Old 05-01-2006, 01:48 PM   #1
Window_licker OP
n0b
Oddometer: 233
BT45's or Avon AM26's for the street?
As it looks like Im not going to be able to fit a 19" front to my 990 with ABS, i am looking for the best 21" for on-road only grip. Through plenty of digging the BT's and the Avons seem to get the best write-ups. Anyone tried both types, or give a subjective idea of improvement over the standard pirellis?
Cheers
Window_licker is offline   Reply With Quote
Old 05-01-2006, 03:27 PM   #2
jsrider
Oddometer: 3,495
Cheers
Personally I think the standard Pirelli's are pretty great on the road.
jsrider is offline   Reply With Quote
Old 05-01-2006, 09:56 PM   #3
KTMax
Ninth of the Nazgul
KTMax's Avatar
Oddometer: 1,099
BT45's is the stickiest tire available in 21' Lloyd... Availability of a BT45 rear seems a problem in Europe. The Avon Roadrider is fairly new so not much info around on these yet.
But you haven't riden your own 990 yet I believe so I'd say give the stock Scorpions a good go first. They're good.
690 SMR
Pics & info @ MonoManiacs
KTMax is offline   Reply With Quote
Old 05-02-2006, 11:39 AM   #4
Window_licker OP
n0b
Oddometer: 233
Richard
The Scorpions were good, but might as well go for as much grip as possible on those bicycle rims . Will change after my first service, UK winter is fast approaching
Old 06-29-2006, 01:21 PM   #5
Window_licker OP
n0b
Oddometer: 233
Quick update on the 21" wheel street rubber:
The Avon Roadrider Am26 front is superb, far superior than the oe pirelli's in the dry and especially the wet. Steering is slightly heavier , giving a more confidence inspiring feel of grip. The profile does seem slightly lower but I have not encountered any adverse handling or stability effects
Avon have told me the matching rear is due very shortly ( about july 06) so will give a further report when its fitted.
Overall, for my 990 the Avon is the road tyre to fit
Old 06-29-2006, 03:02 PM   #6
bLaCk 8east
bLaCk 8east's Avatar
Oddometer: 302
Those Avons are great - great grip. What are you currently running on the rear with the front avon ?
Go n-ithe an diabhal do chuid calóga arbhair.
bLaCk 8east is offline   Reply With Quote
Old 06-30-2006, 02:21 AM   #7
Window_licker OP
n0b
Oddometer: 233
The standard Pirelli. The rear actually feels ok at the moment, but It would be nice if I noticed some improvement with an Avon rear
Old 06-30-2006, 02:34 AM   #8
bLaCk 8east
Oddometer: 302
Interested to know how they will hold up over time. The Avons - from what I can remember, would seem a bit softer than than the scorpions so might not last as long. Might try all avons next time if they release the rear.
Cheers.
Old 02-17-2007, 06:07 PM   #9
rmaudsley
'05 KTM 950 ADV
Oddometer: 143
how many miles are the Avon AM26's lasting ?
rmaudsley is offline   Reply With Quote
Old 02-17-2007, 07:30 PM   #10
codys
Lost in the Vizcaino
codys's Avatar
Oddometer: 1,204
+1 on the pirelli scorps (stockers). I ran the bt-45's last fall . They lasted only 3k with the bike moderately loaded with a good bit of high speed across southern Nevada.The Pirelli's on the way back held up nice with quite a bit of the same conditions. THe Bt's just don't have near the starting tread depth. THe grip was fine though on the bt-45's on highway 1 and mt. st. Helens Rd. I'm gonna use the pirelli's for future road trips.
05 ktm 950 adventure
11 Husqvarna TE630
codys is offline   Reply With Quote
Old 02-17-2007, 08:01 PM   #11
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 908
The AM26 roadriders are holding up great on my 950 - - - not sure if I will spend the bucks for the 19" front - - - unless I can find a killer deal!
They definitely do look skinny
Young at heart
'06 950 Adventure, '07 950 SuperMoto
'09 Versys (w/Woodys Adventure wheels)
mcmann is offline   Reply With Quote
Old 02-18-2007, 12:07 AM   #12
spsduc
spsduc
spsduc's Avatar
Oddometer: 97
I agree, I was going to do a 17" setup for my 990s, but I have just done a track day on the std scorpions and was very impressed. They got a bit squirmy when really pushed, but you shouldn't be going that hard on the road anyway!!! Apparently I was leaving black lines behind me on some of the corner exits! It wasn't spinning up as such, just laying done a bit of rubber. Very predictable. For serious track work obviously road tyres would be better, but for the road scorps are fine.
I have just scored a spare set of std wheels, which I will probably put a 606/ 908rr combo on for real adventuring and leave scorpians on the other wheels.
I have attached a photo of the rear tyre.
Cheers,
spsduc is offline   Reply With Quote
Old 02-18-2007, 12:13 AM   #13
spsduc
spsduc
spsduc's Avatar
Oddometer: 97
Cheers,
And the front.
Old 02-18-2007, 01:08 AM   #14
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 649
Send a message via Skype™ to Dotbond
And the front.
I was there. These pictures are for real. The show off was cruising past KTM525's on the straight at Levels Raceway sitting bolt upright tooting his horn!
But his ute driving skilz are questionable! :)
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Old 02-18-2007, 04:00 AM   #15
coyote
scratch & sniff
coyote's Avatar
Oddometer: 21,910
I get ~6000 miles on mine; the front would go farther, but the rear goes away.
I did 8500 on the originals Scorpions, but I feel the reduction in mileage is well worth the cost in added road grip and stability. The Scorpion front felt vague, at times wanting to tuck on roads that had the tar worked to the surface (think roads in Nevada). I have not experienced this with the Avons.
The most radical revolutionary will become a conservative the day after the revolution.
coyote is online now   Reply With Quote
Times are GMT -7.   It's 04:46 AM.
