Old 03-10-2012, 05:14 AM   #61051
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,437
I have the PC oil plug since 2007, works fine. I use a torque wrench on it though, it doesn't take much to over tighten it.
Sent from my GT-S5690L using Tapatalk
sagedrifter is offline   Reply With Quote
Old 03-10-2012, 05:42 AM   #61052
jon_l
jon_l's Avatar
Oddometer: 3,268
stainless steel NSU screws OK? or galvanic reaction?
About to do my NSU screws. I ordered these M5 x 16 x .8 pitch:
An inmate alerted me to this possibility. Are 18-8 stainless steel NSU screws OK? Or do we need to worry about galvanic reaction? I assume they thread into aluminum.
If I hadn't already spent $13 for 2 screws (had to buy 50, + shipping), I'd switch to steel screws, but I'd prefer to use these if stainless steel is fine.
Based on some limited Googling, it seems an electrolyte such as salt is needed for the reaction, so in an enclosed, bathed in oil environment, maybe galvanic reaction not an issue?
Anecdotal evidence such as "I used stainless and my bike still runs" isn't terribly helpful. I am hoping for something a bit more scientific.
Thanks in advance.
Jon
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 03-10-2012, 05:52 AM   #61053
ride4321
ride4321's Avatar
Oddometer: 1,985
IMS tank with vented locking cap
Installing the IMS tank now and have a question on the vent line. I bought the locking vented cap from Procycle so I don't need to connect the vent hose to the cap. What do I do with the vent hose? Does it get capped off?
Don't you know there ain't no devil, it's just God when he's drunk.
Tom Waits
ride4321 is offline   Reply With Quote
Old 03-10-2012, 05:57 AM   #61054
sagedrifter
Southern Explorer
Oddometer: 1,437
Thread locker works fine on the NSU screws. No need to get complicated. Ok maybe add some star washers...
Don't crank down on them too much either, the sending unit is plastic. I recommend the Permatex Blue Gel threadlocker.
sagedrifter screwed with this post 03-10-2012 at 06:29 AM
Old 03-10-2012, 06:00 AM   #61055
sagedrifter
Southern Explorer
Oddometer: 1,437
Cap it off at the source.
Or put a bolt in it coverd in RTV and fold it over with a zip tie if you want...
The locking cap sucked on my bike, keep us posted on how well the cap vents and if it dumps fuel all over the tank. Mine did / does.
Old 03-10-2012, 06:04 AM   #61056
ride4321
ride4321's Avatar
Oddometer: 1,985
Thanks, that's what i was thinking. Just wanted to make sure.
Tom Waits
Old 03-10-2012, 06:06 AM   #61057
sagedrifter
Southern Explorer
Oddometer: 1,437
Originally Posted by farrell caesar View Post
SO I forgot the flat slide carb ! Dropped needle all the way down to get 45mpg with open air box. Oh it's got power tambien.
I usually get 50 to 51 mpg with a TM40 while riding briskly and 47 mpg if I'm flogging it. Dropping the needle way down does not sound right.
Old 03-10-2012, 06:51 AM   #61058
Nibis
Where to next?
Nibis's Avatar
Oddometer: 844
My IMS came with a nice cap for the carb vacuum port. I used the "vent" line to drain my stocker on prime, into the IMS.
Jim
2008 DR650
Nibis is offline   Reply With Quote
Old 03-10-2012, 06:54 AM   #61059
Nibis
Where to next?
Nibis's Avatar
Oddometer: 844
Are you running the 150 main, I was trying to take it easy to see what mileage I could get, and only got 46mpg, it was very windy out though. Thought about trying the 145
Jim
2008 DR650
Old 03-10-2012, 07:10 AM   #61060
ShadyRascal
Master of None
ShadyRascal's Avatar
Oddometer: 6,644
If you are in Missouri you have thicker air than I do here at 3800 feet. I run a 150 main, and with my opened airbox and GSXR can, I could go to a 155 (dynojet). So I'd say don't go below the 150 before checking other things...
If your mileage is bad, it's probably a needle position issue. Main jet size really doesn't come into play that much unless you're at wide open throttle. Needle position determines your fuel-air mixture during 90% of your riding. Changing the main jet to affect this is chasing it kind of from the wrong end.
When I first installed my DJ kit, going by the instructions, it was very fat and got terrible mileage. I stepped it back until I had the 150 main and the needle clip 2nd position from the top. I have great power and get over 50 mpg all the time, 58-ish if I'm pretty nice to it.
Time spent carb tuning and learning is the best thing you can do for your bike.
Originally Posted by Javarilla
Evolution, or, natural selection, has nothing to do with better.
It merely weeds out what is no longer suitable for the given context.
Originally Posted by Dragoon
I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle.
ShadyRascal is online now   Reply With Quote
Old 03-10-2012, 07:20 AM   #61061
Nibis
Where to next?
Nibis's Avatar
Oddometer: 844
Thanks, the TM40 comes with the needle at the 3rd notch, so I'll try the 2nd, next time I have the tank off
Jim
2008 DR650
Old 03-10-2012, 07:23 AM   #61062
Nibis
Where to next?
Nibis's Avatar
Oddometer: 844
Thanks in advance.
Jon
You should be fine, bathed in oil, sealed from the elements.
Jim
2008 DR650
Old 03-10-2012, 07:24 AM   #61063
sagedrifter
Southern Explorer
Oddometer: 1,437
Yes 150 main, 3 on the needle I think. Its where Procycle sets it.
145 main is too lean for me. Needle position is the mpg effector.
Old 03-10-2012, 07:26 AM   #61064
ride4321
ride4321's Avatar
Oddometer: 1,985
Got the IMS tank on this morning and it seems to be running fine and not leaking. The yellow isn't a very good match but maybe the original plastic is fading. It does match the hand guards.
Tom Waits
Old 03-10-2012, 07:30 AM   #61065
Motodeficient
Oddometer: 448
Anyone know if a DRZ400SM sidestand would work for a DR650 supermoto conversion?
Motodeficient is offline   Reply With Quote
Times are GMT -7.   It's 10:39 PM.
