Old 12-07-2009, 11:16 PM   #76
bmwktmbill
Traveler
Oddometer: 5,197
Tseta,
I agree, lots of factors influence wear. We have to add running the chain too tight. That's hell on everything including wheels.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 12-08-2009, 12:48 PM   #77
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,613
Originally Posted by Tseta
First, the bearings for both setups are commonly available from industrial bearing suppliers. No need to pay the KTM prices.
Maybe so, but from my bearing supplier the double-row angular contact bearing is still 5 times the price of a normal deep-groove ball bearing.
Given the issue with contamination, I would venture to suggest there is no marked difference in life or performance, merely price. The accountants have finally won!
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 03-05-2012, 03:58 PM   #78
Ohffs
Oddometer: 26
So what's the cheap alternative (off the shelf) bearing that will fit? I don't mind keeping an eye on it or even replacing fairly regularly. This is mine
Also my Cush drive rubbers look worn. Is there a pattern part replacement or is it a ktm visit?
Ktm 620 egs
Ohffs is offline   Reply With Quote
Old 03-05-2012, 10:52 PM   #79
Tseta
Lost
Tseta's Avatar
Oddometer: 674
Ohffs: You seem to have the "older" cush drive setup and as such, are going to be looking for a 3205-B-2RSR double row angular contact bearing. The nomenclature may be a bit different with each bearing manufacturer, but the important part obviously is to get a bearing in the correct size (25x52x20.6) and design (double-row, angular contact, sealed from both sides).
The cush drive damping rubbers (#54610459000), at least to my knowledge, are only available through KTM.
Cheers,
Tseta
Tseta is online now   Reply With Quote
Old 03-07-2012, 05:29 AM   #80
Ohffs
Oddometer: 26
Thanks for the reply. Are the Cush rubbers different from each sprocket carrier types different?
Ktm 620 egs
Old 03-07-2012, 06:02 AM   #81
Tseta
Lost
Tseta's Avatar
Oddometer: 674
No, they are the same for all the sprocket carriers. In fact, it seems that they've been the same ever since model year 1991...
-T
Old 03-07-2012, 06:03 AM   #82
Ohffs
Oddometer: 26
Thought tooled the same. Thanks for the rapid reply
Ktm 620 egs
Old 03-08-2012, 08:51 AM   #83
Ohffs
Oddometer: 26
Picked up a 6205 2rs today just to confirm its no good. 5.6mm too shallow.
Hoping this will do it
http://simplybearings.co.uk/shop/adv...ywords=32052rs
Ktm 620 egs
Old 03-08-2012, 09:35 AM   #84
Ohffs
Oddometer: 26
Can we confirm that (25x52x20.6) is the correct size before I order. I don't have anything to measure my old bearing accurately enough.
Ktm 620 egs
Old 03-09-2012, 12:06 AM   #85
bmwktmbill
Traveler
Oddometer: 5,197
It is late but this is what I see with a cheap plastic caliper
I have an OEM bearing new.
I am seeing 25X52X20.6 so not quite 21mm for thickness?
KTM pt# 0625032057
ball bearing 3205B-2RSTNG.
bill
Bill Shockley
bmwktmbill screwed with this post 03-09-2012 at 12:12 AM
Old 03-09-2012, 12:17 AM   #86
Ohffs
Oddometer: 26
Not late at all mate thanks for taking the time to measure it for me .
Ktm 620 egs
Old 03-09-2012, 09:41 AM   #87
tdreyer
KTiM
tdreyer's Avatar
Oddometer: 504
Let us know how that goes
Noticed mine was rough last tire change.
~Tim
"04625 SXC
'04 625 SMC 76,xxx mi.
'97 CR500 Sold
tdreyer is offline   Reply With Quote
Old 03-09-2012, 09:43 AM   #88
Ohffs
Oddometer: 26
Will do. Rang a local firm who can source one at 35 plus vat but obviously of be able to collect it. Failing that simply bearings stock it a bit cheaper. Il get it within a week and update.
Ktm 620 egs
Old 10-24-2012, 01:08 PM   #89
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,649
any more inputs and feedbacks?
thanks.
NSFW is offline   Reply With Quote
Old 10-24-2012, 01:11 PM   #90
Ohffs
Oddometer: 26
not really. I ordered the bearing from simply bearings and all has been well since
Ktm 620 egs
Times are GMT -7.   It's 11:44 AM.
