Old 01-10-2012, 04:06 PM   #58831
luckychucky
luckychucky's Avatar
Oddometer: 1,394
Windshield
Your right on all accounts. I only get to die once. I hope it cuts my head clean off Seriously, most of my riding is within city limits. It's is a little awkward, but I can deal with it until the end. But, I do agree with you on all of your points. If I didn't have to change all the cables, I'd already have ape hangers right behind the windshield. I feel like the DR stock kinda rides like a mild cafe racer. I wear a full face helmet, maybe it will save me from some of the windshield damage. Hopefully. Very good points.
luckychucky is online now   Reply With Quote
Old 01-10-2012, 04:10 PM   #58832
neepuk
Such a drag...
neepuk's Avatar
Oddometer: 1,633
Thumb
Stay Lucky Chucky...
neepuk is offline   Reply With Quote
Old 01-10-2012, 04:19 PM   #58833
Kommando
Kommando's Avatar
Oddometer: 7,390
Originally Posted by asrvivor View Post
So I have been riding with my new FMF powerbomb and see that it gets much hotter (or so it appears) than what I was used to with the stock muffler. It scares me a little but runs purrrrrrfect and have seen a nice low end power increase. Not to mention wheelie heaven! So I was thinking about wrapping the muffler, but don't know if this will increase engine heat or not. As it stands now the vapor shows temps nearing 310 degrees when idling and when really on an uphill push for extended periods. What are some thoughts here about the wrap? Any ideas? Has anyone done this before with the same exhaust? Thanks in advance John
Did you replace the muffler, the header, or both?
If you've increased the flow, you now may be running leaner than you'd want. Running lean makes things hotter. If this is the case, tune your carb before messing with wrap.
Does the new header have a heatshield like the stock header?
Kommando is offline   Reply With Quote
Old 01-10-2012, 04:34 PM   #58834
Kommando
Kommando's Avatar
Oddometer: 7,390
Originally Posted by Dravintoad View Post
After doing a little research trying to find a Rotopax mounting options, I came across this and really like the way this has been mounted. Has anyone else done this? and/or Had any problems with this set-up? (passenger peg removed and rotopax mounted in its place)
I'd MUCH prefer an IMS or Safari tank to that. My IMS gets me around 250 miles/tank, and it doesn't get damaged WHEN I dump the DR. I can still haul a passenger with tank panniers and rear panniers on too. Filled with just 3.5gal, it's lighter than stock, and it's small enough that I don't notice having a bigger tank between my legs in the dirt.
The only real complaint I have about the IMS is trying to find a locking cap that vents well.
Old 01-10-2012, 04:35 PM   #58835
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,971
Originally Posted by JagLite View Post
I bought a nice new Yamaha R6 throttle tube as recommended by several riders.
It decreases the rotation required to go to full throttle.
I only was able to try it on a couple rides before winter arrived with lots of snow but I was pleased with the improvement.
However, while reinstalling my carb after doing the Procycle jet kit, I discovered the "quick throttle" does NOT open the carb fully. I mean that when the cable is tight I can still rotate the cam another 1/4" or so. Yes, the other (close) cable is loose, it is not stopping the throttle.
My guess is that I need to file away some of the plastic on the throttle tube that acts as the stop so that it will rotated more.
Has anyone else noticed this or have this problem? I don't remember reading of it before.
i believe your right. gotta whittle a bit i suppose. i have one as well, but havent used it yet.
plugeye is offline   Reply With Quote
Old 01-10-2012, 05:01 PM   #58836
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,460
Originally Posted by neepuk View Post
To each their own I guess but that thing looks like a throat cutting device waiting to happen IMO... Just too close to the rider's face.
You're going to have to ride through a puddle/pot-hole full of water of undetermined depth at some point even on many road rides... You're going to end up in a situation where the best course of action is going to be UP ON THE PEGS. At times the front end may even come up a little more abruptly than you'd thought it would... What I'm getting at it the fact that a windshield that close to the face could take an everyday, no big deal bump in the road surprise, and turn it in to a hard smack in the chin or neck that knock the rider right off the back or out cold. IMO a windshield on a DR should be out in front of the number plate or not there at all.
You can always take a wind shield off and stash it if the going gets rough or steep.
No big deal. I even use hard bags...
sagedrifter is offline   Reply With Quote
Old 01-10-2012, 05:11 PM   #58837
Aerocycle
Aerocycle's Avatar
Oddometer: 233
Sooo.... I went for a ride all over today, it was so nice out! I went up some pretty beat up logging roads and the bike did great! Especially considering I am 250lb suited up, and have stock suspension.
When I got home, I just happened to grab my rear sprocket and it has a little side to side play. Does that mean it's Cush rubber time? I have read a lot of you guys posting about them. I haven't touched the rear tire/sprocket since I bought the bike, I've just been maintaining the chain. So yay/nay? Cush Rubbers? Or something else? Or is a little side to side play okay....
2006 DR650
Oregon Tag-O-Rama
http://www.advrider.com/forums/showt...=752387&page=3
Aerocycle is offline   Reply With Quote
Old 01-10-2012, 05:25 PM   #58838
ER70S-2
ER70S-2's Avatar
Oddometer: 7,248
Yes. My question to you: is the one hole (arrow) ovaled on your Yamaha throttle tube? I didn't like the way the cable end fit in that hole and that's how I received it.
Thinking the plastic would be rubbery, lilke a fender, I intended to work the chisel in from the top first and then snip off the piece from the right. But, the plastic is really hard, and after a couple of taps with a mallet (from the top), the piece snapped off like glass. I'm lucky it broke about where I wanted. Point is, don't use a chisel. obtw: I put the tube back on the handlebar before using the chisel, I didn't want to break the tube itself.
fwiw: Note how much closer the cable ends are to the o.d. of the tube. That surface is what the throttle stops rest against (open, closed). If forced (hard bump or landing), the throttle might over rotate. I think it was Bkoz that mentioned it some time ago because it happened to him. His theory was discounted as unlikely, but I think it's possible. Since there is a push and pull cable, I'm thinking that untwisting the over-run stop, will be simple. If it happens, you'll know what's going on.
The Yamaha tube is on the left, stock on the right.
I really like the result of a quicker throttle. I don't have to drop my elbow for full throttle. This makes me faster out of every turn (safely, dammit), it gets me to WFO easily and without the rolling my hand forward on the grip frequently. This may only make me 5% faster, but it's effortless, no thinking about it. And my buddies won't have to wait as long. If I have to explain it, you wouldn't understand. Not you JagLite, you obviously get it.
And: the two screws holding the throttle tube are different lengths, the long one goes on top. I recommend stainles allen head replacements. They're 5 x .08 mm thread, one is 25mm and the other is 20mm long.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 01-11-2012 at 10:31 AM
ER70S-2 is offline   Reply With Quote
Old 01-10-2012, 05:36 PM   #58839
HiJincs
Dreamer
HiJincs's Avatar
Oddometer: 632
There's 3 bearings in the rear. Check you sprocket carrier bearing. They don't have a seal on the inside and are notorious for getting gunked up and failing.
I lost my entire swingarm when mine went.
"I am ill equipped in the philosophies of failure"
When I die, show no pity, send my soul to Juggalo City.
Dig my grave six feet deep and put two Sidi's on my feet.
Put some leather over my chest and tell my family I did my best!
HiJincs is offline   Reply With Quote
Old 01-10-2012, 06:49 PM   #58840
doug s.
Oddometer: 1,354
while my windscreen and headlight assembly are a little different than yours, they're wery similar - i see no reason why you couldn't mount your windscreen in front of, instead of behind the headlight assembly:
doug s.
doug s. is offline   Reply With Quote
Old 01-10-2012, 06:55 PM   #58841
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
HiJincs had some very bad luck. Man, that is nasty.
But I don't believe DR650 rear wheel bearings/Hubb are "notorious" for failing. In fact, very few reports of this here among the hundreds of DR's we hear about.
An Aussie guy or two have had them go ... and maybe a few more. Not really common from my dim memory over the last few years.
But if you have some "wiggle" on the sprocket, you should take a look and cop a feel on those bearings (3). I'm betting new Cush Rubbers would solve your problems 100%. Cush rubbers always seem to "look" normal. But I change them anyway and it really has helped. They only stay tight for 10K to 15K miles ... or so.
There is a reason Suzuki use open face wheel bearings. (open on one side) This allows them to be cleaned and re-packed. Sealed bearings don't allow this ... and once water or crud get in, you're sunk. Can you tell I just got a tutorial from my "bearing expert" neighbor? He sells grease for a major supplier to food service processors. Bearings and grease are his life. (former Chevron chemist)
His take:
If you clean (best you can) and re-grease your bearings at every tire change, most times you should be OK for many years. But always try to give them a good feel ... make sure they feel smooth, no roughness or looseness.
It's hard to get to the inner Hubb bearing. I use a "poker" to dab on a bit of fresh grease. Never over pack your bearings, don't go crazy.
There are always exceptions. Much depends on use.
Things that are hard on wheel/Hubb bearings:
1. Lots of river/stream crossings or beach riding.
2. Constant rain riding.
3, Heavy loads chugging over steep, rough ground, especially two up.
4. An over tight chain. NOTE: A heavy rider may be compressing the suspension enough to make chain TOO TIGHT ... Not good.* Tight chain is hard on the hubb bearing, countershaft bearing too.
*So have someone check chain slack with YOU on the bike, feet up. When you're off the bike the chain may appear a bit loose. No worries.
Old 01-10-2012, 07:14 PM   #58842
Paddle007
Oddometer: 303
Just replaced my rear wheel bearings. Approximately 12k miles. Very little water, not enough off road and I am pretty anal about proper chain adjustment. My cushions are getting hard and a little sloppy. Kind of questioned if lose cushions contribute to bearing failure. With only a single bearing in the hub it seems like a lot of load on it. I will replace my cushions everytime I replace my bearings FWIW, Just my two cents.
Paddle007 is offline   Reply With Quote
Old 01-10-2012, 07:22 PM   #58843
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,850
I see it was anwsered better in a post above.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is online now   Reply With Quote
Old 01-10-2012, 07:28 PM   #58844
keenerkeen
keenerkeen's Avatar
Oddometer: 77
You are kidding with that windshield, right?
must be kidding
keenerkeen is offline   Reply With Quote
Old 01-10-2012, 07:30 PM   #58845
gumbometer
hairy reasoner
gumbometer's Avatar
Oddometer: 36
GSXR x40f0x muffler
Originally Posted by nat_han View Post
Thanks...
Anyone knows of anywhere that i can find a used GSXR1k Muffler?
Tried Ebay but couldnt find anything there...
I ordered one from this place after reading about it on drriders.com (after scouring craigslist and ebay for a few months):
"For those looking for this pipe, here is a source that claims to be able to get them with realitive ease. It's where I got mine for $75 plus shipping.
M.I.D.S. Cycle Salvage
Sumter, SC
803-773-3535
ask for Shane
I have no connection to them other then the fact it's where I found mine. Just thought it might help anyone out that has been looking.
Dan"
http://drriders.com/topic2998.html
Shane was the one that answered when I called, and he seemed to have no shortage of those mufflers. He was aware that DR650 owners are looking for them, too.
Good luck -- I hope you find one!
gumbometer is offline   Reply With Quote
Times are GMT -7.   It's 09:34 AM.
