Old 04-21-2006, 07:20 PM   #1
njyang OP
Oddometer: 154
HB Crashbars and KTM factory CB tank guards
Hi all,
just got a set of HB crashbars from Andy, great service and all. However, I don't see how it is possible to mount the HB crashbars with the KTM factory carbon fiber tank guards at the same time.
The bottom of the KTM guards took up some space that the bottom mounting point of the HB bars will not line up with the bottom mounting bolt of the gas tank.
Anyone has any experience with this?
If they can fit together at the same time, I have a set of KTM guards for sale
Joe
njyang is offline   Reply With Quote
Old 04-21-2006, 07:40 PM   #2
Don Lemelin
Scuderia West
Oddometer: 273
you'll need to trim the guards
If you do it carefully it'll come out well.
I've got both on my bike
http://www.advrider.com/forums/showthread.php?t=131563
Cheers
Don Lemelin
www.scuderia.com
www.KTMtwins.com
Don Lemelin is offline   Reply With Quote
Old 04-22-2006, 01:36 AM   #3
shardzero
I have a bike.....
shardzero's Avatar
Oddometer: 486
Is there any chance you can show images of the mounting of the HB guards. ie, the actual point where they mount onto the bike. Do they only mount to the lower tank and behind the upper tank??
shardzero is offline   Reply With Quote
Old 04-22-2006, 08:57 AM   #4
TipOver
TipOver's Avatar
Oddometer: 405
3 point mount
The HB mounts to 3 points on each side. 1. To a crossbar fixed to the headlight mount assembly. 2. To the bottom of the tank. 3. To the crossbar that runs from side-to-side thru the vent holes in the tanks.
It's a very rigid, very strong system.
TipOver is offline   Reply With Quote
Old 04-22-2006, 12:04 PM   #5
njyang OP
Oddometer: 154
Cheers
Thanks for the info Don, did you have to cut the whole bottom size of the gurads off, or just trim the pug area a little?
Shardzero
I'll get some pixs when I attempt the installation again within the next day or so.
Old 04-22-2006, 01:18 PM   #6
Don Lemelin
Scuderia West
Oddometer: 273
Here you go....
Cheers.
Don Lemelin
www.scuderia.com
www.KTMtwins.com
Old 04-23-2006, 02:15 AM   #7
njyang OP
Oddometer: 154
Thanks for the pix Don, I couldn't bear the thought of cutting up thus beautiful piece of carbon fiber, so unfortunately, the KTM guards are for sale. Plus, I didn't want to silicon on the factory paint job of the tanks.
Here are some pixs of the KTM guards.]
This right guard has slight rash due to a tip over, but it isn't much at all as you can see in the pixs.
Old 04-23-2006, 08:13 AM   #8
njyang OP
Oddometer: 154
Ok, here's some pixs for the installation.
All the nutz & bolts, and MHL to round off the edges
Mounting points at the headlight assemble for the front cross bar, replace the factory nutz & bolts with longer M8 bolts.
Front cross bar mounted, tabs at each end are the upper mounting points for the left and right bars.
These two show another crossbar connecting the left bar to the right through that window between the radiator and airbox. A cover behind the fan on the left side has to be removed by taking off the left gas tank, the inner screw will come out, just be pationed and use the T and socket set from the KTM tool kit, push this hose connected to the airbox partly out of the way, and shine a flashlight to that inner dark spot, and you are good to proceed carefully. The fan cover has to be trimmed according to this instruction/template included with the crashbars.
The bottom of both bars are mounting at the bottom bolts of the gas tanks, replace with included longer bolts.
While losse fitted all the nutz & bolts, I noticed this clearance issue. After tiening different bolts in dfferent orders, the solution was to snug up the bolts at the front bars first, then all bolts on the right side, I found thiis will give me more clearance for the left side. When done, there is still less than a 1/4" gap at that spot. But I think this system is very rigid and will maintain the gap at any "easy and normal" spills
Old 04-23-2006, 08:23 AM   #9
njyang OP
Oddometer: 154
The KTM factory CB guards are for sale
http://www.advrider.com/forums/showt...70#post2615070
Old 05-02-2006, 06:50 AM   #10
rpilottx
Oddometer: 1,430
Adventurer's Workshop Work
I just went thru mounting carbon fiber tank guards on my 950S. I have the stock KTM crashbars on the bike as well. The tank guards were purchased from Adventurer's Workshop and go on with 4 bolts. They required enlarging the bottom holes by drilling out 2-3mm to get the bolts to align.
You might want to give Andrew a call. The product is very heavy and very well made.
rpilottx is offline   Reply With Quote
Old 05-02-2006, 08:44 AM   #11
BigDogAdventures
Fart Letter
BigDogAdventures's Avatar
Oddometer: 5,082
Yes you can mount both
The fitment can be a little tricky---------take your time and when your done you will be so happy. These have got to be the strongest guards you could put on the bike.
bigdogadventures.com
2008 Yamaha WR250R/2006 KTM 450EXC/2014 KTM690/2013 Husky 650 TR650
BigDogAdventures screwed with this post 05-02-2006 at 08:49 AM
BigDogAdventures is offline   Reply With Quote
Old 08-31-2006, 05:04 PM   #12
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,947
KTM Crash Bars
Did you sell your KTM Guards????? I am interested.
Joe Morgan
Originally Posted by njyang
Hi all,
Joe
MymoJoe is offline   Reply With Quote
Old 08-31-2006, 05:54 PM   #13
njyang OP
Oddometer: 154
Joe Morgan
Sorry Joe, I have actually installed the factory CB guards with the HB bars in place.
As is, the bottom side of the factory CB guards will not fit in conjunction with the HB bars. Also, in addition to the bottom screws, sillicon was suppose to be used to glue the CB guards to the side of the tank, which I did not want to, due to the beautiful and "faster" orange paint .
But since the sale didn't happen in these few months, I finally took a deep breath, cut and trim out the whole bottom side of the guards, and sillicon them to the tanks. The lowwer edges were trimmed just enough to clear the HB bars. The job actually came out looking quite good. But there were no screws used for mounting, just sillicon.
I'll try to attach some pixs later on.
Old 08-31-2006, 06:40 PM   #14
njyang OP
Oddometer: 154
Old 08-31-2006, 06:45 PM   #15
njyang OP
Oddometer: 154
Holy crap, your 950 is laying eggs all over the place
Originally Posted by BigDogAdventures.com
The
Times are GMT -7.   It's 05:41 PM.
