03-09-2010, 11:02 AM
#61 |
Oddometer: 705
Can you post a pic of your pump and possibly the rocker cover?
03-09-2010, 09:45 PM
#62 | |
Presidient
Oddometer: 167
"I think of a man, and take away reason and accountability...", - Melvin Udall KTM 990 Adventure R 2012 - KTM 640 Adventure 2007 __________________________ Mexico City, Xilitla, Aquismon, the Cave, the River and the Shangrila... Mexico City, Cuetzalan, Nautla, Veracruz dog'meat screwed with this post 03-09-2010 at 10:02 PM |
03-10-2010, 02:00 AM
#63 | |
Scavenger
Oddometer: 107
03-10-2010, 02:21 AM
#64 |
Oddometer: 705
The part of the water pump that is marked with the red arrow has to be parallel with the surface marked on the pic (where the head and the rocker cover join).
Seems there is no pin and hole in your case on the water pump, just ignore it and assemble it. The o-rings, sealant and rocker cover bolts should be enough to hold the pump in place..... ![]() ![]() Anyone else with their 2 'c?? |
03-11-2010, 01:56 AM
#65 | |
Tyre critic
I wouldn't stress about it. It's obvious your engine doesn't have the locator pin.
Cheers, Colin KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread Quote:
03-11-2010, 08:13 AM
#66 |
Scavenger
Oddometer: 107
Yeah I'm not too worried about it, there is only one way for it to go together. Will get it back together tonight if I have time
makazica, thanks a lot for the input... |
04-26-2010, 08:30 PM
#67 |
Motorcycle junkie
Oddometer: 376
Sand the shaft edge!
I'm doing mine now. I had to replace the shaft because of deep pits and I noticed the new one has a sharp edge where it contacts the seal when driven in. I'm pretty sure this could damage the seal, so I sanded it with some 320. Just enough to take the sharp feel off it.
Former Mechanic in Honda and Kawasaki Dealer (eons ago). 38 yrs. of riding and racing dirt and street. |
05-06-2010, 11:09 AM
#68 |
Oddometer: 3
Thanks for this guide. Going to possibly save me $400
Even if I wuss out, thanks.
09-17-2010, 09:09 AM
#69 |
Adventuring Creep
Thank you for this guide! Just got my parts ordered thru my clubmate (with shop discount!), but chose to go with VXB Stainless Steel bearings, http://www.vxb.com/page/bearings/PROD/Kit8971
They were $5.95 each, so quite a bit less and should stand a better chance of survival! They also sell ceramic bearings for it, but at $35 each and not sure about ceramic and hot water, I chose the SS. http://www.vxb.com/page/bearings/PROD/Kit7654
'99 KTM 640 Adventure R ***************************************** East Bay Weekly Coffee ***************************************** Support your local creep! CREEPS MC |
11-11-2010, 02:54 PM
#70 |
Oddometer: 377
No Fit
Wonderful tutorial. Thanks. Problem now is I cannot seem to get the rocker cover/valve cover to fit square. It sits up on one end or other, depending which way I push. I've tried to use two rubber mallets to gently tap-tap.
It also was very tricky to get the water pump itself to fit into the smile-shaped elipse in the block. Here I tap-tapped and it did begin to sink down. Any ideas? Ted Marshall 2002 LC4e 640 enduro 11,000mi |
11-11-2010, 04:43 PM
#71 |
Oddometer: 87
Ted everything should go together pretty easy, if a snug fit.
Just keep moving things around but don't force anything.
"Good people drink good beer" 2006 KTM 625 SMC |
11-11-2010, 05:22 PM
#72 | |
I.Hopp.
Oddometer: 3,076
640 A x 2 |
#73 |
Oddometer: 87
Yep, good advice.
11-12-2010, 09:58 AM
#74 |
Oddometer: 377
Aaaaaah
Thanks.
11-15-2010, 03:30 PM
#75 |
XTique Rider
Oddometer: 7,919
I'm doing the pump on the 2000 LC4E.
Well I don't think its been apart since new. The impeller cover bolts was rusty and one made about 2 turns and seized up. So I would suggest anti-seize be added to the 4 impeller allen head bolts. Thanks for the write up.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails. http://home.windstream.net/catfish/GPS The Early Bird gets the worm, but the second mouse gets the cheese. https://sites.google.com/site/ozarkadventuretours/ |
