Old 10-21-2010, 05:24 AM   #31
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,533
I find GE Silicone II to be stickier in the long run than just silicone
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 10-21-2010, 06:10 AM   #32
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 582
Originally Posted by viola-tor
Hmmm, altering/removing the safety bead... Is that, ummm, safe? Isn't the safety bead what makes this whole concept doable, since "off-road" rims normally don't have the safety bead? Breaking the bead would be the same amount of effort as normal (right?), but...
Thoughts?
I struggled the first time I removed the rear tyre - I think the safety bead was the cause, as the tyre rests against it. Now, with a section removed, it's quite simple if you know where to start.
Normally a puncture will cause a tubeless set-up to deflate more gently than a tube set-up would, as the offending object tends to plug the hole it makes in the tyre, but not in the innertube if there is one. I think it's not as important to have that safety bead with a tubeless set-up.
Some rims don't have safety beads. Does that mean they're dangerous?
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 10-21-2010, 06:23 AM   #33
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,336
Could be. I once had a front tire going soft - didn't know it till I tipped into a second gear corner and it spit the bead and put me on my head. That was on a 19" Excel rim with a safety bead.
That was when I put tubes back into my 950...but I really like tubeless better, so I'm gonna do it again.
2012 KTM 990 Adventure
Chuckracer screwed with this post 11-21-2010 at 08:45 AM
Chuckracer is offline   Reply With Quote
Old 10-21-2010, 06:35 AM   #34
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
I thought all tubeless rims had safety beads. Maybe I'm misinformed. If you're using an inner tube it's a non-issue, isn't that why you/we shouldn't try this on the stock 21" front rim? I remember reading about this in Woody's wheel thread, and about how it's possible to roll the tire off the rim without a safety bead, so he won't attempt to seal the fronts and WILL seal the rears. I could be talking outta my ass, just trying to get all the info...
viola-tor is offline   Reply With Quote
Old 10-21-2010, 08:12 AM   #35
Dino de Laurentiis
Working on it
Oddometer: 79
Has anyone tried these? http://www.alpinaraggi.it/
You switch out the spoke nipples for the Alpina ones with integrated o-ring seals. The advantage being that you can adjust spoke tension afterwards without risking ruining the seal, likely more durable and it's also possibly lighter than stuffing the rim full of silicon or epoxy.
Dino de Laurentiis is offline   Reply With Quote
Old 10-21-2010, 09:01 AM   #36
idahoskiguy
idahoskiguy's Avatar
Oddometer: 1,128
That looks very promising. Any idea where to purchase? My Italian is not very good.
2011 Ducati MTS 1200 S Touring....amazing
2004 Aprillia Futura....sexy Italian mistress
2006 KTM 950 ADV....dirty beast
2001 KTM 640 ADV....most versatile
1999 KTM 300 EXC....woods weapon
idahoskiguy is offline   Reply With Quote
Old 10-21-2010, 09:24 AM   #37
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,336
http://www.advrider.com/forums/showt...ghlight=Alpina
Old 10-21-2010, 09:47 AM   #38
mousitsas
mousitsas's Avatar
Oddometer: 2,786
How about putting silicone only inside the spoke 'cups' and then holding everything together with a few rounds of duct tape?
Old 10-21-2010, 10:24 AM   #39
Grizzz4440
Over the Hill (Wild Bill)
Grizzz4440's Avatar
Oddometer: 106
Duct Tape
Anyone tried just a couple wraps of Duct Tape ?
Grizzz
Ride Hard, Shoot Straight, Speak the Truth = Cooper
Grizzz4440 is offline   Reply With Quote
Old 10-21-2010, 09:21 PM   #40
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,100
I find Sikaflex or most other polyurethane sealants to be way stickier and tougher than silicone on most surfaces. I'm going to be sealing up a set of 18/19" wheels with a combination of seal all and sikaflex this weekend. Only in the dimples, because i like the idea of not having to tear off the whole thing if there's a leak.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 10-21-2010, 11:04 PM   #41
jcma2ra
jcma2ra's Avatar
Oddometer: 10
Absolutely possible and works real well
Here is a set for a KTM
GOLD and Black KTM
More pictures and info here
alpinawheelsusa.com
jcma2ra is offline   Reply With Quote
Old 10-22-2010, 05:12 AM   #42
Dan Alexander
Oddometer: 7,533
True enough. You could also go with Gorilla glue or PL Premium even.
I'm wondering why the Seal All wouldn't be enough, it's pretty sticky itself. Why not try a bit and let dry and see how hard it is to get out and if it looks like it seals well?
Old 10-22-2010, 06:02 AM   #43
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 906
seal all
I try'd just Seal All Just over the nipps, started to have a slow leak after about couple hunderd miles. Maybe some more coats of it would work but its expensive and winds up kinda thin. I jus covered over the Seal All and whole center with silcone. Have'nt had a chance to miles on it yet but it been holding air out in the garage for a couple weeks now.
dogsslober is offline   Reply With Quote
Old 10-22-2010, 07:35 AM   #44
twodollardoug
the calimesa kid
twodollardoug's Avatar
Oddometer: 337
i sealed my wheels using the cyborg method. had to be over a year ago. i have had zero problems. i just rode to moab utah and back tubeless. on 908's front and back at 25 lbs each. i didnt lose one lb of air. one of the best things ive done to my bike. rigggins idaho then moab? i think my test is complete.
"I don't give it a name, but I always speak with it. I don't know if other riders do the same. This is not only a piece of metal - there is a soul" -Valentino Rossi
twodollardoug is offline   Reply With Quote
Old 10-22-2010, 12:19 PM   #45
Dan Alexander
Oddometer: 7,533
Seal All does have small bubbles in it, maybe a bunch of them connected together
My other thought is straight Goop, I use that a lot and really like it... course maybe reinventing the wheel isn't really necessary here
Times are GMT -7.   It's 06:57 PM.
