Old 05-01-2006, 10:36 PM   #1
Wayne Weber OP
why are we stopping?
Oddometer: 3,855
My custom Jesse Mounting system
I designed and fabricated my own Jesse mounts, which, I think look nicer and solve some other problems as well.
I just cut part of the main bar from the Jesse mounts, since I was in a hurry at the time (last year right before vacation!)...but the rest of the contruction is 4130 Crmo tubing.
There is some rust since I just spray painted them. I'll powder coat them when time allows. Note that I replaced the passenger grab rail. The new one is 7/8" diameter, and spaced out further so my wifes fingers don't get pinched, which is a big problem on the stock grab rail.
One more pic, showing the grab rail better:
The jesses rub the side panels a little, but I don't mind. It's about 34" wide with 8" bags, the same as the bars more or less.
The rear curve is a great push bar, and pick up point for when you fall...and you will fall, you will fall!!!!
That is all....
Wayne
04 KTM 950 S
93 KTM 550
93 XT225 Adventure Serow!
00 Weber Rally Twin (www.rallytwin.com)
Gas Gas 270
2 Waterbuffalo's (Sold!)
Wayne Weber is offline   Reply With Quote
Old 05-02-2006, 05:56 AM   #2
FastEddieB
FastEddieB's Avatar
Oddometer: 638
Good job!
Do the bags have a lower support point?
That was an issue on my airhead GS - it bent inwards on about the second or third day of my Baja trip - you can see the shiny spot on the rear drive where it started to rub.
Coco fabricated a reinforcing plate for me and hammered the mount straight on an anvil.
FastEddieB is offline   Reply With Quote
Old 05-02-2006, 09:24 AM   #3
Wayne Weber OP
Oddometer: 3,855
yes, the lower mount is a plastic piece, bolted to the bags, that clips to the long diagonal tube, behind the passenger foot peg.
Wayne
04 KTM 950 S
93 KTM 550
Gas Gas 270
Old 05-02-2006, 09:44 AM   #4
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 75,068
jesses and baja don't mix, the downward force from hitting the woops was enough to bend mine down, the left was so bad the swingarm was hitting the bottom of the bag..
i'll have soft luggage next time i go to MX.
my jesses will be relegated to commmuting.
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
My Wanderlust
Misery Goat is offline   Reply With Quote
Old 05-02-2006, 01:34 PM   #5
Pointman0853
Unregistered Gun Owner
Pointman0853's Avatar
Oddometer: 1,394
Alternative to powder coating
Wayne,
May I suggest you consider the following. Have the mounts Zinc coated, then finished with Krylon. The zinc is sacrificial. They will never rust. If they get scraped up, just touch them up with more krylon. Powder coating will scratch off, then rust forms underneath and you'll get a mess again!
I learned this trick building off-road bits for Land Rovers....
Pointman
AMA Life Member 600475
IBA #5
CarsonTahoeAdventureMoto.com
Pointman0853 is offline   Reply With Quote
Times are GMT -7.   It's 11:45 PM.
