01-19-2012, 07:18 PM
#59206 | |
almost gnarly
Oddometer: 1,472
'97 R1100GS, '99 DR350, '02 DR650, '03 DR650, '04 R1150RT A Few Days Solo to Copper Canyon A Maine Rider’s Arizona Day Trips A Few Days Solo in Baja |
01-19-2012, 07:43 PM
#59207 |
Oddometer: 3
Suspension Suggestions
The time has come to look into improving some of the factory suspension. I use the bike 50% street (getting to work) 50% adventure touring - camping, dirt biking, exploring old mine towns..etc. I weigh about 160lbs with riding gear and my touring luggage set up amounts to approx. 112lbs (ammo box home fabbed luggage system).
With no luggage the front suspension dives a lot under breaking and the rear at factory settings seems extra floaty...For dirt biking it feel like it rides like a Cadillac and frequently bottoms the front suspension out. please excuse my descriptions I’m not a suspension expert. When fully loaded I crank the rear spring to max preload and it still sags real bad. If you test the suspension by lifting a luggage box and release it, the rear shock will bounce a lot with little return dampening. It rids like a chopper a gets scary in a head wind. When riding rough backcountry roads i feel like its trying to kill me. Im looking for some advice on how to go about tweaking my suspension for a noticeable improvement. Im tossing around the idea of using some aftermarket parts from ProCycle, ie 8.3kg/mm rear spring and some .5kg/mm front springs with 10w fluid as a starting point. Has anyone used their front fork spring solution kit? How was the improvements? were they noticeable? Bellow is some pics of my rig for reference. Any help would be greatly appreciated. ![]() ![]()
01-19-2012, 08:04 PM
#59208 |
Oddometer: 531
Start with the front springs, for your light weight daily commute and also adventure touring you should look into the ProCycle Progressive springs. Possibly adding in an emulator.
For the rear I think the 8.3kg might be a bit too stiff when you are commuting. I'm personally 215lb (was 240 when ordered the spring, woo hoo Low Carb!) and have a 7.6kg spring and it feels perfect. Even when loaded up with another 50lb in gear for weekend camping trips. Stock spring is 6.5kg. Riders weight range / Spring rate recommended 150-180 lbs / 6.8 Kg/mm 180-215 lbs / 7.1 Kg/mm 215-225lbs / 7.4 Kg/mm 225-240Lbs / 7.6 KG/mm 230-260Lbs / 8.1 Kg/mm
97 Suzuki DR650 97 Ural Sportsman 2WD 98 Honda XR250R 83 Yamaha XT550 www.drriders.com |
01-19-2012, 08:31 PM
#59209 | |
Oddometer: 604
Shocking!
But once you have more spring, what small amount of damping there is will be totally gone. ![]() Depending on your budget, the fork solution kit from Procycle is an excellent way to go. I have had progressive rate springs in the past and I prefer straight rate. Progressives are softer initially for nice street riding, but they also allow more fork dive when braking. For the rear, it would be a waste of money to put on a stiffer spring when the shock needs a complete rebuild. Procycle offers various internals for the do-it-yourself route. I had my shock rebuilt by Cogent Dynamics because of their excellent shock reputation. Procycle, Cogent, and Keintech are all extremely helpful so give one or all off them a call and listen to their recommendations that are based on experience riding DR650's. Tell them your budget and they can help.
Attitude ~ The difference between Ordeal and Adventure James |
01-19-2012, 08:50 PM
#59210 | |
on the road o'dreams
Oddometer: 5,390
You can get heavier fork springs from any suspension shop but at your light weight ... I would not bother. Just try adding a 1/2" longer pre-load spacer (you can use PVC pipe), another inch of oil, use 10 wt. oil. This is the Poor Man's way to improve the front. You are so light, that should help the front quite a bit. The front will (and SHOULD) always dive a bit under braking. If it didn't it wouldn't work very well off road. With the added spacer length, more and heavier oil, you should see improvement and stop bottoming. If not? Go to heavier springs ... but be careful ... nothing worse then an over-sprung bike. Shock: This is a tougher problem. No easy fix for lack of rebound. Your shock is worn out ... or on the way out. Perhaps the best value is Cogent Dynamics. They can rebuild and re-spring your shock and transform your DR to the Magic Carpet bike. This ain't cheap. Just going to a heavier spring could actually make things worse. And for your weight 8.3 kg. may be a bit much ... even with your luggage. The main thing the stock shock lacks is adequate rebound damping. Alternatives here are to shop around for another shock that will suit the DR650. See: Ohlins, Penske, Wilber's, Hyperpro, Elka and many others. Not all currently make a unit for the DR650 ... but look around.
01-19-2012, 08:54 PM
#59211 | |
Oddometer: 1,656
Steve |
01-19-2012, 08:59 PM
#59212 |
Oddometer: 276
I did some research before buying it, and there a is a special charger that is better to use that balances the charge in each cell which is better for it, but you can use a regular charger. It also has a much slower discharge rate, so it can sit for a year without needing to be charged, assuming there is no draw, but I ride almost every day, so that shouldn't be an issue. I was a little hesitant to buy it at first since there aren't really any long term reviews, and I usually can't afford to be the guinea pig on fancy new products, but lithium batteries are being used in other applications with good results. I'll be sure to let everyone know if I have any issues.
01-19-2012, 10:15 PM
#59213 |
i like stuff
Oddometer: 4,319
hi guys, i was just changing the oil and noticed an oddity as the oil was coming out, it wasnt a smooth exit like most of my bikes, but it was spraying in a random circular motion. I thought maybe a peice of motor was stuck in the hole, so i put a screwdriver up there for a feel and felt some sort of filter/cover over the drain hole.
Is that normal? cheers
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..." |
01-19-2012, 11:21 PM
#59214 | |
Taumarunui..Darwin..
Oddometer: 2,110
I was under the impression that a normal charger that has a desulfating cycle for lead acid batteries was detrimental to the life of the Shorai ?
Edit. Quote:
Les .. 1968 Husqvarna MF250 and MF360 - 1971 Norton Commando Fastback - 1973 Kawasaki H2A - 1973 Ducati 750 GT - 1973 Moto Guzzi Eldorado - 1974 Kawasaki H2B - 1974 Triumph TR5T Trophy Trail - 1981 Ducati 900 SD - 1986 Husqvarna 400 WR - 1998 Suzuki TL1000S - 1998 Suzuki TL1000S - 2007 Ducati Hypermotard 1100S - 2008 Suzuki DR780. |
01-19-2012, 11:26 PM
#59215 |
Oddometer: 10
QUOTE=nat_han;17772022]I'm still on the lookout for the GSXR-1k Muffler!
If there's anyone going for a full system upgrade to FMF-Q4 pipe or other aftermarket brands and willing to part with yours, do let me know! Thanks![/QUOTE] Try EBay.uk they seem to have a few. Email them to see if they will ship to you. I got mine from there, sent to Australia and had it in about 7 days from the time the order was placed. http://www.ebay.co.uk/itm/SUZUKI-GSX...#ht_1425wt_689 Here's an example, sorry can't do the link yet. |
01-19-2012, 11:31 PM
#59216 | |
Oddometer: 276
http://www.shoraipower.com/t-faq.aspx Edit, Just saw your edit...heh. |
01-19-2012, 11:49 PM
#59217 | |
dougholck
Oddometer: 660
Stopped today at local Battery's Plus store where I get my Odyessy batteries to see if they carried the Shorai? Nope. Manager is a biker and said he's just not sure the product is proven yet but he has talked with Shorai. He has a buddy that runs the Shorai in his BMW K1300 and is having starting problems durring hot situations, which can be from weather or engine heat. Manager thinks Shorai great for guys who need to shed a few pounds for racing competition but not convinced the best for going out to the boondocks and hope it starts every time. Think I'll stick with Odyessy till reviews are in. Looks like the PC310 will fit my DR. |
01-20-2012, 12:53 AM
#59218 | |
finger lickin' good
Has anybody tried Ricor's rear shock?
Godspeed ![]() I'd rather do it than watch it. Those of you with spouse and SO's know this already, but man give them a big hug, and don't take anything foregranted. - MACK RIP When 51% of the grasshoppers vote, the ants are screwed. http://godspeed.smugmug.com/Motorcycles |
01-20-2012, 01:42 AM
#59219 | |
dirt dog
Oddometer: 720
01-20-2012, 03:18 AM
#59220 | |
Southern Ontario
Oddometer: 1,997
Stiffer, better suspension will help handling too of course, just suggesting a diet is also in order. Less weight would help engine performance and fuel economy, and in particular off-road performance. I suspect ammo cans could be dangerous to your legs in an off-road get-off. She'd be a lot easier to pick-up too .
jon_l screwed with this post 01-20-2012 at 10:48 AM |
