Old 12-27-2011, 12:47 AM   #58291
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,228
Good Center Stand
Originally Posted by shu View Post
If you like to have a centerstand (I do) it's the only one out there, as far as I know. It is not a great stand but it's ok. Note in the pic, I have 2 little blocks under the feet since it's really not tall enough. Also, I have strapped the stand to front wheel ( look close to the stand), since it sits so close to balance point that it's easy to knock off the stand when you're wiggling the rear wheel back on.
But it's not overly heavy (7 pounds) and makes chain and wheel maintenance easy. I'd buy another.
............shu
asurvivor quote: "How's it do in the mudd and really bumpy trails?"
Have had that centerstand on my 2006 DR for about 29K miles, including Dug Bar on the Snake River twice. Seems to hold up fine. Yes, it's a "little" short, so little blocks of wood, rocks or something is needed to get the rear wheel off the ground to turn the wheel (oiling chain etc). Have thought about welding some steel plates like snow shoes to spread the load and increase height... but not yet. Maybe even a little foot pedal to help in deploying the center stand.
Got my center stand from ProCycle just after getting the bike in 2008. See the picture.
Dave
smilin jack is offline   Reply With Quote
Old 12-27-2011, 01:07 AM   #58292
PHILinFRANCE
PHILinFRANCE's Avatar
Oddometer: 1,157
I find this works fine
I,M HERE FOR A GOOD TIME NOT ALONG TIME
PHILinFRANCE is offline   Reply With Quote
Old 12-27-2011, 01:30 AM   #58293
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,311
Originally Posted by dljocky View Post
Good day all,
I'm thinking of using the electrical plug above the headlight for wiring in my heated grips. They draw 16watts (1.33 amps) on high per grip. Does anyone know if this will be ok, ie, are these wires sufficient to power the grips without overheating, etc? Any advice is greatly appreciated. Do I need to run a relay or fuse if I can use this connecter? Thanks.
That plug is used on the European head lights with a small single pilot light/bulb.
My thoughts on high draw items is a direct feed from the battery via a switched relay avoids resistance and gives the maximum power to the item in question instead of via the stock loom protecting it also from high draw losses and overheating.
The item would then perform at its best.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 12-27-2011, 02:10 AM   #58294
dljocky
Oddometer: 861
Thanks, I appreciate your reply.
I guess that is what I'll do then.
dljocky is offline   Reply With Quote
Old 12-27-2011, 04:48 AM   #58295
jon_l
jon_l's Avatar
Oddometer: 3,144
Originally Posted by B1 View Post
which nuvi is that? my budget didnt allow for a decent gps so went for the garmin nuvi 1490t. the five inch screen is really easy to read, and its the cheapest model which allows programming of routes. works quite well offroad with the garmin topo maps. it ain't no zumo but for around $160 to $200 on ebay i'm not complaining.
Mine is a ~2007 Nuvi 200. Came mounted on a used DL650 I bought. Other than outdated maps, and reduced battery life due to age (10 minutes max without vehicle battery), it works perfectly.
Used it on the DL650, CBF1000, DR650, and in the car.
Sucks compared to a Zumo, Montana, Oregon, GPSMAP 60, or 62, 76, etc., since I can't do any route planning, but it allows me to wander around, turn down unknown roads, and then ask it for directions home. Also, to save locations so I can return again.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 12-27-2011, 04:54 AM   #58296
jon_l
jon_l's Avatar
Oddometer: 3,144
Originally Posted by Rasthomas View Post
This may sound crazy, but I tried the ram mount system and it worked well on the handlebars of my DR650. Well I have three other bikes and was taking off on the Tiger. Instead of getting a new ram mount, I cable tied the little mount that came with the 70 dollar Garmin to the accessory bar. 3000+ miles later and it still is holding solid. I am a big supporter of DIY projects. In this case I just happened to try it and it worked beyond my expectations.
Penny tech is great, and if it works for you . The only thing I bought twice is this:
The rest moves from bike to bike with a loosening of the thumb-turn.
CBF1000 & PCX150
Old 12-27-2011, 05:00 AM   #58297
greer
Oddometer: 3,765
Heated grips
Good info here:
http://www.thumpertalk.com/forum/sho...g+heated+grips
A neat trick for getting rid of the resistor, scroll down just a bit to read my post about the turn signal flasher:
http://www.advrider.com/forums/showthread.php?t=641249
Happy Wiring!
Sarah
greer is offline   Reply With Quote
Old 12-27-2011, 07:15 AM   #58298
dljocky
Oddometer: 861
re
Thanks. Great info!
Old 12-27-2011, 07:19 AM   #58299
jon_l
jon_l's Avatar
Oddometer: 3,144
Originally Posted by Weldman View Post
mom-in-law bought me a TomTom 1535 (5" screen) GPS "for your truck" for Xmas, but y'all know what I want to put it on .
Any mounts that are particularly good?
Not a close-up, but my cheap, Garmin Nuvi is visible above the tankbag. I already posted the RAM bits I use. Here is a photo I found of the GPS on the DR:
CBF1000 & PCX150
Old 12-27-2011, 08:54 AM   #58300
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,629
packable solution
http://www.advrider.com/forums/showthread.php?t=538235
http://www.advrider.com/forums/showthread.php?t=653387
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 12-27-2011, 09:21 AM   #58301
Weldman
Weldman's Avatar
Oddometer: 1,360
Thanks for the help
but the back of this Tom tom 1535 is a bit different from the Garmins, and also I couldn't find a cradle that would work for it. I've ended up by ordering a case-type mount that encloses the unit. Hope it works out O.K.
Thanks again.
Nawfick, Virginny
Weldman is offline   Reply With Quote
Old 12-27-2011, 09:28 AM   #58302
oldenuf
Oddometer: 462
center stand
If I were to load my DR up with racks, bags and all the weight of traveling with the comforts of home, I would go ahead and get a center stand. Once you have it so many things are a breeze.
Art
oldenuf is offline   Reply With Quote
Old 12-27-2011, 09:58 AM   #58303
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,629
need a quick swingarm bolt torque #
manual is on other computer
thnx
Alaska
Old 12-27-2011, 10:18 AM   #58304
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,969
thnx
55.5 lb-ft
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is online now   Reply With Quote
Old 12-27-2011, 10:29 AM   #58305
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,629
Originally Posted by vfr870 View Post
55.5 lb-ft
thankyou!
Alaska
Times are GMT -7.   It's 08:53 PM.
