Old 04-19-2006, 08:32 AM   #1
Bonebag OP
ADDvrider
Bonebag's Avatar
Location: Wisconsin..Hot,Cold and everything in Between
Oddometer: 5,380
Pissed Akropovic??? Questions
My buddy just picked up a set of slightly used Akropovic pipes for his 950..they don't fit snugly when bolted to the end of the pipes? They move back and forth and side to side.... Is there some sort of washer that needs to be here?? thanks
Bonebag is offline   Reply With Quote
Old 04-19-2006, 08:39 AM   #2
Don Lemelin
Scuderia West
Oddometer: 273
Make sure....
That the gaskets are in place (item number 32) Often times they remain in the stock pipes.
Cheers.
Don Lemelin
www.scuderia.com
www.KTMtwins.com
Don Lemelin is offline   Reply With Quote
Old 04-19-2006, 09:32 AM   #3
Motobrandt
Free Opinions Here
Motobrandt's Avatar
Oddometer: 630
What Don said. I'd guess that's the problem unless there's some weirdness (highly technical term) with the threaded part of the color. Which seems unlikely since it hapens with both sides.
Akros should come with those gaskets. But seeing as how they're second hand they probably got lost, forgotten, or are still rolling around in the bow he got them in.
Motobrandt is offline   Reply With Quote
Old 04-19-2006, 09:53 AM   #4
TipOver
TipOver's Avatar
Oddometer: 405
FMF's don't provide that gasket either.
I suspect the aftermarket companies expect the installer to swap or replace (if defective) the gasket using OEM suppiers.
If I recall correctly the install directions from FMF said to transfer the old gaskets from the stock mufflers. You just remove them using the appropriate tool(s). I beleive they were a metal gaskets that CAN be damaged during removal.
TipOver is offline   Reply With Quote
Old 04-19-2006, 11:05 AM   #5
SeanW
Oddometer: 117
Do You Realy Need Them
I put on FMF's and destroyed one of the gaskets. So I put one pipes on without it. Seems fine. Do you really need them ?
SeanW is offline   Reply With Quote
Old 04-19-2006, 11:55 AM   #6
redboots
Johnny Lung
redboots's Avatar
Oddometer: 141
You "should" renew them whenever the cans are removed as they are crush washers...
Are you a Hollow Chocolate Bunny of the Apocalypse?
redboots screwed with this post 04-19-2006 at 11:56 AM Reason: spelling
redboots is offline   Reply With Quote
Old 04-19-2006, 12:46 PM   #7
TipOver
TipOver's Avatar
Oddometer: 405
Probably
should replace them but I suspect most don't unless they destroy them during transfer to the new mufflers.
NOTE: Yes gaskets should be used in the install. We are dealing with extremely hot gases. If they escape in the wrong place (under your butt, near the airbox, carbs, shock, frame, ect.) they can quickly damage or destroy anything near them. A bit like a cheap plasma cutter.
Old 04-19-2006, 01:34 PM   #8
Bonebag OP
ADDvrider
Bonebag's Avatar
Oddometer: 5,380
Yeah..you really need them...without them the muffler would rattle and spew exhaust everywhere..
Called up the Corse Superbike and all is well..they have them in stock.
Thanks for the info..
Old 05-08-2006, 08:35 AM   #9
richardg
Oddometer: 20
carb settings
Talking od Acraprovics, I have just ordered a pair for my 950, does anyone know whether I need to make any adjustments to the carbs?, I have already lifted the nedles one notch with the origonal pipes (running slightly rich) so I am hoping that the new cans will be fine at this, any thoughts??
richardg is offline   Reply With Quote
Old 05-08-2006, 09:26 AM   #10
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,423
Depends where you live.....i'm in UK and mine is fine with no carb adjustments and wheelies in second off the throttle.
BLUE(UK) is offline   Reply With Quote
Old 05-08-2006, 02:29 PM   #11
Goss
LC8 Adventurer
Goss's Avatar
Oddometer: 1,380
Check the bolts to be sure they are not too long and bottoming out in the Akra's flange before they get snug. Used sets sometimes don't come with all the proper hardware.
2004 KTM 950 Adventure S
2007 Ducati 999S Parts Unlimited
2012 Ducati Multistrada 1200 Pikes Peak
Goss is offline   Reply With Quote
Old 01-23-2007, 02:01 PM   #12
root1
adventureme
Oddometer: 3
Thumb '06/950 Akropovic Exhausts Installation Steps
Thank you for sharing your experiences with Akras installation. I ordered a set for my '06 KTM 950 Orange and beg someone to list installation steps or refer me to the reliable installation procedure if exists. I'll do the legwork:
I guess I want to start with the 'no-air-box-mod' type
Tools: (Any special shop tools other than 950 on-board set)
1.
2.
3.
4.
Extra Parts and materials:
1. Gaskets (manufacture, part number?)
2.
Any Other Pre Installation Category (For example, Elevation Considerations, Environment, Air Box modification or not, Any expected pitfalls?)
Procedure:
( Note: this procedure is an example one; improve it please as you wish)
1. Remove rear fenders
2. Remove original exhusts and check for, save? original gaskets
3. Clean head pipe ends and treat them with ??? if any
4. Install new/original gaskets ( using tool X)
5. Install Akras
6. Check for loose ends and tightness, accuracy of installation
7. Test starting the engine (expectations)
8. Testride with baffles in (expectations)
9. Install fenders
10. Testride with baffles out (considerations, expectations)
Thank you.
Victor Z.
Purcellville, Virginia, USA
root1 screwed with this post 01-25-2007 at 08:45 AM
root1 is offline   Reply With Quote
Times are GMT -7.   It's 11:04 AM.
