Old 04-25-2006, 10:24 AM   #1
rob748 OP
resident alien !!!!
rob748's Avatar
Oddometer: 825
rear sprocket bearing $89.00 !!!! (05 640 Adv)
any one have a # for a bearing that goes in the sprocket carrier on the chain side at the rear
the dealer wanted $89 for it, is this correct or can l get it cheaper and a bearing shop
Help
05 640 adv
rob748 screwed with this post 04-25-2006 at 11:00 AM
rob748 is offline   Reply With Quote
Old 04-25-2006, 10:43 AM   #2
RT jim
Oddometer: 2,006
Originally Posted by rob748
any one have a # for a bearing that goes in the sprokect carrier on the chain side at the rear
Help
05 640 adv
Yes you'll get it cheaper . Bring the bearing it has name and numbers on it. Or it will be mesured. Bike part number won't help at a bearing supplier. Tell em sealed bearing
RT jim is offline   Reply With Quote
Old 04-25-2006, 10:46 AM   #3
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,847
check to see if it's on Loaded's site
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Old 04-25-2006, 01:06 PM   #4
MartinDKtm
MartinDKtm's Avatar
Oddometer: 222
I dont have the exact price for the bearing you want (#3205) but seeing in the shop online fiche on here that they sell the others bearings for the rear wheel(#6205) for 29$ each US. I can have this bearing (#6205) for 3.50 Canadian...So Im pretty sure it can be found cheaper.
Martin
Offroad? Is where everythings begin!
MartinDKtm is offline   Reply With Quote
Old 04-25-2006, 01:10 PM   #5
ldbandit76
Life is good.
ldbandit76's Avatar
Oddometer: 481
This place:
http://www.cbrbearing.com/
Has a large selection of high quality sealed bearings. They probably have the size you need. Take some measurements of it, or read the numbers on it, and give them a call.
They've done right by me.
As a note: do ask who makes the bearings you're buying. There is a big difference between a quality ball bearing and a cheap one, and there's no way to tell by looking at them. Truth be told, price is usually a good indicator, presuming you're getting them from similar sources (industrial supply places).
Dave
ldbandit76 screwed with this post 04-25-2006 at 03:38 PM
ldbandit76 is offline   Reply With Quote
Old 04-25-2006, 01:15 PM   #6
MartinDKtm
MartinDKtm's Avatar
Oddometer: 222
I can have a 3205 bearing for around 30$ Canadian. Just called a bearing supplier.
Old 04-25-2006, 03:04 PM   #7
metlcutr55
LongGoneDaddy
metlcutr55's Avatar
Oddometer: 886
google msc industrial supply and do a search on ball bearing, use the filter to select deep groove ball bearings, i used some of these to modify a set of cast wheels to my klr, worked great prices ran $4 to $8 depending on size. thay have a $25 minimum for me but i deal with them using purchase orders. credit card might be less.
metlcutr55 is offline   Reply With Quote
Old 04-25-2006, 03:14 PM   #8
JonL
Enduro NEEC
JonL's Avatar
Oddometer: 67
Sounds about right for dealer, just bought one at 28 (GBP) from KTM dealer here in UK. I know that it will last though.
JonL
KTM 200 EXC
KTM 640 Adv R
JonL is offline   Reply With Quote
Old 04-25-2006, 03:43 PM   #9
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
JonL
Which brings up the ultimate question.... why does Rob need a rear wheel bearing on an '05 Adventure???
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 04-25-2006, 07:23 PM   #10
MartinDKtm
MartinDKtm's Avatar
Oddometer: 222
Good question ChrisC...I have a 2003 640 Enduro with 20 000km and still on original bearing. I never regreased them and the bike saw a lot of water/sand/mud. No sign of wear at all on them.
Old 04-25-2006, 08:18 PM   #11
cheekymonkey
born again jackass
cheekymonkey's Avatar
Oddometer: 148
INA Part# 3205 2RS
Hi there,
My bearing is also shot at about 5000 miles (8000 kms).
Anyway a friend of mine with an 2002 LC4 640 E got me a replacement bearing.
INA Part# 3205 2RS
I don't have the price of this bearing but I did buy all 5 for about the same price that KTM wanted for their equivalent to the bearing above.
Here's the disclaimer: I have not put this bearing in my bike yet but I guess you could check the dimensions for proper sizing.
Good luck, I hope this helps.
"the dream of this is also make that the person can not make this trip can ride with me ..and use my eues for see and your theyre brain for understand"
ZOA
cheekymonkey is offline   Reply With Quote
Old 04-25-2006, 08:22 PM   #12
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
pressure washer?
Anyways, that price sounds high, in my uninformed opinion. Oddly the 2004/5 microfiche online don't have the wheel assembly so here is a 2003 (which is probably very similar or the same):
Which part is it? Doesn't really matter because the price you quoted is about half the price of the entire hub...
tem #: 58410010044
REAR WHEEL HUB DAMPED CPL.2001
Quanity On Diagram: 1
Cost Each: $192.57
I can't imagine that the 2004- hub is so bad assss that one bearing alone is half the cost of the entire -2003 hub. But there I go guessing again...
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 04-25-2006, 08:22 PM   #13
cba191
wanna buy a monkey?
cba191's Avatar
Oddometer: 744
DOOD! if you're going to have bewbies in your avatar, let them be smokin'
cba191 is offline   Reply With Quote
Old 04-25-2006, 08:27 PM   #14
holycaveman
Oddometer: 14,387
First of all the bearing is a 6205 rsr. A very wierd wide bearing. Parts unlimited don't carry it. a 6205 2rs willl not work.
Second of all
:Which brings up the ultimate question.... why does Rob need a rear wheel bearing on an '05 Adventure???
Sorry rob, the secret is out!
holycaveman is offline   Reply With Quote
Old 04-25-2006, 09:42 PM   #15
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,352
I get these from the local bearing supply place and replace them when they get wonky. They are about $30 and are good enough. Take the spent one out and take it with you to the bearing guy. He'll fix you up and you'll have a new buddy when it's time for wheel bearings.
gaspipe [the original]
Hair of the dog....
gaspipe is offline   Reply With Quote
Times are GMT -7.   It's 02:16 AM.
