Old 04-14-2006, 03:28 PM   #1
scottcolbath OP
scottcolbath's Avatar
Oddometer: 7,149
Tire changing lube.What do you use?
The ol' soap and water treatment works, but what have you used that you liked better?
I have a flat and I'll be trying out my new Mojo Lever this weekend. I thought I would try something new if there were any suggestions.
S.C.
scottcolbath is offline   Reply With Quote
Old 04-14-2006, 03:37 PM   #2
joelwebb
joelwebb's Avatar
Oddometer: 64
Re: Tire changing lube
S.C.
I use REMA tire mounting paste and have been very pleased with this stuff. I purchased an 8lb. tub of this several years ago and after mounting many tires I still have lots remaining. I made the mistake several weeks ago of trying to un-mount a rear tire on my /5 without the paste and had forgotten just how much this product assists with tire mounting/un-mounting. I think there are several products like this and they are not expensive.....
Regards,
Joel
What I hear, I forget.
What I see, I remember.
What I do, I understand.
~ Chinese Proverb
joelwebb is offline   Reply With Quote
Old 04-14-2006, 03:50 PM   #3
Rad
Just me
Rad's Avatar
Oddometer: 12,176
Forget the water, just squirt liquid dish soap around on the bead and... bingo
Rad is offline   Reply With Quote
Old 04-14-2006, 04:49 PM   #4
SuperGlide
Oddometer: 223
The Old Tire Shop Standard was Murphy's Oil Soap. It came in a big can with a swab. Add hot water and voila.
SuperGlide is offline   Reply With Quote
Old 04-14-2006, 04:54 PM   #5
Steverino
Arrogant Horse's Ass #1
Oddometer: 36,668
I use the vegetable oil based product from NoMar...works very well.
But then again so did dish soap and water. Need it slicker and thicker? Just add more dish soap.
Steverino is offline   Reply With Quote
Old 04-14-2006, 04:58 PM   #6
oldasdirt
Oddometer: 261
You got WD-40. It will work too. oldasdirt
oldasdirt is offline   Reply With Quote
Old 04-14-2006, 05:04 PM   #7
Bob
Formerly H20Pumper
Bob's Avatar
Oddometer: 2,718
I second Rad, I tried soap and water, then more soap less water, more soap...
Also heard about straight Simple Green? Change tires, clean the bike all at once!
Let us know how the new MojoTire lever works?
Bob is offline   Reply With Quote
Old 04-14-2006, 05:06 PM   #8
RXCrunner
Oddometer: 4
cream type handcleaner (gojo) works well.In the construction tire buisness,alot of the old timers use it.Just don't use the type with grit(pumice).
RXCrunner is offline   Reply With Quote
Old 04-14-2006, 05:36 PM   #9
WR_guy
Location: 96' Dr650 - 200 wr400f street legal -- Hot xr50
Oddometer: 883
I dont use any. get the tire in the drop center of the rim and it comes right off and on. leaving the tire in the sun helps too
WR_guy is offline   Reply With Quote
Old 04-14-2006, 05:38 PM   #10
PoodlePumper
Custom Title User
PoodlePumper's Avatar
Oddometer: 1,171
Astroglide.
2014 BMW F800 GSA
PoodlePumper is offline   Reply With Quote
Old 04-14-2006, 05:44 PM   #11
Motoplaner
Motoplaner's Avatar
Oddometer: 23,211
Napa carries a product called "Tire Mounting Lubricant" for about $7 a gallon.
Motoplaner is offline   Reply With Quote
Old 04-14-2006, 05:53 PM   #12
Kamala
Kamala's Avatar
Oddometer: 12,913
Dish Soap and Water. I recently bought Yamaha Tire Lube, It worked OK but it made a mess and was a bitch to clean up. The beauty of Soap amd Water is that its a Soap and Water Clean up.
I survived the Great Folk Music Scare of the 1960s (when it almost caught on) !
Kamala is offline   Reply With Quote
Old 04-14-2006, 06:45 PM   #13
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,871
2nd for wd40. Got to be careful not to get any on your brake rotor.
katbeanz is offline   Reply With Quote
Old 04-14-2006, 07:12 PM   #14
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,354
RU-GLIDE - it's what I use at home. The stuff is awesome.
When I'm on the ride, I swipe those little shampoo tubes from the motels. They make great bead lubes in the field.
gaspipe [the original]
Hair of the dog that bit me, Lloyd...
gaspipe is offline   Reply With Quote
Old 04-14-2006, 07:13 PM   #15
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,354
Originally Posted by PoodlePumper
Astroglide.
That's not where the tire goes....
Times are GMT -7.   It's 11:08 PM.
