Old 11-09-2011, 02:50 PM   #56596
Rumlover
Ed
Oddometer: 707
Originally Posted by ER70S-2 View Post
I got it. I'd bet he got it.
Thanks, sometimes my sense of humor gets me in trouble
Rumlover is offline   Reply With Quote
Old 11-09-2011, 02:55 PM   #56597
shu
Oddometer: 1,053
Originally Posted by Rumlover View Post
shu,
You know I was kidding (with my "surely you jest" comment) -- right?
I have always appreciated your input and found it very helpful.
The internet is not the greatest sometimes (at least for me) for getting across what I mean.
Not offended in the least. Now back to carbs and F/A screws.
thanks..................shu
shu is online now   Reply With Quote
Old 11-09-2011, 02:59 PM   #56598
Harpua
formerly josdavlar
Harpua's Avatar
Oddometer: 166
Originally Posted by alansz400 View Post
I was riding home last night after dark and looked at my header after going up a long hill it was glowing red. Has anyone else ever noticed theres doing that? Alan
non-issue. been discussed before... tho a common mod is to remove the header and grind down a big fat weld that's inside that tends to hang onto heat.
Harpua is offline   Reply With Quote
Old 11-09-2011, 03:11 PM   #56599
Rumlover
Ed
Oddometer: 707
Old 11-09-2011, 03:17 PM   #56600
ER70S-2
ER70S-2's Avatar
Oddometer: 6,936
Thanks, sometimes my sense of humor gets me in trouble.
It's not your sense of humor that's a problem, it's those without one.
Are your PMs off intentionally?
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 11-09-2011, 03:31 PM   #56601
GISdood
GISdood's Avatar
Oddometer: 857
Originally Posted by 996DL View Post
How about letting us know the conditions of the old valve guide seals and whether your top end freshen up, cleared up the start up blue smoke and minimal oil consumption ?
Nice to hear you took it upon yourself, to work on the bike the 2nd time around.
996DL
The old seals I took out didn't appear to be worn, degraded or cracked (sorry, didn't take photos as I was too busy referring to the repair manual diagrams - I may have them in a baggie at home still and will post photos if I can find them), but the rubber on them definitely felt hard and brittle compared to the new seals. Once it was all buttoned back up and broken in, there was no sign of blue smoke or smell of burning oil anymore.
Being that the rings only had about 25,000km on them when the top end came off for the second time, I doubt that they were the source of the burnt oil smell on startup, especially when considering that oil consumption was next to nothing.
My guess was that it was just a case of the seals hardening up over the years of cold winter storage. Several weeks of -30 to -40 celsius throughout the winter are not at all uncommon where I live, and the bike spends its winters in an unheated storage shed on my property. I can't imagine those kind of temperatures being too kind to seals of any sort over time.
GISdood is offline   Reply With Quote
Old 11-09-2011, 04:03 PM   #56602
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,145
Originally Posted by Stringer99 View Post
thanks guys. looks like i have a paper gasket :( and my head gasket is leaking ...
debating a JE high comp piston vs just gasket replacement. is it advisable/worth it to run the JE without a new cam? Can a newb install it, including the cylinder wall deglaze? And finally, what is the process to remove old gasket material without damage?
The tab is a rivit holding the metal layers of the gasket together. Paper wouldn't have it.
Also, check your cam chain tensioner for the leak. Many here have had it leak and mine just started after 19K miles. Is making a nice moist area around the base gasket for dirt to stick to!!
Mongle is offline   Reply With Quote
Old 11-09-2011, 04:40 PM   #56603
procycle
procycle's Avatar
Oddometer: 2,407
Originally Posted by c2c4c View Post
I have the same setup your employee has - cut box and stock exhaust. I have your kit installed with the suggested jet/needle position for cut airbox (don't know what the exact figures are but I went by your included suggestions). Pulls hard but has that off idle bog and low speed surging. Screw 2.5 turns out. What should I play with the dial it in? Needle position? Main jet? Pilot jet? Fuel screw?
I'm contemplating just ditching the stocker and going with your pumper....but the wallet is not fat enough at this time....
At 2.5 turns the idle mixture screw is probably too far out. Most riders are reporting about 1 turn out will clean up the off idle bog. To cure the low speed surging you might try lowering the clip (raising the needle) one position. Only make one change at a time, then test ride.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 11-09-2011, 05:44 PM   #56604
996DL
Buell me
Oddometer: 2,333
I doubt the original valve guide seals, were at all affected by our brutal Canadian winter's temps, normally it's strictly just heat related degradation and possibly oil breakdown can play a role as well. Your region is an offroad paradise and while I know you tour considerably, high heat offroading by yourself or the previous owner, will accelerate the wear life of these items as well...
What was your approach with reringing your DR, did you leave the cylinder's finish untouched, or lightly deglaze the nikasil surface ? And finally, have you rejetted the bike, to alleviate the supposed oem lean condition ?
Thanks for your, as always, considerable positive input to this thread / site, GISdood !
996DL
996DL is online now   Reply With Quote
Old 11-09-2011, 06:27 PM   #56605
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Originally Posted by motolab View Post
The graph you posted looks like it's from wide open throttle runs, correct? If so, how does it pertain to the pilot jet and pilot air bleed sizes, which affect predominantly 1/16 to 1/8 throttle openings?
Regards,
Derek
No idea. Looks good though
I adjusted the pilot and pilot-air to be the same ratios the 640 uses (but still smaller than those ones). Seemed to help down low, without introducing any negatives.
Of course, since the mx_rob kitted FCR39MX went in last August, I would never willingly go back to a CV carb
NordieBoy is offline   Reply With Quote
Old 11-09-2011, 08:07 PM   #56606
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,437
FI is great. The existing maps may not be perfect, but unlike a carbureted bike, with FI at least the possibility exists to make the mixture correct at every intersection of throttle position and rpm. Because of the high resolution, it's potentially a lot of work, but you don't have to worry about overlap between circuits, gasoline spills or multiple disasemblies/reassemblies.
Regards,
Derek
I agree with this.
I had fuel injection on 3 different K model BMW's and they all performed flawlessly.
'00 BMW R1100RT, Gone away: 5 previous BMW's, 3 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is offline   Reply With Quote
Old 11-09-2011, 09:30 PM   #56607
ER70S-2
ER70S-2's Avatar
Oddometer: 6,936
More compression is good everywhere (with or with out a JE cam), except for maybe the gas pump. You might have to go up in octane, if it starts pinging.
If you're a garage guy with tools, probably.
I don't know.
Patience helps, don't start if you're in a hurry. Permatex makes a gasket remover, I used it when my clutch cover gasket broke, doing the NSU screws. It was really slow, I didn't use a metal scraper. EDIT: I've heard of some using the 3M fiber wheels on an air grinder, but those will turn high rpm and could do damage if you press too hard. Never use 3M fiber wheels, see following posts.
If that's true, there should be another rivet. And there is, left rear corner; smaller and harder to see.
2013 WR250R
ER70S-2 screwed with this post 11-10-2011 at 09:15 AM
Old 11-10-2011, 05:10 AM   #56608
Paddle007
Oddometer: 302
Never use those fiber wheels around an open engine. The material, aluminum oxide? , which flies off the wheel is extremely small and impossible to remove from your engine. Major automotive manufacturers have bulletins explaing the problem. They also are too abrasive. You will not have a flat surface when your done. I know it's not alot of metal removed but the time saved is not worth it.
Paddle007 is offline   Reply With Quote
Old 11-10-2011, 05:41 AM   #56609
mslow
Faccia Brutta
mslow's Avatar
Oddometer: 523
520 Conversion
I did a search but either I suck at using the search tool or the search tool sucks.
Two questions
First, how do you search for a specific term? I've seen where you use quotes to indicate a specific term.
Second question, with the 520 conversion, are there additional spacers needed and if I'm going to a 46 tooth rear, should I get rid of the top roller. The rear shock has been resprung and revalved so the sag is dead on for off road set up.
pin it!
mslow is offline   Reply With Quote
Old 11-10-2011, 07:19 AM   #56610
procycle
procycle's Avatar
Oddometer: 2,407
Don't even consider it. I've seen dozens of cylinders and other parts ruined because some "mechanic" user an abrasive wheel to remove a gasket.
Times are GMT -7.   It's 07:22 PM.
