Old 10-24-2012, 03:53 PM   #91
Tooltech
Oddometer: 132
Ahoy...there...
Originally Posted by holycaveman View Post
First of all the bearing is a 6205 rsr. A very wierd wide bearing. Parts unlimited don't carry it. a 6205 2rs willl not work.
Second of all
Sorry rob, the secret is out!
You do realize you are riding a motorcycle and not a personal water craft, by the way where is your PFD?
2013 KTM 500 EXC
2012 KTM 990 SMT
6 NOVEMBER 2012 DARK DAY FOR USA
Tooltech is offline   Reply With Quote
Old 10-24-2012, 05:52 PM   #92
rob748 OP
resident alien !!!!
rob748's Avatar
Oddometer: 825
2006
it was 2006 :) used a few bearings from BDI, price has doubled and the bike is getting ready for a full rebuild
rob748 is offline   Reply With Quote
Old 11-02-2012, 05:12 PM   #93
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,812
mine is from a 2002, the carrier not turning smoothly, there's some resistance, and somewhat crunchy.
pushed bearing out, it's made by NSK (germany), # 6205 B2RSR2NG. the OD is 2.0465-2.0470. the bearing itself turns smoothly and no play.
anyway, since it's 2 years old and over 6k miles, i decided to get a new bearing. JAF 6205RS (made in japan @ $30). same OD as the NSK 6205.
i checked the ID of the carrier, 2.0442-2.0445...
based on the above numbers, the interference is over .002. that's a lot....
that explains why the bearing was tight. the outer raceway was getting crushed causing it to collapse.
we do a lot of press fit bearing installation here and the typical interference is .0005 - .001.
does anyone has an uninstalled oem ktm bearing ? OD?
what's the ID of your carrier?
my next move is machine the ID of the carrier by removing .001 of material.
NSFW is offline   Reply With Quote
Old 02-11-2013, 05:52 PM   #94
overlandr
Dystopist
Oddometer: 5,926
Bump the above post.
overlandr is offline   Reply With Quote
Old 02-11-2013, 09:52 PM   #95
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,812
machined the bore to 2.0460, installed the bearing went smoothly (not slip fit). i even balanced the tire afterwards, and i can tell it was spinning with little friction and finding the off balance at the same spot again and again.
already did 2k miles and so far so good.
Old 02-15-2013, 07:54 AM   #96
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,260
Doing some lite maintenance recently I noticed my rear wheel had noticeable play when installed - should there be any play or should it be tight? The discussion I usually found was for what I think's called axial play (left/right movement along the axle); mine does not seem to move axially, but it does wiggle with what I'm thinking's called radial play (like an airplane banking to turn).
I'm not sure how to measure play but if there's a spec please also explain how to measure it.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 02-15-2013, 08:56 AM   #97
Droptarotter
Oddometer: 1,298
Hey Meat..................that wheel should be tight. Any way you forgot to install a spacer???
If not, you have a bearing going.
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 02-16-2013, 10:38 AM   #98
meat popsicle
Ignostic
Oddometer: 14,260
Cheers
I don't think I did (its been thousands of miles since I had the rear wheel off - yikes). I guess its time to contact Steinhouse Racing...
Old 12-05-2014, 04:56 PM   #99
scottcolbath
scottcolbath's Avatar
Oddometer: 7,149
I think I found the correct sprocket carrier bearing for my 2005 640, for $40. I'll be picking it up next week. I do have a question.
Is there a proper order in which to remove and install the new bearing and bushing? Should I knock out the whole bearing/bushing combo in one part, then install the new bearing alone, followed by the bushing? Or, should I press the bushing into the bearing, then install the assembled parts into the sprocket carrier?
S.C.
scottcolbath is offline   Reply With Quote
Old 12-06-2014, 11:36 PM   #100
bmwktmbill
Traveler
Oddometer: 5,218
Bump for this.
I am traveling so I can't look at my parts book.
Darned if I remember a bushing. If you use a heat gun things will go easier.
Freeze the bearing to install.
Anyone else?
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 12-06-2014, 11:56 PM   #101
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,651
That bushing is what is often also called a wheel- or axle-spacer. Remove them before removing or installing bearings in to the hub. Sometimes they can be removed or installed by hand, if not they are only a slight press fit - nothing near as tight as a bearing in to the hub - as they are held in place by the clamping force of the axle nut.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 01-04-2015, 09:17 PM   #102
scottcolbath
Oddometer: 7,149
Anyone know the difference between a 6402 SRS bearing, and a 6402 RSR bearing?
S.C.
Old 01-05-2015, 09:16 AM   #103
markk53
jack of all trades...
markk53's Avatar
Oddometer: 9,198
Originally Posted by RT jim View Post
Yes you'll get it cheaper . Bring the bearing it has name and numbers on it. Or it will be mesured. Bike part number won't help at a bearing supplier. Tell em sealed bearing
Tell them double sealed! Bearings come open, single or double shielded, and single or double sealed. The shielded are not sealed, they have protective metal shields, but no actual seal.
OD, ID, and width in metric is how they're done. I got all my wheel bearings for my Kawasakis at Fastenal.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 01-05-2015, 09:22 AM   #104
markk53
markk53's Avatar
Oddometer: 9,198
S.C.
I didn't see anything for the SRS, but 2RS means seals on both sides where RS and RSR only indicated seal on one side.
Here is a simple listing, there may be some brand differences, but this sums up the main points of code for bearings.
Mark - klx678
Old 01-06-2015, 06:19 PM   #105
scottcolbath
Oddometer: 7,149
Rear cush hub bearing for my 2005 640.......$40 at Bearing Belt and Chain in Phoenix. Brand and part number is JAF 5205-2RS.
S.C.
Times are GMT -7.   It's 02:33 PM.
