Old 12-19-2011, 03:29 PM   #58066
ADVBedouin
Rider
ADVBedouin's Avatar
Oddometer: 396
I'd just turn out the idle adjust screw 1 full turn & see if that solves your cold starts..
It was all mine needed, & it's easier than changing the fuel screw/enrichener setting...assuming you've already enrichened/turned out your fuel screw...
Originally Posted by Weldman View Post
too. Where's this mixture screw at?
Thanks.
ADVBedouin is offline   Reply With Quote
Old 12-19-2011, 03:36 PM   #58067
ADVBedouin
Rider
ADVBedouin's Avatar
Oddometer: 396
What happened to Moto-Sport Panniers??
Hi Gang, anyone know what's happened to Motosport Panniers..those nice silver or black auliminum ones Shu used on his epic journey??
They were located down in So Cal, I'd spoken with a guy named Ove last year, but now the website points to some dude's soft pannier site out of Colorado. Anyone know what gives?
Old 12-19-2011, 04:21 PM   #58068
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,288
they've always been in colorado? same company as dirtbagz.
they dropped the racks and hardbag line awhile back.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 12-19-2011, 04:26 PM   #58069
shu
Oddometer: 1,056
Epic Journey...
I can tell you, Bedouin. Sadly, no more Motosport Panniers.
The Colorado guy, Ed, was 1/2 the business. He's the same guy who makes Dirt Bagz and also owns Motogear Outlet with his wife ( great people to do business with). Anyway, Ed made the soft bags for Motosport Panniers.
Ove, the guy in California, had the machine shop and made the brackets and the metal panniers. The way I understand it Ove was 70+ years old and only doing it to keep busy and he decided this year that he'd had enough and closed the business down.
..................shu
shu is offline   Reply With Quote
Old 12-19-2011, 04:33 PM   #58070
shu
Oddometer: 1,056
Originally Posted by ER70S-2 View Post
There's a flush brass cap on the stock set-up, easy to see with a mirror. When I did mine, I removed the carb, but left the throttle cables attached (seemed easiest). You'll have to loosen the two carb clamps to twist the carb so you can drill a small hole in the plug (1/8" or thereabouts). Remember that there are two hoses on the right side of the carb that fit tightly, they'll resist letting the carb twist and it seems the throttle cables also hit the frame backbone. That's why I pulled the carb loose. Once you have the pilot hole drilled, use a small self tapping screw to pull the plug. It isn't in there very tight, mine twisted a little when the bit grabbed. Go gently, the fuel screw is right under the plug, 3/16" maybe.
Yes, mine had a brass plug in there as well. Mine was pretty tight but I used the same procedure to remove it: drill a little hole through it, twist a screw into the hole, grab the screw with some pliers and work the thing out. I took the carb off and did on my workbench though, I didn't want to take the chance of screwing things up because of bad position, bad light, loose work etc.
............shu
Old 12-19-2011, 05:18 PM   #58071
Weldman
Weldman's Avatar
Oddometer: 1,503
Well I'll try that first then
thanks!
Nawfick, Virginny
Weldman is offline   Reply With Quote
Old 12-19-2011, 05:45 PM   #58072
ER70S-2
ER70S-2's Avatar
Oddometer: 7,010
For others: this works because it lowers the carb slide in the bore, limiting airflow a bit. The increase in vacuum pulls more fuel through the pilot circuit, = richer for cold starts.
Hi Shu
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 12-19-2011, 05:59 PM   #58073
Rumlover
Ed
Oddometer: 707
Hi Shu
I think it actually closes the butterfly valve (or whatever you call it) a little more, but same affect as you stated.
Rumlover is offline   Reply With Quote
Old 12-19-2011, 06:03 PM   #58074
ER70S-2
ER70S-2's Avatar
Oddometer: 7,010
The damn devil and details, you are correct.
2013 WR250R
Old 12-19-2011, 06:12 PM   #58075
poppawheelie
poppawheelie's Avatar
Oddometer: 591
kobukan
Originally Posted by kobukan View Post
I'm looking for a standard length side stand. Bought a bike that was lowered and need to raise it back up. I posted in the flea market, but thought I'd ask here in case one of you guys lowered your bike and have one you might be willing to part with for a reasonable price.
PM'd you.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie is offline   Reply With Quote
Old 12-19-2011, 06:21 PM   #58076
Rumlover
Ed
Oddometer: 707
I agree, gets me more often then I care to remember.
Old 12-19-2011, 06:47 PM   #58077
ER70S-2
ER70S-2's Avatar
Oddometer: 7,010
2013 WR250R
Old 12-19-2011, 07:08 PM   #58078
poppawheelie
Oddometer: 591
Hi Shu
Jeeze, just build a fire under it and go! Worked on old Harleys with 50 weight oil
Old 12-19-2011, 07:53 PM   #58079
ER70S-2
ER70S-2's Avatar
Oddometer: 7,010
Like this??
2013 WR250R
Old 12-19-2011, 09:47 PM   #58080
shu
Oddometer: 1,056
Used to go skiing with a guy who drove an old Fiat. After a day of skiing we'd have to crawl underneath and light a camping stove under the oil pan for about 15 minutes before that thing would start.
My DR starts well in the cold. I stick it in 3 or 4 th gear first, and roll it forward just a bit to get the metal bits moving. Then gas on, full choke, clutch in and no throttle. Crank it over with the starter motor- let it turn over twice. Turn the key off and let it rest 5 seconds and crank it again. Starts right up. I do keep my battery on a tender at home and replace batteries as a wear item before they give me trouble.
When the temps are in the low 20's F*, I duct tape a piece of cardboard in front of my oil cooler. I don't think the motor ever really warms up otherwise.
..............shu
Times are GMT -7.   It's 01:14 PM.
