Old 10-25-2010, 06:39 PM   #61
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 2,991
Originally Posted by viola-tor
do I need to prep the area around the spoke nipples, like scuffing with scotchbrite like is recommended for the other method?
When I do mine, I will use the plastics-safe brake cleaner to degrease the area. Like you, I'd like to hear about scuffing up the recessed areas with scotch bright or similar...
nevermind is offline   Reply With Quote
Old 10-25-2010, 06:46 PM   #62
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,073
Originally Posted by Chuckracer
Grrr...two spokes are leaking. Now I gotta pull the thing apart and put the tube back in it tomorrow morning before I can leave. Dammit!
Well...we'll get it. Maybe I shouldn't have skipped the "Goop" step after all! I guess I have all winter to get it right. Tomorrow we ride!
So, I just finished my rims (cyborg method), but haven't mounted the tires yet. By the way, I ended up using goop rather than sikaflex. And I think the goop does a way better job of sticking to the rim than the seal-all does. If i did this again, I might skip the seal all. I cleaned everything with alchohol, but didn't roughen the surface at all- maybe that would have helped. One new rim, one old rim.
Anyway, I trimmed the seal-all right at the edge of the spoke dimple- the extra seal-all came off easier than I would have liked. Then I went over with goop, making sure to seal over all edges of the previous layer. I'll put some tires on in a few days and see how it did.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 10-31-2010, 08:50 AM   #63
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
How come no one has mentioned THIS to me here in this thread? (thanks for the verbal heads-up WarriorPrince)
http://www.advrider.com/forums/showthread.php?t=596213
Doing a tubeless conversion and running this stuff would give you a 1/4" puncture hole protection, so it is claimed...
viola-tor is offline   Reply With Quote
Old 10-31-2010, 09:59 AM   #64
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,294
So it is a "dry" tire slime basically?
Old 10-31-2010, 10:09 AM   #65
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,241
I've got it in my tubes. Can't say how well it works...hope to not find out!
Chuckracer is online now   Reply With Quote
Old 10-31-2010, 10:28 AM   #66
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
I just read the whole thread, very informative. It's stays liquid inside, but if you get a hole it's forced out into it and then gums up and hardens. It seems you have to be careful on installation not to get any moisture inside, but looks promising. The thing is you can pick up a nail and not even know it, just keep riding, and apparently that's fine. Works with or without tubes.
I'll be considering...
Old 10-31-2010, 10:31 AM   #67
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,473
It may solve some of the leaking issues with the Seal-All not really sealing all
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 10-31-2010, 10:32 AM   #68
Dan Alexander
Oddometer: 7,473
That's what I'm thinking, just Goop it and be done. I like how it flows slowly while drying so I bet it seals better than Seal-All
Then add the Tyre Guardian .. too bad about not being able to use Dynabeads though, I like those.
Old 10-31-2010, 10:56 AM   #69
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
This TireGuardian stuff won't seal the spokes at all, just the outer part of the tire. Ya, I'm thinking maybe do both...
However, after reading the thread there is one catch: If you want/need to use a tire plug you have to CLEAN the TireGuardian latex stuff out of the hole... I can only imagine that means un-mounting the tire so you can get at it from the inside. If it's doing it's job, you won't need to do that, but if it's not working or your hole is bigger than 1/4" (tubeless) than I suppose you have bigger problems anyway...
Old 10-31-2010, 11:01 AM   #70
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 2,991
Ride-on is another tire sealant and I'm using tire sealant from notubes.com Yeah, the notubes is for mountain bikes, but watching Stan jab hole after hole into a bicycle tire while losing little or no pressure sold me. PLUS it's cheaper AND I can get it locally. I'm running it in the tubes on my 990 and 525. So far, so good.
Sealant:
http://www.notubes.com/tubeless_system.php?cPath=21_60
Very Cool vid, this stuff works!
http://www.youtube.com/watch?v=C_BsT8D9JYY
No, I'm not interested in an arguing about tire sealants...
Old 10-31-2010, 11:06 AM   #71
Dan Alexander
Oddometer: 7,473
Doh, yeah one is on the rim and one is on the tire
Is that necessary for an external plug or just if you want to use an internal mushroom plug? I don't see why you'd have to remove it if an external plug was used as it seals the tire itself. Clean any TG out of the hole and insert the plug and it should work, no?
Old 10-31-2010, 11:07 AM   #72
Dan Alexander
Oddometer: 7,473
Not even a little ??
Old 10-31-2010, 11:10 AM   #73
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 2,991
no sir, sorry...
Old 10-31-2010, 11:58 AM   #74
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
Ya, maybe the rasp tool would clean up the hole enough, but I suspect the stuff is slimy and would interfear with the bond between the gooey plug and tire. Maybe we need some clarification on that point from the manufacturer. The TG is designed to fill the hole, so I think clearing it out might be a trick.
Old 10-31-2010, 12:02 PM   #75
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,173
I agree. In addition, if you had a cut on the side wall and wanted to put a tube, it'd be a mess. I was originally interested but it's not clear to me if I could just put in a tube without consequences.
bikyto screwed with this post 11-20-2010 at 04:37 PM
bikyto is offline   Reply With Quote
Times are GMT -7.   It's 09:05 PM.
