Old 11-09-2011, 08:44 AM   #56656
FatChance
Road Captain
FatChance's Avatar
Oddometer: 9,314
Originally Posted by shu View Post
I finally removed it and replaced it with a set screw because A FEW OF YOU have had problems and I didn't want to tempt fate, but I'm not convinced that it happens all that often.
"all that often" is a very relative way of looking at this, especially if it happens to you. The top roller broke off my first (2000) DR650 just once and that was often enough for me! When I bought my current (2005) DR650, I took it off as soon as I rode the bike home from the dealer. So, the top roller only broke off on 50% of my DR650s, at least so far.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance screwed with this post 11-09-2011 at 08:49 AM
FatChance is offline   Reply With Quote
Old 11-09-2011, 08:50 AM   #56657
JagLite
JagLite's Avatar
Oddometer: 598
Cool2 Winter Shocker!
Originally Posted by vorg View Post
Putting to gether an ADV group buy for the cogent shock upgrade.
Good chance to save $$ on the hard coat $45 instead of $125 if you go it on your own.
Chime in here: http://www.advrider.com/forums/showt...301968&page=24
Lets get started on the off season upgrades.
I missed out on the last group buy from Cogent because I didn't want to lose the use of my bike during our very short summer here in Alaska. But now is the time to do it. If anyone is thinking about upgrading to good suspension, consider doing it now. In the past, Rick at Cogent has offered group buy prices during the slow time in Nov/Dec.
If you are unfamiliar with Cogent, read the thread linked above. Start at the beginning to read what is involved and what others who have bought them think of it. If you want to skip the history lesson, start on page 21 for the last group buy info:
http://www.advrider.com/forums/showt...301968&page=21
And you can go directly to Cogent's DR650 page for more:
http://www.motocd.com/cd/index.php?o...ucts&Itemid=66
There are many ways to go when improving the suspension and is one of the best cost/benefits available according to those who have done it. There are less expensive options and I usually go that route. Then I spend more money going with what I should have in the beginning...
Chime in if you are interested and add your name on at the end of the thread above.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 11-09-2011, 08:58 AM   #56658
tobster9
Sky larker
tobster9's Avatar
Oddometer: 113
Question torque
can someone please dig up the torque setting for the 2 14mm bolts either side of the spark plugs, i cant find it anywhere, got a small leak and scrabbling around to get my sh*t together before death valley tmrw,
thanks
with sufficient thrust pigs fly just fine
tobster9 is offline   Reply With Quote
Old 11-09-2011, 09:29 AM   #56659
996DL
Buell me
Oddometer: 2,020
Originally Posted by GISdood View Post
I'd been experiencing the same blue smoke on cold starts that others were describing, but it went away after the bike warmed up and my overall oil consumption was negligible. Figured it had to be old, tired, hardened valve seals. I ordered the top end gasket/seal kit from ProCycle (along with a pile of other bike goodies, like new rings from my local dealer) and proceeded to take the engine out of the frame and strip the rest of the bike down. The top end was once again taken apart and new piston rings installed as part of the process.
How about letting us know the conditions of the old valve guide seals and whether your top end freshen up, cleared up the start up blue smoke and minimal oil consumption ?
Nice to hear you took it upon yourself, to work on the bike the 2nd time around.
996DL
996DL is offline   Reply With Quote
Old 11-09-2011, 09:30 AM   #56660
Al Tuna
PUI Offender
Al Tuna's Avatar
Oddometer: 8,330
thanks
27.5 ft-lb
Southeast Weather Map
"I might as well keep going, there's no 'effing way I'm going back the way I came"
Moran Nation 21 Club.
Al Tuna screwed with this post 11-09-2011 at 09:57 AM
Al Tuna is online now   Reply With Quote
Old 11-09-2011, 09:31 AM   #56661
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 779
Eek
Originally Posted by procycle View Post
Once again, your carburetor setup is outside the norm. Most riders who have tried the 45 pilot have reported a 'rich bog' just off idle that couldn't be tuned out without going back the the stock 42.5 pilot jet. Most bikes will even exhibit the off idle bog just turning the mixture screw much beyond 1.5 turns.
now i realize that i'm not a parts re-seller so my experience is given without any agenda....but yeah, bike runs great, no bog, no issues, pulls like a freight train.
i can't believe you would argue that a +2.5 change (very small) in pilot jet would be too rich, but using the DJ ultra-thin needle is fine.
the pilot jet change pales in comparison to the amount of fuel added by the DJ jet needle.
2006 DR650SE, daily commuter + a StripleR
and a bunch of 2 strokes that you dont want to read about. :)
http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed screwed with this post 11-09-2011 at 09:44 AM Reason: wording re-worded.
vintagespeed is offline   Reply With Quote
Old 11-09-2011, 09:32 AM   #56662
tobster9
Sky larker
tobster9's Avatar
Oddometer: 113
Thumb
thanks Al, thats awesome
Old 11-09-2011, 09:41 AM   #56663
eakins
Butler Maps
eakins's Avatar
Oddometer: 14,431
thanks
cyl head bolt 27.5 ftlb (you can't do just the 2! there are 2 more under the head cover that also must be torqued, so you must remove the head cover, torque and have a new gasket to reseal it. apply torque in a criss-cross patern.)
cyl head cover 7 ftlb
it's all in the manual pdf from the image al posted.
base gasket leak? pre 2003? honestly you're in rush (sounds like it with your post demand) so i'd fix it when you're back.
Ozarks
, Nor Cal , COBDR shipping, AZBDR scouting
Facebook:
http://www.facebook.com/butlermaps
Old 11-09-2011, 09:43 AM   #56664
Al Tuna
PUI Offender
Al Tuna's Avatar
Oddometer: 8,330
You really should check all the cylinder head bolts, rather than torquing only two. Plus the leak may be coming from the valve cover and not the cylinder head gasket.
EDIT: eakins beat me to it.
manual pdf from the image al posted...
Al Tuna screwed with this post 11-09-2011 at 09:54 AM
Old 11-09-2011, 09:53 AM   #56665
JagLite
JagLite's Avatar
Oddometer: 598
Wink Save this link! Save PDF!
Originally Posted by JagLite View Post
I have been searching for hours over the past few days (really!) to find a post that listed stock fork sizes for common (dirt?) bikes.
I don't remember what thread, or even what forum I read it in....
I thought it was in here though.
Does anyone recall seeing it?
AND, do you remember where you saw it?
It was a LONG post listing dozens, if not hundreds, of bikes by fork diameters.
I don't remember if it listed other dimensions, all I recall was diameters.
I have tried searching using every term I could think of and I am getting nowhere in any thread or forum.
Seems to me it was in a discussion of fork swapping...
Since this thread is one of my daily reads I have tried here as well as Thumpertalk and other DR650 sites.
One of those things that we read and think "that is really interesting and useful" and then forget to save it somewhere for when we want it.
Or maybe I am the only one who forgets everything...
Uh, never mind. Dumbhead finally thought to search on Google and instantly hit multiple sites with the chart....
Thank you for your time, now we may get back to the regular discussion of pilot jets: "to clean or not to clean, that is the question..."
For anyone who has a lousy memory like me, here is the original location (as far as I can tell) of the Fork Tube Listing I had searched for:
http://www.ohiocaferacers.com/
It is in the Tech Tips section.
They also have a chart of "Stock Steering Stem Sizes" which is also very helpful so you may want to save both of them.
I have saved the links, and saved a PDF file of each.
Next time I ask where this is, perhaps one of you fine people will remind me that I saved them....
The link I had remembered was actually this one:
http://scandalon.com/2009/06/motorcy...iameter-chart/
But it is nice to give recognition to the ones who actually put it together.
The All Balls website lists the bearing sizes for forks which is also very handy. With all three lists, you can figure out if what you plan will be feasible. Without breaking the bank for custom machine shop work.
Attitude ~
James
Old 11-09-2011, 10:08 AM   #56666
shu
Oddometer: 757
Originally Posted by Krusty ... View Post
He doesn't jest. And don't call him Shirley...
........shu
shu is offline   Reply With Quote
Old 11-09-2011, 10:10 AM   #56667
shu
Oddometer: 757
Good point.
It's kind of like medicine. Odds of 1 in a million for having a bad reaction to a drug or vaccine sounds good unless you happen to be the 'one'.
I guess that's why I finally removed my chain roller too.
...........shu
Old 11-09-2011, 10:33 AM   #56668
LexTalionis
Inciteful
LexTalionis's Avatar
Oddometer: 412
Originally Posted by Fire Escape View Post
Use a google search of this thread and you will find pictures and comments.
Short version is that if your chain tension isn't loose enough you can rip the upper chain roller and it's mounting point where it is attached to the frame right off the bike. If you remove it, your chain doesn't need to be adjusted as loose, which makes it one of those 'Catch 22' (does anyone still remember what that meant?) things.
As in all things DR, opinions vary and anecdotal evidence is always considered 'proof'. I took mine off. YMMV, enjoy the new toy!
Bruce
I know what it means, I read the book and watched the movie.
Lex
The older I get, the better I was.
LexTalionis is offline   Reply With Quote
Old 11-09-2011, 11:08 AM   #56669
procycle
procycle's Avatar
Oddometer: 1,607
No agenda here other than trying to contribute to everyone's general understanding. Just pointing out that the majority or DR owners won't be happy with a 45 pilot jet. Neither would they be happy with a cut open airbox and a shimmed needle. It worked for you so more power to you. Your bike responds differently than 99% of the other DRs. We do see this occasionally. On the other side of the balance is the bike ridden by one of my employees. He has a cut airbox but still has a stock exhaust. His bike wouldn't run properly until we set the DJ needle on the 5th position. That would be way too rich for 99% of other DRs but his bike ran great with that setup and got 53+mpg. Most other bikes with his setup would need the needle set at position #2. Go figure.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 11-09-2011, 11:47 AM   #56670
Stringer99
Oddometer: 183
Question
Is there any way to confirm visually (while bike is assembled) if you have a paper base gasket or a metal base gasket
Stringer99 is offline   Reply With Quote
Times are GMT -7.   It's 07:27 PM.
