Old 04-14-2006, 09:28 AM   #1
G-three OP
Oddometer: 37
2006 640 fuelling ish
Wow, this first post thing feels good. i just picked up a new 640 adv. in march, and love it. after riding a klr for 10 years, its a shock to have not bought the ktm earlier. However, right from day one the bike when left to idle for 20sec to a minute, like at a stop light, would hesitate and sometimes stall when light throttle was applied, like leaving the light. So i figured the bitch was just choked down. During the first service I opened the airbox with a cover like the ktm jobby, re- jetted to a 157.5, which will change to a 160 as i found a lean condition after the plug was checked, raised the needle one clip, drilled slide holes to .117 and hogged out the stock exhaust. The bike starts and idles fine, and under way there is a dramatic improvement over stock, but the stalling problem still persists, if anything it is worse. Next, i turned up a mixture screw like loadeds and played with it. Got a smooth idle, but it did nothing for the problem. So, is it the float level? the bike works awesome. Is it the pilot jet? Do I need to go up size? Any help would be awesome, thanks
G-three is offline   Reply With Quote
Old 04-14-2006, 02:18 PM   #2
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
The occasional "flame-out" is fairly common with a new, tight LC4. Break-in can take a few thousand miles.
You didn't mention what your idle speed is... if its around 1400-1500 rpm, it's a bit too low.
Try raising your hot idle speed to 1600-1700 rpm... too low an idle speed will tend to exacerbate the problem.
When the idle speed is set correctly, the low speed mixture screw will become a bit more "responsive" to adjustments.
At your elevation, the idle mixture screw should be set at around 1.5 to 2.5 turns out from seated.
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 04-14-2006, 02:27 PM   #3
Buckster
Buckster's Avatar
Oddometer: 1,003
Could be the carb breather pipe getting pinched under the seat.
Buckster is offline   Reply With Quote
Old 04-14-2006, 02:29 PM   #4
G-three OP
Oddometer: 37
Creeper, thanks. I'm relieved. Idle was set to 1500 as per the manual, I'll try 1700- 1600 and check it out. I'll try to post some pics when I figure it out.
Old 04-14-2006, 03:04 PM   #5
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
I second the Buckster's emotion - did you check the "evaporative emissions control" hardware? You didn't state that you have either checked or removed it.
From memory a few have had a similar issue and found it to be a pinched line. I don't know much about the fancy SAS system (sic?) on the 04- bikes but folks have been removing them in order to get the engine breathing properly and reliably.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 04-14-2006, 04:05 PM   #6
G-three OP
Oddometer: 37
Haven't removed the emissions control crap yet. seems to have a line from the carb and one from the airbox to the canister were the tool pouch should be and a breather line which runs from the canister to the front of the bike under the tank. Can i remove this crap and plug the holes on the carb and airbox or will it affect the fuelling? as far as venting on the carb itself, all i see is a short 90 degree tube with a breather on it, no way it gor pinched since it sits below the seat inside the frame tubes.
Old 04-14-2006, 04:27 PM   #7
G-three OP
Oddometer: 37
ok forget the carb vent stuff......got a couple of the lines confused and i can see the one that could be pinched...sorry.
Old 04-14-2006, 05:04 PM   #8
meat popsicle
Ignostic
Oddometer: 14,224
G-three,
There are a few guides available for dealing with evaporative emissions devices (not sure about the SAS stuff that your model year has... probably somewhere) and discussion about the carb vents.
But, DO NOT, I repeat DO NOT go about willy-nilly cutting and blocking off lines and vents... most are there for a good reason.
(sorry, but I am a practicing parent; you just were my test subject )
Old 04-14-2006, 05:58 PM   #9
G-three OP
Oddometer: 37
ok, so the lines are as follows, canister has one line venting through the snorkel(its just stuffed in there), one line running under the tank to the front of the bike under the front fairing(to nothing) and one line on the opposite side running to the airbox btween carb and filter. dosen't look like it does much, so i'll plug the airbox and see how it runs. carb has vent tubes that are not attached to the canister, nor is there a pipe attached to the cylinder head betwwen the exhaust.
Old 04-14-2006, 08:59 PM   #10
meat popsicle
Ignostic
Oddometer: 14,224
Canisterectomy thread (not indexed I believe)
Post #8 is a reasonable fella:
http://www.advrider.com/forums/showthread.php?t=85728
continued on #10
950 thread that discusses the SAS-ectomy:
http://www.advrider.com/forums/showthread.php?t=40598
Or not? Lots of opinions of course:
http://www.advrider.com/forums/showthread.php?t=116608
Or yes?
http://www.advrider.com/forums/showthread.php?t=79837
Others that I might index for other reasons...
http://www.advrider.com/forums/showthread.php?t=92937
http://www.advrider.com/forums/showthread.php?t=78700
Old 04-15-2006, 12:39 AM   #11
shardzero
I have a bike.....
shardzero's Avatar
Oddometer: 486
The bike is designed to run with the emission control installed so I would try less drastic measures first. Here in Aus we have issues with fuel quality. Basically results in certain fuels making my bike run like a pig. Maybe try several servos and even a fuel additive.
shardzero is offline   Reply With Quote
Old 04-15-2006, 09:43 AM   #12
meat popsicle
Ignostic
Oddometer: 14,224
Have you looked over the tubing system that KTM installed with the charcoal cannister?
It's helter-skelter at best; and quite a few have had issues with it becoming pinched, likely due to it's factory routing, or when the bike is on it's side the charcoal cannister fills with fuel -both problems interfere with operation.
There has been no posts (save yours) that counciled to leave the charcoal cannister in place. There is, however, a difference of opinion in regards to the SAS system. Although I don't have experience with this (not part of the 2003 models), some say it excessively leans out the mixture under deceleration, causing popping, whereas others say it's no big deal. Probably relates to bike setup.
Old 04-15-2006, 02:56 PM   #13
G-three OP
Oddometer: 37
removed the canister. totally rinky-dink. i can't honestly say by looking at the setup that it will effect the way the bike runs, but i'll let ya know.
Old 04-15-2006, 03:12 PM   #14
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
It has no effect on the way the bike runs at all, other than it may run better if the fuel tank vent is routed to a location less likely to be pinched.
The EVAP canister is not an "invasive" component... all it does is to use airbox vacuum to gather and contain evaporative emissions in an activated carbon medium.
C
So... how's tricks?
Old 04-15-2006, 05:02 PM   #15
G-three OP
Oddometer: 37
so....the bike works awesome. removed canister, 160 main jet, stock needle position, air screw 1.75 turns out. idle set to 1650-1700. no hiccup
, or stall. i wonder if the canister system was causing a rich condition when left to idle causing the flame out?
Times are GMT -7.   It's 12:21 PM.
