Old 04-18-2006, 10:16 AM   #1
F=ma OP
Deceleration is Dangerous
F=ma's Avatar
Oddometer: 63
Neutral Light Always on. '06 640 Adv.
I've read reports of intermitten problems with the nuetral light staying on. And maybe I have got this problem, interestingly it just started after my first service (1000km ), so I'm wondering if the dealer could have cause the problem. The light did go off on its own once.. but now its stuck on again. Anyone know where this sensor is? The dealer changed my front sproket ( from 16 to 15 ) I wonder if a sensor or sensor cable could have been damaged? The bike has about 600 miles on it.
Any tips on what is wrong, is this common?
F=ma is offline   Reply With Quote
Old 04-18-2006, 10:56 AM   #2
DRZmaui
Oddometer: 111
Sounds like switch is disconnected, or grounding out. Or it could be stuck in the off position. The Neutral light comes on when disengaged.
You can find the switch in front of the engine oil filter.
Let me know if this helps. I just replace mine. Had to wait 3 weeks for the part
DRZmaui is offline   Reply With Quote
Old 04-18-2006, 01:45 PM   #3
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Creep's replying...... wait for it
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 04-18-2006, 02:01 PM   #4
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Item 17, (center left) is the neutral switch, located just ahead of the transmission sprocket. This routes thru a multi-plug (30) and on to 48, a diode.
Item 40, a clutch interlock switch also routes to this diode.
Voltage flow is thru the starter button (9), to the aux relay (42).
The diode (40) must be closed (grounded) by the clutch interlock (40) or the neutral switch (17) for the aux relay to become energized, closing the contacts.
When the aux relay closes voltage flows to the main starter relay (37), which energizes, closing the contacts, then voltage can flow to the starter itself.
The neutral light comes on when (I assume) the diode internal curcuit is closed via the neutral switch.
At least thats the way it looks to me... but I could be way off.
Not all circuits are indicated. To view each subsystem, click here.
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 04-18-2006, 02:03 PM   #5
Phoenician
Phoenician's Avatar
Oddometer: 165
Easy fix
Thats an easy fix... Jack up the horn and put a Honda under it. Should fix your problem and any other problems in the future.....
Phoenician is offline   Reply With Quote
Old 04-18-2006, 02:06 PM   #6
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Thats not fair... I could have said fuck it and walked away ya' know.
Well... I could have.
So... how's tricks?
Old 04-18-2006, 02:07 PM   #7
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Bite us (collectively), Uranus Boy....
Fuckin' n00bs....
Chris
1943 BSA M20WD
Old 04-18-2006, 02:48 PM   #8
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Fuckin' n00bs....
I see a rant coming some day... can't wait.
So... how's tricks?
Old 04-19-2006, 05:48 AM   #9
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,234
Get a room you two...
meat popsicle is offline   Reply With Quote
Old 04-19-2006, 06:00 AM   #10
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
It's a fuckin' n00b ass prodding contest. What fun....
Chris
1943 BSA M20WD
Old 04-19-2006, 11:14 AM   #11
meat popsicle
Ignostic
Oddometer: 14,234
All cleaned up.
Thanks man,
The index needs electrical troubleshooting threads.
EDIT: I just noticed that my "get a room" comment now appears to relate to two entirely different individiuals
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
Old 04-19-2006, 11:57 AM   #12
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Thanks man,
You know I love him dearly, but sharing a room? I don't think so....
Chris
1943 BSA M20WD
Old 04-19-2006, 02:46 PM   #13
Buckster
Buckster's Avatar
Oddometer: 1,003
You would share underpants with the guy you freak!
Buckster is offline   Reply With Quote
Old 04-19-2006, 02:53 PM   #14
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Thanks Bucky, ya wanker...
Chris
1943 BSA M20WD
Old 04-19-2006, 03:45 PM   #15
meat popsicle
Ignostic
Oddometer: 14,234
Times are GMT -7.   It's 10:35 PM.
