04-23-2006, 11:44 AM
#46 | |
Ignostic
Oddometer: 13,844
Flanny's PDF of his guide is available in my Yahoo briefcase, also indexed under "Other External Links to Downloads". Lots of stuff in there that you might want to 'borrow'. Plenty of other useful stuff and fluff in the index. Hopefully I will get the edits done soon and have some cleaning and new additions soon.
Kronreif Trunkenpolz Mattighofen LC4 640 Its not so much staying alive; its staying human that counts. |
04-23-2006, 12:38 PM
#47 |
d00b
Oddometer: 1,692
Meat, thanks for the links, seems like that's what I need.
IMO the index is fine as it stands, it's damn useful. That index is quite an incrdible & addictive thing actually. The bike's already popping a bit & idling not so good just from removing that first muffler plate so I guess it needs to be a bit richer. Problem with the 640 SM is that it has no rev counter, so it's hard to adjust idle mixture screw based on that method of setting a higher idle speed and then adjusting. After listening to a few minutes of idling you kind of forget what the previous idle sounded like... How much would you turn your idle mixture to counteract just a bit of leanness from opening the pipes slightly? Don't need to answer that if it's going to open a can of worms... Thanks anyway for the suggestions so far |
04-23-2006, 12:48 PM
#48 |
Ignostic
Oddometer: 13,844
No tach? Dang...
The best person to answer your question is more than likely creeper. I have never tried to tune a bike w/out a tach; perhaps there are some others who have that know other diagnostics besides RPMs. Read over creeper and Flanny's guides; they might have some info for ya. Perhaps you could turn it a hair and then go for a ride and see how that influences the popping? "idling not so good" means what? Idle hunting? The idle dropped lower after the change? PS - thanks for the compliment on the index, however I say you're full of dirhams...
04-23-2006, 02:43 PM
#49 | |
d00b
Oddometer: 1,692
I suspect the idle always was a bit slow, now it seems to have dropped slightly, stalled twice. Nothing major though, I'll try a light touch on that mixture screw..
I just came back from a ride (1.30 am, hot as hell outside) and I also noticed that the mid-throttle acceleration now seems a bit dull or flat - that would correspond to something I saw on Flanny's site about running lean on the main jet. I tried a bit of choke for a hundred yards or so and the throttle seemed to get more of a kick - does that make sense? Making the mix a bit richer? Or maybe that's oversimplifying it. And all of this would (I think) correspond to my heavy-handed opening up of the muffler. Which is fine - as long as there's consistency with symptoms. Unpredictability is what I don't like. Quote:
04-26-2006, 07:38 PM
#50 |
Oddometer: 53
I bought my Adventure in AUstralia and it had the exact same exhaust as yours. I tried to modify it. Nothing worked other than cutting it open, removing the offending pieces and rewelding it. Basically its not really worth the effort as the thing weighs as much as if it were made out of brick. Order a good aftermarket and wait for it to arrive in the emirates, inshaallah.
04-27-2006, 02:45 AM
#51 | |
d00b
Oddometer: 1,692
As a temporary fix I cut out the first plate, and then drilled 6 x 10mm holes thru the second back plate, so my brick exhaust sounds much better now, not too loud but good, and much more airflow out the back. The carb was suddenly a lot more lean, so now I'm doing the carb jetting and at the same time putting on a smaller back sprocket. I'll see how it goes latter today if the damn wind stops, we've had sandstorm for the past 2 days... |
04-27-2006, 03:21 AM
#52 | |
Bend it Bend it
Oddometer: 5,435
04-27-2006, 07:30 AM
#53 | |
Ignostic
Oddometer: 13,844
04-27-2006, 07:43 AM
#54 | |
Bend it Bend it
Oddometer: 5,435
04-27-2006, 10:09 PM
#55 |
Oddometer: 53
oh I know sandstorms alright. I rode by myself from Sanaa to Musqat through the desert almost 10 years ago on a Suzuki DR 600. That was one tough ride, following wadis and goat tracks for weeks...
I was in Dubai last year for a short visit. It was too hot for riding. Imagine. I live in Canada where its too cold, too much snow etc. Trust me I would rather be too hot. I hope you have this exhaust thing all fixed up. I drilled mine out too before finally giving up on it. lost1 |
04-27-2006, 10:20 PM
#56 | |
Ignostic
Oddometer: 13,844
04-27-2006, 10:29 PM
#57 |
Oddometer: 53
Meat, you got the angle all wrong, How in the hell are we supposed to see the DAM exhaust pipe.
04-27-2006, 10:54 PM
#58 | |
Ignostic
Oddometer: 13,844
04-28-2006, 05:42 AM
#59 |
d00b
Oddometer: 1,692
I recognize that baby, if the shot was a better angle you'd see that it's got Acrapovic pipe, not DAM.
BTW notice the aftermarket Corbin seat, there's a bit of wear but it's still good for a few thousand miles. |
04-28-2006, 05:48 AM
#60 | |
d00b
Oddometer: 1,692
If you were here in summer, you'd remember that it gets up to 50 degrees C (120 F). I'd raher be too cold thanks. The killer in Dubai is that heat combined with massive humidity. 10 minutes on the bike & you are soaked. |
