Old 11-16-2006, 08:12 PM   #31
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 13,843
Originally Posted by crazybrit
In case this helps anyone else I just replaced mine. I stumbled across Pacific NW Bearing (just down the road from me in Springfield Oregon).
2x KBC 6205-2RS $3.72 each
1x SMT 5205-2RS $13.84 each
1x seal 32x52x7 B $3.50 each
shipping: $4.05: total $28.83.
Can't recommend the owner, Steve Stormont enough, answered lots of e-mails. KBC is korean, I've used them on many bikes. SMT is Japanese.
You've installed them and you are good to go? And which bike do you have (model/year... there is some variance)?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 11-16-2006, 11:42 PM   #32
crazybrit
crazybrit's Avatar
Oddometer: 8,039
I have a 2004 SXC but the wheel in question is a cush 2001 LC4e. Yes
good to go. It's all standard stuff. Plenty of people have used 5205-ZZ
and posted about it, no rocket science.
crazybrit is offline   Reply With Quote
Old 12-09-2008, 05:00 PM   #33
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,169
Send a message via MSN to warewolf Send a message via Skype™ to warewolf
Quick question
Is the sprocket carrier bearing the same OD as the 6205 wheel bearings... 52mm? (bike's not handy to check).
I can't get a 3205 or 5205 here. Can get a 4205 though: 25x52x18. [edit]4205 is wrong, see later post.[/edit]
Ta
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
Originally Posted by Steve McQueen
All racers I know aren't in it for the money. They race because it's something inside of them... They're not courting death. They're courting being alive.
warewolf screwed with this post 12-15-2008 at 08:32 PM
warewolf is offline   Reply With Quote
Old 12-10-2008, 10:56 AM   #34
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 6,435
The bearing CAN be sourced from bearing suppliers. Here in Australia the bearing suppliers unit is half price of what KTM are asking. Mine collapsed somewhere between 36k and 40k (and took the chain with it ). Not a cheap exercise that one. The bike still rode fine, funnily.
GodSilla is offline   Reply With Quote
Old 12-10-2008, 01:49 PM   #35
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,169
[edit]
WRONG!!! The bearing is actually 25x52x20.6 (angular contact ball bearing, double row, seals on both sides)... likely an SKF "3205 A-2RS1/MT33", should be available, will check on Monday.
The product lists I was reading previously did not include the angular contact bearings.
It is NOT an SKF 4205 ATN9, a deep groove ball bearing double row
[/edit]
So it looks like the first digit of the code can vary depending on the market/supplier, as someone alluded to earlier. In this instance, it could be a 3205, 5205 or 6205 !!!
Cheers,
Colin
warewolf screwed with this post 12-15-2008 at 08:33 PM Reason: WRONG! Again!
Old 12-10-2008, 05:02 PM   #36
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,648
Originally Posted by Zerodog
When you get the new one pop a seal off one side with a small screwdriver and pack the crap out of it with your favorite waterproof grease. That is a dirtbike trick to help seal out the water and crap.
no!!!!! bearings come pre packed with a sufficient amount of grease. packing in a whole whack more could cause an overheating condition and failure. you may get lucky and heat the bearing up resulting in liquid grease pouring out... but the result will be similar... no grease... you will likely have a failure.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 12-11-2008, 05:07 PM   #37
Addict orange
You can't fix stoopid
Addict orange's Avatar
Oddometer: 40
To get good high speed bearings try an independent alternator rebuilder. Even small shops like mine have over 100 #'s in stock. Most cost $3-$8.
I have never seen a wheel bearing # I didn't stock.
Work Suckss!
'00 KTM 300
'05 HUSA fe650
Auto Electric and Battery
Addict orange is offline   Reply With Quote
Old 12-12-2008, 12:09 AM   #38
bmwktmbill
Traveler
Oddometer: 4,012
http://www.acehardwareoutlet.com/(ql...rce=GoogleBase
or maybe it was this:(will check the specific tube when I get home).
http://www.acehardwareoutlet.com/(ql...SKU=1000003632
'02 640 Adventure
Guys, I am an idiot but I pulled my sprocket carrier bearing cause it was running rough, after I knocked it out(propane torch to heat gently), I washed it out after popping the seals and then packed the piss out of it(basically filled it full, left some small room for expansion) with the above grease(I packed every other bearing on the bike with this same grease, swing arm, steering head, all wheel bearings-front and rear wheels, pivot, etc.) I even put some under the front fork trash seals ala Creeper...then I rode the bike to Seattle, shipped it to Russia rode to Mongolia(Gobi desert for two weeks, temps around 110F.) and then to Europe. Around 10K miles was gravel sand dirt.
My sprocket carrier bearing still runs rough, I plan to repack it this winter. For now, still the same grease.
When I left for Seattle miles were 14K, now 35K or more.
You will not liquify this grease, it is designed for disc brakes running hot.
Pop the seals with a pocket knife. Just do it.
b
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 12-15-2008 at 11:23 PM
bmwktmbill is offline   Reply With Quote
Old 12-15-2008, 08:28 PM   #39
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,169
Ok, an update.
KTM specifies a 3205B-2RSR. The one in my bike is one of those (I think, the top half of the writing is rubbed off) but it also has "6205 RSR" in big letters on the bearing seal.
FAG/INA do a 3205-B-2RSR-TVH. Talking to my SKF chap, he says SKF are replacing all the "B" series with "A"s, only very minor differences between the two. So the SKF equivalent is 3205 A-2RS1, A for Angular contact.
If I was in the USofA I'd just buy them from Stenhouse Racing...
Cheers,
Colin
Old 12-15-2008, 11:28 PM   #40
bmwktmbill
Traveler
Oddometer: 4,012
This friggin question won't die, to my mind only FAG makes the correct bearing, I bought a spare to carry just for that reason...when I checked with Colin@Stenhouse he was not selling the FAG bearing.
Maybe he is now.
b
Bill Shockley
Old 12-16-2008, 07:31 AM   #41
gunnerbuck
I.Hopp.
Oddometer: 3,076
I replaced my sprocket bearing eons ago with a NSK unit that I picked up at bearing supplier... The # on the box is 3205B-2RSRTNGC3....
gunnerbuck is offline   Reply With Quote
Old 12-16-2008, 01:24 PM   #42
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,169
Most of the answers to my questions were earlier in the thread. Dunno why I missed them
Cheers,
Colin
Old 12-16-2008, 02:25 PM   #43
ChrisC
Molon Labe
ChrisC's Avatar
Oddometer: 6,286
I know for a fact that Loaded specializes in pre-lubed fagina bearings...
Chris
'03 KTM Adventure 640
'43 BSA M20WD
ChrisC is offline   Reply With Quote
Old 12-16-2008, 05:38 PM   #44
meat popsicle
Ignostic
Oddometer: 13,843
Same thing happens to me, all the time...
Old 12-19-2008, 10:51 PM   #45
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 6,435
Hi Meaty
Remember me?
We were lovers once. You still owe me money. When can I have my bike back? How's my missus?
Write soon wontcha.
Times are GMT -7.   It's 01:02 AM.
