Old 11-29-2011, 07:40 PM   #57406
nupit
Oddometer: 49
Spring rate
I purchased a 08 DR 650 the other day. Its stock except for some small dirtbagz side bags and a big parabellum windscreen ( soon to be in the flea market). I want to install stiffer springs front and rear. On the race tech website if I search for 225 lbs, it gives me rates of 8.3 rear and .70 fork. Does that seem correct? Seems like it will be stiff....any help would be appreciated ... thanks
nupit is offline   Reply With Quote
Old 11-29-2011, 07:44 PM   #57407
ShadyRascal
Master of None
ShadyRascal's Avatar
Oddometer: 6,857
Call Jesse at Kientech. He'll ask your weight and details, and recommend the correct springs. Good guy and tell him Steve from Hamilton sent you.
Originally Posted by Javarilla
Evolution, or, natural selection, has nothing to do with better.
It merely weeds out what is no longer suitable for the given context.
Originally Posted by Dragoon
I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle.
ShadyRascal is offline   Reply With Quote
Old 11-29-2011, 07:45 PM   #57408
nupit
Oddometer: 49
Thanks for the info...I'll do that
Old 11-29-2011, 08:44 PM   #57409
vicster
Oddometer: 1,135
I'm 227# nekkid. I went with the Race Tech rebuild rear shock kit with 8.6 rear spring - love it! I tried Iniminators with .05 springs in the front. Worked really well loaded for touring on rough pavement. Didn't work for me without the touring load on pavement and didn't work on rocky off road. Too stiff. I've since gone back to stock springs and Intiminators. That combo works well on the pavement and rough rocky offroad. The .05 may work for high speed jumps,etc., but not in my real world.
YMMV
vicster is offline   Reply With Quote
Old 11-29-2011, 08:51 PM   #57410
Mercenary
Mindless Savage
Mercenary's Avatar
Oddometer: 1,017
Man....should start a weight loss thread.....
I'm WELL north of 300 with all the gear and the suspension upgrade is next on the list after the seat. What can I do to my stock suspension right now to prevent it from bottoming out terribly and have it handle somewhat decently on the road? I fully realise that I won't get any high performance out of the stock suspension but some tips for the mean time would be greatly appreciated.....
2015 DR 650
We can handle it....We're Canadian
Mercenary is offline   Reply With Quote
Old 11-29-2011, 11:25 PM   #57411
Garak
Cardassian Spy
Garak's Avatar
Oddometer: 266
With the stock suspension, there probably isn't a lot you can do to avoid bottoming. You can crank up preload, which will raise your ride height, but if the spring rate is too soft, it's too soft and you'll bottom all the same. That having been said, springs are pretty cheap (< $250 all around), and easy to install.
Across the country on the kindness of strangers and the strangeness of friends (and a DR650).
My LinkedIn Profile
Garak screwed with this post 11-30-2011 at 12:40 PM Reason: spelling
Garak is offline   Reply With Quote
Old 11-29-2011, 11:29 PM   #57412
ER70S-2
ER70S-2's Avatar
Oddometer: 7,224
Newride:
Just gently remove that bearing, like you were going to change it. Don't remove it completely, just until what's remaining of the old seal falls out and you can gently tap the bearing back in. And you won't damage the seal on the bearing.
If you didn't know how to change the bearings, now would be a good time to learn.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 11-30-2011, 03:01 AM   #57413
greer
Oddometer: 3,855
Regarding the Procycle stator
Originally Posted by Paddle007 View Post
Mine should arrive any day. I'll let you know.
Any word yet? Thanks
Sarah
greer is online now   Reply With Quote
Old 11-30-2011, 03:17 AM   #57414
petie
Oddometer: 71
Originally Posted by procycle View Post
More likely a little bit of dirt or debris is stuck in the float valve.
My tm40 has just done the same thing. I drained the float and hooked it back up, still did it. Pulled the lost bowl off, lotsa crap, cleaned and hooked up and still did it! Flushed thefuel inlet with heaps of carby cleaner, lots of hit came out. Hooked back up and all ok! New bike to me, first mod is a fuel filter! Sounds like this is your problem to...?
Todays dogma is tomorrows dog shit.
petie is offline   Reply With Quote
Old 11-30-2011, 03:45 AM   #57415
newride
newride's Avatar
Oddometer: 704
Originally Posted by ER70S-2 View Post
Newride:
all good, got the metal seal out with no damage to bearing. Not going to get into messing with bearings this time around.
Thanks for all your help.
1975 BMW R90/6
My moto blog: http://jbloggie1.blogspot.com/
newride is offline   Reply With Quote
Old 11-30-2011, 04:27 AM   #57416
Reconstructed
Oddometer: 259
Reconstructed is offline   Reply With Quote
Old 11-30-2011, 05:39 AM   #57417
Stringer99
Oddometer: 183
Question
which is better for our stock motors, the NGK CR10 with single or dual electrodes? thanks.
Stringer99 is offline   Reply With Quote
Old 11-30-2011, 06:22 AM   #57418
mercenario27
mercenario27's Avatar
Oddometer: 61
Radios
A group of us decided to purchase radios and noone knows nothing about them. I was wondering if someone would point me in the right direction. Didnt want to talk to sale reps until I was schooled
1. not all of us have ton of cash to drop down on a headset.
2. wanted something compatible with other systems.
3. something the had decent range .
Current
1997 Suzuki DR650 & 2006 Honda CB900F 919 Hornet
Gone
1996 Suzuki GSF750 Kan.of.tuna & 1986 Honda VF700 Intercepter
mercenario27 is offline   Reply With Quote
Old 11-30-2011, 06:24 AM   #57419
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Agreed, Ill be going to Pep boys this week to get a fuel filter
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 11-30-2011, 07:11 AM   #57420
TrophyHunter
Oddometer: 2,300
Radios - Almost all of us in our local group that have radios, have the Baja Designs headset. It's not cheap, but it has a noise cancelling mic which is very important. You'll wanna smack the first person that gets a non-cancelling 'cause when they transmit, your ears won't be happy.
http://www.bajadesigns.com/ProductDe...t-Radio-System
http://www.eham.net/reviews/detail/5241 Yaesu VX-170
I don't understand much about the comms....so I asked the geeks I ride with who do. I bought what they had. Radios add a fun and safety factor to the ride. We put one in lead, one sweep & sometimes one mid-pack if the group is large enough.
'07 WR450 2013 HD Road King '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Times are GMT -7.   It's 05:27 AM.
