Old 07-09-2008, 06:28 PM   #15076
hammockman
Always Lost!
hammockman's Avatar
Oddometer: 125
I'm looking into those crampbusters
A friend of mine recommended the crampbuster for long distance riding but I'm trying to find out what size to order.
hammockman is offline   Reply With Quote
Old 07-09-2008, 06:40 PM   #15077
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
I just got the bog standard ScottOiler one.
NordieBoy is offline   Reply With Quote
Old 07-09-2008, 06:47 PM   #15078
Errandboy
Oddometer: 21
I just bought a new ‘07 DR650SE and am getting ready for the 600 mile oil change. The parts guy at the dealer sold me two drain plug gaskets and said I should drain the engine sump and the other plug (also on the crankcase) drains the oil filter housing or the oil radiator, he wasn’t sure which. I have the Suzuki factory service manual and they only talk about the one drain plug in the changing the oil instructions. I’ve noted on these boards people complaining that the crankcase is over-filled when they put in the Suzuki-prescribed quantity of oil and you should only put in two quarts to keep from over-filling. Could it be the over-filling occurs because not all the oil was drained when pulling only the single plug? Should I follow the manual’s directions or the parts guy’s? If you pull both plugs, any danger of losing the prime in the oilpump with subsequent disasterous results?
Also: Is Dual-Star still in business? I’ve tried calling them for two days to order a skid plate and center stand; keep getting a recording that says they’re either closed or too busy to talk to me, leave a message, then the recording says the mail box is full, can’t leave a message, call later. Have called later for two days now, is getting tiresome. Is this typical of their customer interfacing? Any comments on their center stand and skid plate also appreciated. Thanks for your help in getting this old timer off to a good start with his new toy.
Errandboy is offline   Reply With Quote
Old 07-09-2008, 07:18 PM   #15079
stvbeck
Oddometer: 18
Cruise Control
Originally Posted by rallyhound
Can anybody here tell me which throttle lock type cruise control works on my 2003 650?
Vista Cruise 7/8" Universal. I bought the wrong one the first time (single/dual cable) and could not make it work. I installed mine last week and have used it for 600 miles. Works great.
Regarding the cramp buster. I've used the large one 6000 miles (before the cruise control). No interference with my pro-bend guards.
stvbeck is offline   Reply With Quote
Old 07-09-2008, 07:35 PM   #15080
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
One is for the sump. To drain the oil. Did you get an oil filter?
The second is for the timing mark cover - you use it to set the engine position so you can adjust the valves.
I reused the old gaskets .. I keep 4 spare new ones (amonst other things like oil filterS, etc) ... take a look at them when they come off the bike and see if you can trust them again.
Dual-Star scenter stand
Unobtainium. Don't bother. As in not avalible for the last few years, not likely to be avalible ever? Try SWMototeck (IIRC).
Frank Warner is offline   Reply With Quote
Old 07-09-2008, 07:38 PM   #15081
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
I had the same luck when trying to call Dual Star a few months ago. Keep trying, you will get thru eventually. The products they produce are generally good quality, but their customer relations leave a lot to be desired. They have a reputation for listing items online and taking orders for things they don't have on hand. They will take your money, then place you on a waiting list until they have enough orders in from others to manufacture a batch. If it were me, I'd call and confirm that the item wanted is in stock BEFORE sending them a dime.
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 07-09-2008, 07:39 PM   #15082
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
Twisted Throttle carries that one, IIRC...
Old 07-09-2008, 07:47 PM   #15083
exboomer
exboomer's Avatar
Oddometer: 91
I would perform the oil & filter change just like it states in the Suzuki service manual. If your bike is under factory warranty, follow the manual. As for Dual Star, I have heard bad things about their customer service or lack of. I bought a center stand from Twisted Throttle (SW Motech). Very happy with it. Good luck with your DR
exboomer is offline   Reply With Quote
Old 07-09-2008, 08:05 PM   #15084
Errandboy
Oddometer: 21
Thanks for the replies. Guess I'll go for the Motek stand, maybe a Utah Sport skid plate. (I got the oil filter.) It's great that you guys save people from re-inventing the wheel.
Old 07-09-2008, 08:27 PM   #15085
bumpathump
Oddometer: 328
Errand -
Geez. That's a no-brainer. I agree with others who say follow the service manual's instructions. And it does not matter if the bike is under warranty or not.
Regarding the aluminum sump gasket, I have never replaced one. Probably should, but I just haven't gotten around to it. Do not overtighten the sump plug, and you should be fine.
Rick
bumpathump is offline   Reply With Quote
Old 07-09-2008, 08:33 PM   #15086
bumpathump
Oddometer: 328
Rally -
I have an NEP throttle lock on my 2003 DR650. Works great but took some fabrication to make it fit.
I don't leave home with it :-).
Rick
Old 07-09-2008, 08:38 PM   #15087
KTMRyder
throttle jockey
KTMRyder's Avatar
Oddometer: 3,819
I have the Utah Sport skidplate on my 06.
kind of a pain to mount intially but it has a slot for the drain plug so you shouldn't need to remove it too much.
very solid well built piece that looks like it will hold up to a lot of abuse.
Heading out to ride the Continental Divide from Colorado north to the Canadian border on Saturday.
stay tuned, I will post in Ride Reports when we get back in a couple of weeks.
IBA # 38521
KTMRyder is offline   Reply With Quote
Old 07-09-2008, 09:39 PM   #15088
Pickled Amnesiac
ex Fishbulb....
Pickled Amnesiac's Avatar
Oddometer: 1,251
Wicked
Originally Posted by DevilofSky
hey guys...
i'm in italy... do you know where i can find a cheap side racks for my dr... posted 2pages ago... 190$ are too much...
here ya go...
they are just aluminium so they are light...
i held them on with hose clamps and they held up just fine for 30,000km
fish
EDIT: they cost 10$ australian, about 23 eurocents..... lol
Soaked to the skin, chilled to the core but alive. I left a puddle at the hotel desk as I checked in … this is how adventures end … not with a bang but a puddle on the carpet!...
SkyRiderman.....11,000 km in the aussie desert
Pickled Amnesiac is offline   Reply With Quote
Old 07-10-2008, 02:43 AM   #15089
DevilofSky
DevilofSky's Avatar
Oddometer: 78
Originally Posted by fishbulb
here ya go...
fish
Sorry! have you a photo "zoomed"? so i can understand better...
but there you can claps a bag?
Just an italian guy
DevilofSky is offline   Reply With Quote
Old 07-10-2008, 04:19 AM   #15090
DRjoe
DRjoe's Avatar
Oddometer: 5,256
Dose any one know of a source thats cheaper than suzuki for throttle cables for the dr
thanks in advance for any help
Joe
Times are GMT -7.   It's 07:49 PM.
