Old 01-10-2012, 07:28 PM   #58846
keenerkeen
keenerkeen's Avatar
Oddometer: 77
Originally Posted by neepuk View Post
You are kidding with that windshield, right?
must be kidding
keenerkeen is offline   Reply With Quote
Old 01-10-2012, 07:30 PM   #58847
gumbometer
hairy reasoner
gumbometer's Avatar
Oddometer: 36
GSXR x40f0x muffler
Originally Posted by nat_han View Post
Thanks...
Anyone knows of anywhere that i can find a used GSXR1k Muffler?
Tried Ebay but couldnt find anything there...
I ordered one from this place after reading about it on drriders.com (after scouring craigslist and ebay for a few months):
"For those looking for this pipe, here is a source that claims to be able to get them with realitive ease. It's where I got mine for $75 plus shipping.
M.I.D.S. Cycle Salvage
Sumter, SC
803-773-3535
ask for Shane
I have no connection to them other then the fact it's where I found mine. Just thought it might help anyone out that has been looking.
Dan"
http://drriders.com/topic2998.html
Shane was the one that answered when I called, and he seemed to have no shortage of those mufflers. He was aware that DR650 owners are looking for them, too.
Good luck -- I hope you find one!
gumbometer is offline   Reply With Quote
Old 01-10-2012, 07:34 PM   #58848
speedmaster
speedmaster's Avatar
Oddometer: 591
Originally Posted by asrvivor View Post
So I have been riding with my new FMF powerbomb and see that it gets much hotter (or so it appears) than what I was used to with the stock muffler. It scares me a little but runs purrrrrrfect and have seen a nice low end power increase. Not to mention wheelie heaven! So I was thinking about wrapping the muffler, but don't know if this will increase engine heat or not. As it stands now the vapor shows temps nearing 310 degrees when idling and when really on an uphill push for extended periods. What are some thoughts here about the wrap? Any ideas? Has anyone done this before with the same exhaust? Thanks in advance John
I don’t think wrapping the exhaust header would lower cylinder head temperatures. It might make the pipe feel cooler and seem cooler but the heat would have to be conducted through an additional medium versus the bare metal pipe.
My 2009 DR frequently runs at 300 and sometimes hits 320 at sustained revs on 80+ degree days. It would be interesting to hear from others who use a cylinder head temp gauge and have noted operating temperatures.
speedmaster is offline   Reply With Quote
Old 01-10-2012, 07:49 PM   #58849
keenerkeen
keenerkeen's Avatar
Oddometer: 77
could be dangerous ..mounting a bit far back for riding off road
keenerkeen screwed with this post 01-10-2012 at 07:59 PM
Old 01-10-2012, 08:30 PM   #58850
BergDonk
BergDonk's Avatar
Oddometer: 3,811
Originally Posted by Aerocycle View Post
Sooo.... I went for a ride all over today, it was so nice out! I went up some pretty beat up logging roads and the bike did great! Especially considering I am 250lb suited up, and have stock suspension.
When I got home, I just happened to grab my rear sprocket and it has a little side to side play. Does that mean it's Cush rubber time? I have read a lot of you guys posting about them. I haven't touched the rear tire/sprocket since I bought the bike, I've just been maintaining the chain. So yay/nay? Cush Rubbers? Or something else? Or is a little side to side play okay....
They are not unknown to fail, and it can be near catastrophic when they do. Not hard, or expensive, to change sooner rather than later.
http://www.advrider.com/forums/showt...9#post15720809
I ended up with a double row bearing that outlasts the original, but still got the wobbles after a while.
And IMHO rider weight is not a criteria for chain adjustment, its the alignment of the countershaft, swing arm pivot, and axle that determines the longest distance, and the chain needs to be adjusted accordingly. If a heavy rider is aboard and the swingarm sits above this line then the distance shortens. An over tight chain not only prematurely wears cs and wheel/cush bearings and the chain and sprockets, it compromises the suspension performance.
Steve
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is online now   Reply With Quote
Old 01-10-2012, 09:04 PM   #58851
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,815
Originally Posted by sagedrifter View Post
Among my friends who get terrible tread wear, they all use too much air pressure.
I stay around 22/25 psi in my tires. If I put 32 psi in the rear, I wouldn't make 3,000 on any tire. Been there, done that. If I run higher pressures up front the tire looks like a saw blade. Fully loaded, 24 psi works well in the front.
Too little or too much psi has a great impact on tread life. I hate changing tires, so I do run a 705 on the rear most of the time. Most of my friends run 36 psi on pavement and real low pressures off road.... They don't get good tread life either.
On my 07 FJR1300 I could wear out a Pilot Road in 4K if its all tight curves. The edges go quicker up in western NC. I just run them smooth some where between 5,500 to 5,800 front and rear. My buddy rides slower and never sees more than 4,200 on the same tire. Its all about being smooth and the amount of engine braking you use. Switch backs and rough roads like 80 in NC near Marion will kill a rear tire quick.
If your having fun, just burn them up. The only time a care about tire life is when I tour. I like to know how far I can go loaded up with camping gear. If I go out west to Utah or some thing like that, I run a 705 on the rear and some thing more aggressive out front. I can get 7K out there in the wide open spaces. Thats enough to get me home on one set of tires. The roads out west give better tread life, they must be rougher here in the SE. Or maybe its the tighter curves. I don't complain about curves....
I never run more then 25 on my 690 or 450. Usually around 15-20. Still get crap for tire life. Never over 1K miles on tires like Mt-21's, T-63's &49's, 756's etc. On the motard wheel set for the 690 I've tried as low as 24 and as high as 38 and tire life is the same, get about 1200-1300 miles out of a Diablo Corsa or Pilot Power.
Old 01-10-2012, 11:30 PM   #58852
eRRmmm
Oddometer: 576
I guess wheelspin on demand and regularly returning the front tyre to the ground has a negative effect on tyre life.
It's a good problem to have
eRRmmm is offline   Reply With Quote
Old 01-11-2012, 01:30 AM   #58853
nat_han
2 Wheelers By Choice.. =]
nat_han's Avatar
Oddometer: 200
Sumter, SC
803-773-3535
ask for Shane
Dan"
Thanks alot for your input!
Still finding...
The drriders.com doesnt have one for sale!
nat_han is offline   Reply With Quote
Old 01-11-2012, 02:34 AM   #58854
greer
Oddometer: 3,836
Nat,
I think Ken was suggesting you call Shane at M.I.D.S. Cycle Savage.
Sarah
greer is offline   Reply With Quote
Old 01-11-2012, 03:32 AM   #58855
nat_han
nat_han's Avatar
Oddometer: 200
Originally Posted by greer View Post
Nat,
Sarah
Hi Sarah!
I know that, but I'm not based in the USA...
Not too familiar on making overseas call!
If there were some sort of email link, maybe it will help... hmmm
Old 01-11-2012, 03:44 AM   #58856
greer
Oddometer: 3,836
Oh heck, sorry about that; fill out your profile!
Sarah
http://www.midscyclesalvage.com/
Old 01-11-2012, 06:05 AM   #58857
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,529
I just don't know how some of you guys do it. I mean I don't even get 3.5K miles out of a Pilot Road on my Strom. Never come close to 3K on ANY 50/50 dual sport tire I've ever tried. Never got 1.5K out of any knobbie. Now I just picked up a DR and even if I can get twice the milage on it that I get out of a tire on my 690 or my 450 EXC that still won't even come anywhere close to what you're getting
I get 1000-200miles from a rear knobby on my DR and about 2000 from the front. I run a Kenda 130/90-17 rear TrakMaster II and on the front a tire I feel no one seems to know about, but fantastic in the real slimy going: a Bridgestone ED-03
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-11-2012, 06:32 AM   #58858
ct-ktm
Oddometer: 3,351
Hey Russ..Can you or anybody..tell me if a smaller tail light will fit right into my stock fender..My blinkers or what is left of them need to be replaced ..is this stuff just plug and go..?...Getting reafy to go through the DR..been a loong season for that bike..
ct-ktm is offline   Reply With Quote
Old 01-11-2012, 06:48 AM   #58859
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,075
I know of one for sale on Craigslist. It's in Kenosha Wisconsin. I'll be in Kenosha Saturday morning for another reason. Here's the LINK. I think the asking price is a little high and there is some discussion, on DRRiders, that it may not be the 040 (titanium) version. However, the seller isn't sure of the model year. I could check it out to see what it really is. Perhaps the seller would take less since it still seems to be available. Let me know.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 01-11-2012, 07:05 AM   #58860
Rusty Rocket
Life behind "Bars"
Oddometer: 9,529
Check here:
http://www.kientech.com/DRZ250DR650TailLightConv.htm
This bolts right on using the same holes and wiring. It's form a DRZ250.
It's what I have. On mine, I still have the stock plate holder/plate light.
2009 DR650
Times are GMT -7.   It's 03:31 AM.
