Old 11-20-2010, 02:49 PM   #91
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,131
Originally Posted by bikyto
You're right. I didn't explain it correctly.
But after thinking about more, my suggestion doesn't work. I was hoping to replicate the suggestion with the paper/duct tape but using a rubber cap instead so that the nipple would turn inside it.
Since you guys are running without this additional headache that I was trying to add to my burden... I'll just forget that idea.
Yeah- a couple reasons I went with this method-
I've never adjusted a spoke before on my motorcycle wheels.
These are mainly street wheels- I'm considering going tubeless on my rear dirt wheels too, though. Street wheels seem to get dinged around less.
It's just not that big a deal to cut off the sealant on a couple spokes and adjust, then reseal. Hopefully that would be the case if I did need to adjust spoke tension.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 11-20-2010, 02:57 PM   #92
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,458
My leaks have always been at the threads of the nipple, never around the base at the rim.
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 11-20-2010, 03:40 PM   #93
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
Good to know!
Using the wire mesh to clean up the surface ... Off I go
bikyto is offline   Reply With Quote
Old 11-20-2010, 03:42 PM   #94
bikyto
bikyto's Avatar
Oddometer: 2,190
Got it! Thanks for the input. I'm just trying to minimize the time spent resealing while on the road if necessary. But that's what tubes are for!
Old 11-21-2010, 07:22 AM   #95
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,865
Maybe the wheel builder used oil on the threads to prevent galling. Prolly have to if the spokes and nipples are both stainless. The oil would screw up your adhesion.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 11-21-2010, 08:34 AM   #96
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,458
Hmmm...there's food for thought. The wheels are 19/17 Excel rims w/ stainless spokes and nipples.
I stripped off all the Goop and Seal-All from both wheels last night...gonna start all over again, and this time pay more attention to prep.
I'm thinking about the paper dot over the spoke nipple technique now.
Old 11-21-2010, 10:08 AM   #97
LukasM
Oddometer: 5,426
Has anybody thought about using sealed rims together with the Tubliss system?
Since neither is completely trouble free on it's own, together they should give you an extra safety margin without any drawbacks other than cost and a bit more weight.
Should be a good solution for those of use using narrower rims that don't have a safety bead like the DID Dirt Stars on the Super Enduro.
LukasM screwed with this post 11-21-2010 at 10:18 AM
Old 11-21-2010, 11:41 AM   #98
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,435
Woody's latest technique, thoughts and advice on sealing wire wheels.
hope i catch you before you got tooo far...
just re-read the whole thread... and i'll try to give ya what works and what doesn't....
amazingly most every technique offered here works when done right...
in a nutshell....
1 ..CLEANLINESS IS NEXT TO GODLINESS when using any of these techniques!!!!...there can be NO oil residues on any spot you want to seal and have the sealants adhere to....
2,,,wheels that have ss spokes and ss nipples invariably have the brown anti-seize on the threads which by way of centrifugal force will work it's way out under the sealant,possibly softening it...this has to be stopped from spreading
3,,,the round paper sticky idea although neat in concept just doesn't cut it because you are removing the equivalent area from the sealers to do their job..fugget it
4,,,it is SUPER important to spray brake clean/acetone/alchohol ie a NON oil cleaner and compressed air that is CLEAN [we traced one sealant failure,ie the entire silicone seal came off in one piece to an air line coming out directly from the compressor tank instead of through the airline oil/water filter system..the technician did all the cleaning and then added an oil film to the finished work...oooops]
5,, it is important to get the sealants way down into the spoke nipple cavity
6,, it is important this be filled and allowed to set/harden cure..
7,,we have found that the single item that affects the success or failure is giving each layer time to cure,,,and that does NOT mean dry to the touch...that skin that forms is like putting a lid on the sealant tube,,and then you put another layer lid on ..and the stuff underneath is still soft,,guys ,,40psi in your tire will force anything that can move out of it's way..air has a peculiar trait of finding it's way the tiniest weakest spot,,hence all the incidences of seeing little air bubbles from the spoke nipple junction....
a caveat i'm going to inject at this point before you even start...make sure your spokes are properly tensioned and your wheel is true so as to minimize the need to turn adjust the spokes ,,the main reason for ruining a seal job...hence we re-commend superlacing because it has the highest chance of not needing spoke tightened on a routine basis.....
another WARNING:
use adequate ventilation so ya do not fry your brains or lungs...my technicians hated performing this task til i myself realized we're getting high/dizzy off this s___. now we have a fan going to blow all the vapors away...'mo betta,,,when they say well ventilated,,even doing this outside the shop [where they did it most of the time] didn't cut it ,,,being 1-2' away was still too close,,,hence using the fan to aggressively move the vapors
so here's what i've done to alleviate the time crunch,,,keep the air from getting seeping through the spoke threads and/or around the nipple rim junction
what ya need is the best of all the previous techniques PLUS what i am going to share...
here's the WWW Rx:
go to your hobby shop.,,,home-depot or whoever has:
1,, thin set superglue in bottle with thin nozzle
2,, a bottle of 'gap-filling superglue
3,, a bottle of accelerator we use a hypodermic needle to apply a tiny bit of the stuff to the right spot
4,, a tube of Silicone II
5,, a can of de-natured alchoho or acetone
6,, a role of 3/4'' wide nylon strapping tape
so having prepped your spoke/nipple rim interfaces
1,,start by filling the holes with the thin stuff and a touch of accelerator ..there!! instantly a non flexing plug,,,,if the holes are too deep don't fill all the way with the thin set ..you can fill up the rest in the next step
2,,now using the gap filler [it's thicker] go around the baseof nipple and apply a not to thick coat ,,just enough to see that the glue is settling nice all around the base ..no need to completely fill it ,,,while you are at it ,fill in the deep holes in your nipple if any ,,,now a touch of accelerator and BAM!!!,set done,,next...
3,,thoroughly wipe all accelerator residue off with acetone/alcohol swab and dry
4,,now we want to apply a nice layer of the Plumbers GOOP,,i start on the outside of the nipple in acircle and swirl toward center kinda like an ice cream cone topping,,,let it settle and cure,,again a nice medium film is better than slobbering all over the place...our tests confirm this stuff sticks better than Seal All,,let this cure overnight
5,,i believe we could apply another layer of goop that extends a lil further out than the last and cure another day and be done with it....i however have chosen an extra step to consist of ,,,
6,,applying a thin layer of silicone II that completely covers the nipples,,i let this cure for 2 days..done properly you will NOT be able to pull this stuff off,,a rotary stiff wire brush is our solution at ripping through the silicone....
7,,last but not least i apply two layers of nylon strapping tape in the appropriate widths as added insurance from errant tire irons
track record ??? 0 failures in the last year especially the ones around the spoke nipple or nipple rim interfaces..
other items that can snooker you,,,these are things found out ,,,from customers complaining of real slow air loss...we've learned to Rx em like this:
1,,make sure the weld divots on your rim are smoothed out or filled in with JB weld and machined down
2,,some new rims have exaggerated knurling on the sides,,if ya have slow leaks you'll see foam appearing real slowly,,,,after letting your wheel sit flat for awhile sometimes up to half hour later and there's the evidence of a leak,,,sanding the highest edges off will cure this...we have also run athin layer of silicone around the entire inside corner of the bead/lip
3,,depending on valve stem ,you may need to flatten the inside surface of the drop center to allow full contact for the o-ring under the metal valve stem.....
the above takes the best of all the previous techniques ,,reduces the time factor considerably ,,,eliminates the two chief air leak passageways by sealing them and providing a stable support for the next layers of sealant...that aren't prone to centrifugal forces or the oils in the nipple
now it's off to ride with mo betta peace of mind that that seal job is not going to let you down....
woody
PS when you have someone do all of the above the parts/materials are circa $25-30/wheel including metal valve stem...the rest is carefull tedious labor.
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 05-22-2012 at 09:55 PM
Old 11-21-2010, 01:14 PM   #99
bikyto
bikyto's Avatar
Oddometer: 2,190
Thank you Woody. Very kind of you to take the time to write it all up.
Old 11-21-2010, 01:48 PM   #100
slackmeyer
slackmeyer's Avatar
Oddometer: 3,131
That's really good advice, and he mentions something that I did, and forgot to mention- I sanded down the weld seams on my excel front rim. I was getting some air leakage there at first, none now.
And as far as the super glue, I know my local art supply store carries zap-a-gap C.A. glue and spray accelerator- it's good stuff, and probably works well for this. But I kind of like the flexibility that Seal-all has.
Zak
ktm
old bmw
others
Old 11-21-2010, 08:56 PM   #101
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,458
Thanks a bunch for that Woody! Yes, you did catch me before I did anything.
I'm on hold now, digesting all this information, deciding how I want to proceed, if at all.
Old 11-21-2010, 09:15 PM   #102
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,992
the new 2011 Husabergs and the KTM 690 SMs are tubeless...anyone know how?
From the outside I can't tell..They do not use special spoke nipples or a cross spoke...has to be on the inside????
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 11-21-2010, 10:05 PM   #103
rooscoe
Oddometer: 24
When sealing the rear rim on my SE using "cyborg" method I first sand blasted the spoke nipples, then steam cleaned. All spokes sealed first try. Haven't had any leaks in a year now. Maybe I just got lucky. Although my rims are silver Excels laced by Woody. Hmmm.
rooscoe is offline   Reply With Quote
Old 11-22-2010, 05:57 AM   #104
woody's wheel works
Built to Last
Oddometer: 3,435
FYI the rims are Saxess made by Behr who make all the rims used by the other 'real tubeless' ie rims with no holes in the air chamber...like all the X-laced rims used by BMW/Aprillia Caponord/moto Guzzi...
according to a link by Nowwhat ,,they use anew special sealing strip..looks like this:
it..
parts fiche link here...
http://www.supermotojunkie.com/showt...-KTM&p=1173669
w
woody's wheel works screwed with this post 11-22-2010 at 09:44 AM
Old 11-22-2010, 07:40 AM   #105
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,992
they use Alpina's o-ring system on the nipples...
w
Sorry Woody...that isn't what I am talking about...The new rims use an internal system....not Alpina Spokes...like I said looks stock from the outside,,,
the answer here:
Times are GMT -7.   It's 06:34 PM.
