Old 02-14-2014, 06:10 AM   #151
Georgios
Georgios's Avatar
Oddometer: 180
Originally Posted by sailah View Post
I like the spot filling method as it allows for leaks to be found and repaired quickly. But doesn't the superglue and goop screw up the nipple and make adjusting the spoke impossible? Or is it fine because the wheel should be tried and perfect and the ca acts like a thread locker?
Ive used this method and youre right about the thread locker. Spokes will only give problems when they loosens, they cant become tighter by itself.
All the years, I never had problems with the spokes or wheels using this method. Good luck and let us know about your experiences.
Georgios is offline   Reply With Quote
Old 02-15-2014, 04:41 AM   #152
35xj
Oddometer: 930
did my rear wheel over the last few days. 3 passes with GOOP. mounted up my heidenau yesterday, out 41 PSI in it Dipped it in a bucket.....
NO LEAKS!
debating doing the front now?
35xj is offline   Reply With Quote
Old 02-15-2014, 05:40 AM   #153
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,756
Cool, I'm going to try the spot method if it doesn't work I'll try something else.
I like woodys method of the superglue to keep the goop from pushing out.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 02-15-2014, 09:07 AM   #154
renogeorge
Oddometer: 1,425
I used the Goop process on the rear. Worked great but I did have a slow leak on my trip to Alaska--nothing a topping off every couple of days wouldn't fix. But when I got home and tanked the wheel I noticed small leaks on 3 or 4 spokes. All of these leaks were THROUGH the spoke nipple NOT AROUND the outside. I removed the Goop from the leakers, unscrewed the nipple, cleaned and soaked the spoke end and nipple in metal etching liquid, reassembled with Goop on the threads and "sealing surface" of the nipple and re-Gooped the inside area. Works fine now with no leaks.
My bike is an '07 with lots on grunge on the spokes and wheels. Seems like getting the surfaces clean is the key. Getting Goop down in the threaded inside area of the spoke nipple is important to prevent the type of leaks I had. Thin coats of Goop and let it dry several days if possible.
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 02-15-2014, 09:31 AM   #155
35xj
Oddometer: 930
been debating putting some slime inside the wheel now, just in case...
Old 02-15-2014, 09:44 AM   #156
renogeorge
Oddometer: 1,425
Slime
I can tell you what doesn't work!! For my first attempt, I Gooped, then wrapped the spoke area in Gorilla tape. When I had slow leaks on the road, I slimed it. When I got back from Alaska and pulled the tire off, the Gorilla tape had disintegrated into mushy strips which were rolling around loose in the tire. So there is some kind of chemical reaction there. I suspect the problem was between the Gorilla tape and the Slime--not the Goop. But, you might want to try a bench experiment with Slime on cured Goop.....
KTMs--300, 518, 990
Old 02-15-2014, 03:35 PM   #157
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,475
Don't do it. If it's not leaking...it can't get any better than that! You'll hate yourself come tire change time...
For Sale: 2012 KTM 990 Adventure
Chuckracer screwed with this post 02-15-2014 at 04:13 PM
Chuckracer is offline   Reply With Quote
Old 02-18-2014, 05:02 AM   #158
35xj
Oddometer: 930
still holding air. got about 100 miles on it now.
what's the consensus on doing the front?
Old 02-18-2014, 05:57 AM   #159
Georgios
Georgios's Avatar
Oddometer: 180
Go ahead! But work carefully.
Old 02-18-2014, 06:05 AM   #160
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,475
The problem with the front is the lack of safety bead on the stock 21" rim. If it leaks and looses too much pressure it could spit the bead.
On the other hand...I had a set of 19/17 wheels for my '04 Adventure that HAD the safety bead on the front wheel, had a front tire loose air, spit the bead and put me on my head, so...
Old 02-18-2014, 06:17 AM   #161
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 582
I see no reason not to do the front. I don't understand the safety bead argument, because the innertube does nothing to hold the tyre in place once the air has escaped (as others have said). A tubeless set-up will normally deflate a lot more slowly, so is far safer.
I sealed my rear with mastic in September 2006 (at 10k km) and have never had a problem - now over 100k km. The only downside is that it's more difficult to change tyres. For this reason, next time I will be tempted to try the Gloop method - the problem is, one cannot adjust the spokes. I can on my mastic version, as I stuck small disks of masking tape on the head of each nipple before applying the mastic.
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 02-18-2014, 07:23 AM   #162
Idle
Oddometer: 719
Wink
For a leaky spoke, loctite works a treat. Just align the leaky nipple so it's on the bottom, let the air out and drip a little loctite on the threads. Leave overnight, and air back up in the morning. I cleaned the leaky spoke/nipple with a toothbrush and dried it with compressed air, then tickled it a little with a blow torch before applying the BLUE loctite.
I used Mylar stickers over the nipples, then three coats of black RTV over the stickers, (dot method). I set the wheel on a slightly warm radiator heater overnight and mounted and aired it up the next day.
Proper preperation is key, with sandpaper, steel wool, green scotchbrite ect... and denatured alcohol.
I've NO room at all in the swingarm for an out of true rear wheel, so before every tire change I check and adjust the spokes if necessary, then slather the soapys on to leak check.
The first couple tires, I had a leak or two which I sealed up after dismount.
I've swapped 6 rears out since going tubeless, (12-14k miles) plugged 4 nail/screws in that time.
*cleaning the old rubber off the safety bead before mounting helps to seat the bead I believe.
*Do not place a rim strip over the sealed rim to "protect the sealant".
It makes airing down problematic as the rim strip will spin under acceleration and block the valve stem. I dealt with it by removing the core and puncturing the rimsrip with a small allen wrench for untill my tire wore out.
*Do not put gorilla or duct tape around the rear rim. It will just unravel and end up in a ball or wad. The heat a rear develops, and centripetal force is the culprit I believe.
The best part is you won't even know you picked up a nail or a staple in this case. Fixt in 1/2 a cup of coffee in the morning.
17 x 5.00 Behr rim with safety bead.
Idle is offline   Reply With Quote
Old 02-18-2014, 07:28 AM   #163
Idle
Oddometer: 719
Oh fwiw, I usually air down for trail riding to 17 front, 15 rear and have not had any slippage whatsoever. (rim/tire marked with paint pen)
The rim just outboard of the safety bead is knurled to keep it from slipping.
Old 06-03-2014, 08:17 PM   #164
Toolferone
Oddometer: 323
Well, I am doing this on my Honda Shadow rear tire right now. I went with the 3M 5200 all the way around the rim. I have no idea yet as it takes 7 days to cure. Here is a short video right after I applied the sealant.
Click the weirdly sized photo to see the video
Tom F
My woodworking website
Toolferone is offline   Reply With Quote
Old 10-30-2014, 01:01 AM   #165
wilmar13
Oddometer: 775
I believe the real problem of not having a safety bead is not really for tire retention after air loss, but for air retention in the tire. At least as it related to sealing wheel for off road use.
The sidewalls can deflect away from the rim on impact without a tube (or safety bead), and then burp air out. Happens on homebrew Mtn bike conversions if you go below ~26psi... at what pressure this is a danger on an LC8 beast is unknown, but I bet it is still a much higher pressure than where you would pinch the tube under identical conditions, so why not just run a tube? That is the realization I have come to after trying to devise a way to forego the tubes with skinny wheels.
The safety bead may keep a tire on the rim when it is flat, but it also keeps it from going flat to begin with. That is the only thing that makes sense to me as you are right; an exploded tube does little to keep the tire on the rim.
'14 KTM 1190-R
wilmar13 is offline   Reply With Quote
Times are GMT -7.   It's 11:36 PM.
