt LC4, it's probably no worries. I rarely even ride mine outside of the rough stuff, though, so I want all the travel it was built with.
Arch
Old 04-12-2006, 12:54 PM   #13
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
Stock height, you just get used to it. Sidestand makes for easier dismounts in full gear, btw. I wanna get a Boejangles seat for it, but spare pennies are few. If I ever do, I'll just have him scoop it out a bit. But like I said above, lowered might work well for you. Just depends on how the bike gets used. I'd take up Surly on the offer to try out the links.
Arch
Old 04-12-2006, 02:02 PM   #14
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,651
Which lowering links did you use? That is, how much lower?
With the Emig 28mm (1.25") links and the forks pulled through 25mm, my bike is easier to handle on the street. I'd like to do some back-to-back testing in off-road conditions versus standard. Even lowered it is too tall, so I'm wondering if I'll really notice that extra inch when man-handling the bike. If not, it might be better to have the suspension all standard for better handling on-the-move when seat height isn't an issue.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 04-12-2006, 02:07 PM   #15
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
1.25"
Arch
Times are GMT -7.   It's 06:40 AM.
