Old 05-09-2012, 08:48 AM   #64021
ram1000
ram1000's Avatar
Oddometer: 1,835
Originally Posted by bouldertag View Post
I was starting to get worried that something was seriously wrong as I have the vibes also.I have a 2009 3k miles and had the vibes since day 1 at 800 miles. I first thought it was the engine at a certain RPM issue. Doesn't really feel like a jackhammer but rather deep rattle at speeds talked about already, mine around 40-45 and only last during that 5 MPR zone then once under or above 40-45 it is gone . Can feel it on my pegs. I have the 14t front and stock rear. Took out the top roller when purchased. I was thinking it could be the top roller also. But the video helps to show it is the chain which makes me happy that it isn't in the engine.
Very interested in eliminating this issue or if it is totally normal and will be fine.
Thanks for visiting this area of concern.
boulder
My first guess for vibes is always motor mount bolts, especially in the head...
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is offline   Reply With Quote
Old 05-09-2012, 09:29 AM   #64022
Olas
the darkness
Olas's Avatar
Oddometer: 4,059
I know about the vibes, and I would have to agree that lugging the motor is what brings them out. I also have a 14t and stock rear sprocket and 50MPH is way to low to be shifting into 5th...I would definitely consider that lugging. My DR definitely lets me know when I'm lugging her by way of increased vibes. Keeping the RPMs high makes it run much smoother, IMO.
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 05-09-2012, 09:40 AM   #64023
Tech23
Tech23's Avatar
Oddometer: 471
Originally Posted by BadDogMax View Post
I'll add that the video was taken while accelerating from 50-60MPH in 5th gear, with a 14t front sprocket. Not lugging it IMO.
I appreciate all the help and theories... maybe we can solve this thing!
Do you still have the stock BST 40 CV carb on your bike? If so is the top of the air box cut/modified?
Tech23
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 is offline   Reply With Quote
Old 05-09-2012, 10:20 AM   #64024
Rumlover
Ed
Oddometer: 707
Vibrations
I hadn't rode my bike for a few days, so I just went out for a little test run. I have a 14/43 gearing and a pretty well dialed in BST. I did a couple of roll-ons at 50mph (stock speedo) in 5th gear (used 50 instead of 55 because of 43t rear). It was turning around 3500rpm at the time, which is about as low as I want to turn in 5th gear with a normal load (my fat ass).
50mph roll on was plenty fast to avoid the common lugging\lurching issue but I did pick up an "ever so slight" vibration in the footpegs untill about 55mph. But I had to be really concentrating to feel it and had never noticed it before. I consider this completly normal for a big single, with CV carb, on it's way up through the power band (once over 4000rpm it really comes to life).
But seriously if this is what some of you are noticing you are far more picky then me. I would have never noticed it if I wasn't really REALLY trying to pick something up.
If I was doing anything other then cruising --- had a passenger, going uphill, or just accelerating hard in general, I sure as heck would be downshifting.
I am not discounting other issues magnifying the vibration, but overall It is not a happy place for the motor, in 5th gear with a load.
I suggest picking up the RPMs (downshifting) if you are loading the motor between 50\55mph in 5th, or switch carbs.
Just my opinion
Rumlover screwed with this post 05-09-2012 at 12:17 PM
Rumlover is offline   Reply With Quote
Old 05-09-2012, 10:44 AM   #64025
ER70S-2
ER70S-2's Avatar
Oddometer: 6,778
... Or, maybe everyone is suffering with the oscillation problem, and some solve it by revving the engine to 8000RPM before shifting?
Just kidding, this vibration is not like the bucking bronco you get when lugging the engine. I think the "jackhammering on the swingarm" description is close.
In fact, if I intentionally lug the engine while accelerating, the bucking bronco will go away as the RPM increases, then suddenly the jackhammering will start at maybe 50-55MPH, then suddenly stop again at 60MPH.
There is no jackhammer at steady state or at medium to full acceleration. Only with gentle acceleration or slight uphill. Not the kind of acceleration you'd normally downshift for, like passing a car, or racing that dude on the DRZ400 who lives in the next housing tract.
Here's my latest theory: the BST carb has a vacuum operated slide that has some resonant frequency where it's most likely to oscillate up/down. The chain on this bike has a very long span, and when stretched with the right tension by acceleration, also has a resonant frequency like a guitar string. When those two resonant frequencies are the same (or perhaps a harmonic of one another) the following sequence happens: the engine fires a pulse, whipping the chain, which causes a jerk back to the engine, which creates vacuum, which causes the carb slide to undershoot, which causes the engine to stumble, which whips the chain, and then the process repeats.
Low RPM lugging would be be basically the same mechanism, except without the added resonance of the chain. So the jackhammering is like a second onset of lugging, once you're past the "normal" lugging you'd get on a BST-equipped DR.
So if my theory holds any water, the million dollar questions is this: Have any of us experiencing the jackhammering drilled the carb slide? This would change the resonant frequency of the slide and perhaps break up the resonance problem.
I have not drilled mine, my carb is stock except for a washer under the needle and a ProCycle mixture screw.
I have the same vibes with the 15t sprocket btw.
I quoted this whole message because it's so accurate to what's also going on with mine. I have not drilled the slide. I think your latest theory is quite possible, but I'm not enthusiastic about buying a $470 TM-40 to try out. I think you should do it.
Next time you have the rear wheel off, look for wear a mark about 3" in from the left (welded on) snail adjuster. I posted pics a few pages back.
My jackhammering is not a harsh, metal on metal, clanking (hammer and chisel). The impact and resonance is there, but there seems to be some sort of damping, perhaps the hub cushions.
I'm going to put my 16t on before I ride today. Although too tall for my altitude, it was smoother on my Kali trip in February and needs a second ride, paying closer attention. The hammering was almost nonexistant with the 16t at sea level. This contradicts the 'rpm too low' theory somewhat, the 16t would lower my rpm, not spin it up.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 05-09-2012, 11:05 AM   #64026
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Next time your have the rear wheel off, look for wear a mark about 3" in from the left (welded on) snail adjuster. I posted pics a few pages back.
Couple ideas:
Are you sure your non OEM rear wheel and hub bearings are fully seated, 100%? Do they fit properly? I only mention this because of the unusual wear on your axle. What would cause that?
I see you've gone creative on chain alignment ... maybe go back to just matching up the snail adjuster numbers. My front sprocket has always shown a bit of wear on the outside. No other problems or bad vibes as a result. I DO change my front sprocket every 7 to 10K miles ... no matter what. REally helps with smooth running and saves chain.
OEM sprockets please.
I believe you mentioned you had your clutch off to do NSU. I would double check your work there, and while in there look for dig marks in basket slots from clutch plates. Look at Lukas' pics to see a PERFECT basket. A worn one would have little dents where the clutch plate tangs sit in basket slots.
http://advrider.com/forums/showpost....ostcount=19799
Usually for me drive line vibes have always been from worn sprockets or chain. Something is worn or out of alignment. I doubt it's your clutch basket, but if it's installed incorrectly or not torqued? Then who knows? I hope you torqued down the BIG nut to full spec? Can't recall number, but it's a BIG ONE.
I hope it's not that BIG ball bearing under the clutch!
Adv Grifter screwed with this post 05-09-2012 at 11:11 AM
Old 05-09-2012, 11:15 AM   #64027
gone fishing
Oddometer: 76
Jetting question.
Picked up a 99 last Sat. Previous owner had opened the top of the airbox, installed k&n with foam cover and a dynojet kit using a 160 main. Bike runs great and starts easy. It has the stock muffler on it. I have a fmf q4 laying around that I was thinking about trying out. Have a couple of questions for anybody who has went this route before. First, will I have to go up bigger on the main jet? Bike came with the rest of the dynojet kit so I have a couple bigger ones if needed. Second, other than saving eight or ten pounds, is it worth fooling with?
Thanks,
Fred
gone fishing is offline   Reply With Quote
Old 05-09-2012, 12:44 PM   #64028
Dravintoad
Toadthumpin
Dravintoad's Avatar
Oddometer: 1,765
Well. I can feel vibes in the foot pegs when I ride at certain rpms similar to what is being described. Also, I can tell by the shadow on the road in the morning that my chain jumps around just as much as the video. I put on a new chain and sprockets this week, along with new cush drive rubbers.
I wish I could ride one of these vibration plagued bikes for comparison, but until I do, I'll just assume it in your head.
Coitus Thou, Thou coital coitus.
Dravintoad is offline   Reply With Quote
Old 05-09-2012, 01:25 PM   #64029
fizzerfz1
fizzerfz1's Avatar
Oddometer: 756
Thanks,
Fred
No, IMO not worth it unless you like loud pipes and like to repack the muffler. Moreover since you say the bike runs great, just keep riding it.
But if you want to still go over to the FMF you can just try swapping the pipe and then trying it out before going to a bigger jet. Since you have a cut airbox and K&N filter you may get by without a jetting change.
I had a DJ kit on my bike with cut airbox and a K&N filter, but I think my main was smaller than 160...The bike ran good with great mileage. Now I have a FCR
DR650 - FZ1 - 200 EXC (plated - Not inspected yet)
fizzerfz1 is online now   Reply With Quote
Old 05-09-2012, 01:30 PM   #64030
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,435
It's a big single. I think it's in their heads also. I remember the first time I rode a streetbike after years of offroad experience with moto-x bikes. I thought there was something wrong with the tranny. I could hear it shift. It was just that the motor was so quiet. I think it's more just the nature of the beast. Big single sending individual shock waves at low RPM and high load. I could be all wet also.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 05-09-2012, 01:31 PM   #64031
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Still does it with my FCR pumper carb...
I think it's a combination of power pulses and tight/loose links.
My new chain didn't do it for a few thousand km's.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 05-09-2012, 01:35 PM   #64032
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Thanks,
Fred
If its running the stock muffler, I'd try going down to the 155 main. The 160 is really only used with an open pipe.
DR650 Wiki
Old 05-09-2012, 02:19 PM   #64033
gone fishing
Oddometer: 76
Thanks for the replys. The FMF came with a 97 I bought last year. I commute on it almost every day. Its stone stock and gets about 60 mpg on my drive to work, so I didnt want to mess with it. I might try the pipe on the 99 but if its really that loud, it won't stay on.
Old 05-09-2012, 02:50 PM   #64034
cemory
cemory's Avatar
Oddometer: 55
Originally Posted by Mikey Boy View Post
Unfortunately it was molested by me while removing the fender and changing the taillight. I dont know how they crossed as I thought I capped them off securely(I should of just unplugged the freakin connector but I was working fast and being stupid). I doubt Suzuki will cover anything on it. I will get a picture up tonight of what i'm dealing with.
Maybe you should just put the original light back on and then take it to the dealer. This is America and you are innocent until proven guilty.
Chris in Topeka
cemory is offline   Reply With Quote
Old 05-09-2012, 03:16 PM   #64035
Tech23
Tech23's Avatar
Oddometer: 471
The reason I asked if you still have the stock BST 40 CV carb on your bike, and if you cut/modified the top of the air box is because of the routing of the slide chamber atmosphere vent hose/filter. There have been reports this vent hose filter that sits right over a "desnorkled" or cut air box opening can cause surging as it picks up the constant changing of positive and negative pressure waves within the air box. This can add to the slide oscillation that makes the CV carb the POS it is. On the plus side drilling the slide makes for better throttle response because it allows the slide to react faster...on the down side this faster reacting slide can make the oscillation of the slide (surging) even worse. This is why many elect to bypass this step in the Dyno Jet instructions.
I think you may be learning first hand why many pitch the CV carb in favor of a flat slide carb that features a direct connection to the slide as opposed to a pulsing vacuum connection.
Tech23
Tech23 screwed with this post 05-09-2012 at 08:56 PM
Times are GMT -7.   It's 02:31 PM.
