Old 04-16-2006, 06:45 PM   #1
DSM8 OP
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,230
2003 KTM 640 ADV (Creeper HELP)
Creeper or somone please help.
I have a problem with my ADV. When I let off the throttle and it returns to the closed position at the bars (I.E. the throttle tube returns to the closed position) the RPM's either increase or remain at a high RPM.
Does someone have a diagram that shows the proper routing of the throttle cables.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
WWW.DSM8.whereamiriding.com
DSM8 is offline   Reply With Quote
Old 04-16-2006, 06:53 PM   #2
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 13,872
Originally Posted by sdmdm8
... the RPM's either increase or remain at a high RPM.
For how long? And it varies due to what? Meaning why does it sometimes surge and othertimes just stay high? Whatever it is, that sure will make your clutch hand busy (and wear out the clutch faster eh?)...
I don't know if such a diagram exists. Why do you think it's cable routing? Perhaps they just need to be lubed?
More info?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 04-16-2006, 07:11 PM   #3
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Hummmmm,
The cables in the stock position route across the back of the bars, down and along the upper left side of the frame backbone, then over the top and into the carb cable bracket. The stock cables are pretty beefy and not easily crushed, so I have a hard time believing they could be squeezed hard enough to bind them.
I suppose if they are miss-routed and in a bind right from the start, this could affect your return to idle.
Assuming they are not miss-routed, I'm more inclined to believe they are miss-adjusted. Remember that you have a pull-open and a pull-closed cable, plus the spring tension on the throttle plate bell-crank... so those areas are your most likely suspects.
The idea of a pull-closed cable is to be able to force the throttle shut, no matter what... a safety device.
The way I adjust throttle cables is to first slacken them up completely, then adjust the pull-open enough to turn the throttle bell-crank to it's stop and no more, then adjust the pull-closed cable to give me about 1/16" to 1/8" of free play at the throttle grip.
Then, with the bike running, you turn the bars to center, full left and right lock. At each of these positions, blip the throttle to make sure it returns to a regular idle. If not, back off the pull-closed cable adjustment a bit.
This is a whole bunch easier if you have a auxiliary fuel bottle, so you can run the bike with the tank off.
If you have a good ear, you can forgo the running test and just listen for the throttle bell-crank to "click" against its stop when you let the throttle grip go.
As an aside, I currently have my cables running on top of the frame backbone and up to the right side of the steering head. Works better with the SUB mount damper set-up.
Good luck sorting it out,
C
creeper is offline   Reply With Quote
Old 04-16-2006, 07:47 PM   #4
DSM8 OP
DSM8's Avatar
Oddometer: 3,230
THANKS!!
Will check that first thing.
Originally Posted by creeper
Hummmmm,
C
Old 05-04-2008, 12:36 PM   #5
nikoktm
nikoktm's Avatar
Oddometer: 131
rewire all the electrical system!
Hi everybody!!!!!
I just sent the frame to be painted (orange and looks great!), but i miss the pictures that i took of the electrical system...
I couldn't find any information about how I can rewire and plug everything again!
If anybody can give me some information or even better, some pictures i will be your friend forever!!!!!!!!!
By the way, It's a ktm lc4 enduro 03!!!!
nikoktm is offline   Reply With Quote
Old 05-06-2008, 12:50 AM   #6
bmwktmbill
Traveler
Oddometer: 4,064
Make sure you have play in the choke cable and that the carb connections to the engine are tight.
b.
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is online now   Reply With Quote
Old 05-06-2008, 07:41 AM   #7
Zerodog
Oddometer: 1,233
Originally Posted by nikoktm
Hi everybody!!!!!
Man this is totally off topic. It isn't even relevant to the original question in any way shape or form. Post a new thread on the topic please. You will get lots of answers for YOUR question.
It is a good plan to take pictures of stuff and have a plan for reassembly before you take it apart. It will be a tough deal plugging everything in. I would start with the parts manuals you should have in your KTM briefcase thing. They might show your harness and the electrical assemblies.
As for the original question,
Check the throttle cables. I bet they are pinched by the tank. It is easy to do. I did it myself once. It is pretty exciting!
Zerodog is offline   Reply With Quote
Old 05-11-2008, 07:13 PM   #8
Motobrandt
Grrrrrrrrr
Motobrandt's Avatar
Oddometer: 627
Yeah but.... Does anyone have any ideas who's going to run for president in 2008?
I know it's a long ways off... But I'm feeling the something other then the typical white male politician...
Motobrandt is offline   Reply With Quote
Old 06-12-2008, 07:29 PM   #9
DIRTYNIDGE
Oddometer: 25
Just incase there is still an issue with the original question.
If there arent any trapped cables to be found and the carby slide is free; try pointing steering staight and giving it a rev, if it doesnt settle back to idle quickly it could be your idle mixture running too lean.
Depending on what carb you have, there may be an idle mixture adjusting screw, on my Dellorto it is just to the right (engine side) of the normal Idle (air) adjusting screw, screw it all way in then back 1.5 turns as a starting point, may need fine tuning, if it bogs down when revving - too rich, If it keeps revving after throttle shut - too lean, may have to be tuned in conjunction with Idle Air Screw.
Apologies if Im barking up the wrong tree here, have just had a similar issue with my bike.
DIRTYNIDGE is offline   Reply With Quote
Old 06-12-2008, 07:34 PM   #10
ChrisC
Molon Labe
ChrisC's Avatar
Oddometer: 6,287
Hi everybody!!!!! I just sent the frame to be painted
Fuckin' n00bs these days...
Chris
'03 KTM Adventure 640
'43 BSA M20WD
ChrisC is offline   Reply With Quote
Times are GMT -7.   It's 10:20 PM.
