Old 05-07-2012, 03:13 PM   #64066
anaud14
Oddometer: 4
Originally Posted by anaud14 View Post
Hey guys, I've got a dead DR in my garage and I'm not sure where to begin to revive it.
Two weeks ago I stopped for a break while trail riding, and when I started the bike to head out again, it turned over very weakly. A little while later I stopped for another break, and the bike wouldn't turn over at all, just clicking. Luckily for me I had a ditch between me and the freeway, so I rolled down the hill and was able to bump start and head toward home on the road. I got about 4kms down the road and she started to choke and pop then finally die completely.
My guess was that my battery had finally croaked. Original battery, 26000kms and 4 years old. I bought a new battery and put it in, and she ran great...for 50kms. After the 50 kms I got the exact same problem as before with the popping and dying.
I'm no expert at all with electrical, my best guess is that my battery isn't receiving any sort of a charge. Can anyone point me in the right direction to getting this thing running again?
Alex
I THINK I may have found my problem, but as I said, I'm no electrical guru by any means.
I started with the terminals like you guys suggested, then worked my way to all the wire connections. I found the red wire going into the regulator/rectifier to be extremely corroded, so much that when I lightly touched it, it came apart.
Could this be my issue?
anaud14 is offline   Reply With Quote
Old 05-07-2012, 03:19 PM   #64067
ER70S-2
ER70S-2's Avatar
Oddometer: 2,612
2004 DR650: 47,033 miles of The last 314 miles were done with my super, hot rod, whiz-bang, blue KLIM Dakar gloves. Good thing I lost one of my 10 year old Joe Rocket gloves; I didn't know I could ride so fast.
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 05-07-2012, 04:05 PM   #64068
poppawheelie
poppawheelie's Avatar
Oddometer: 278
Pissed Gas Cap Vent won't stay on
I bought one of these gas cap vents and could not get it to stay on.
The nipple on the cap is tappered, and the hose pops off. I put it on, walked away, and came back to find it on the floor. I tried roughing up the sufaces (even inside the hose) with sand paper, pinching the hose with safety wire... even silicone glue wouldn't hold it on! Problem solved with Super Glue, but I wonder how others may have solved this problem, other than buying the locking cap.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie is offline   Reply With Quote
Old 05-07-2012, 04:17 PM   #64069
notarat
notarat's Avatar
Oddometer: 333
When I owned a KLX250S I bought the Clark oversized tank. Specifically, I purchased a second. (meaning it was a bit discolored and not offered through normal channels.)
It was a leaky POS so I called them back and they sent another one, a production unit, that was also a friggin colander, rather than a tank. Point is, the clark tank had one of those tubes on it and I just yanked it off the clark and installed it onto the Acerbis and it works great. It was the only good thing to come out of that whole debacle.
If anyone needs to strain some pasta I have a clear and black colander for sale that holds over two gallons, at least temporarily...
notarat is offline   Reply With Quote
Old 05-07-2012, 04:34 PM   #64070
BadDogMax
Oddometer: 118
Chain vibration video
Originally Posted by NordieBoy View Post
In that vein, look at the top of your chain by the front sprocket when the vibes are happening.
NordieBoy, you are on to something! I am working from home today so I thought I'd grab the video camera and run up the road and back. Most of the time the chain was smooth, but during the vibration it was... well... watch the video:
Check out the slo mo of the chain at the end!
2007 Suzuki DR650, 1983 Honda XL600r (SOLD), 1970 Honda CT70H
BadDogMax is online now   Reply With Quote
Old 05-07-2012, 04:43 PM   #64071
dljocky
Oddometer: 660
I had to use super glue on mine also. I didn't really want to go back to this cap, but after having three of the locking gas caps fail(rubber washer thingy) I've decided to go back to the original cap like this. I'm hoping Procycle can get me some of those rubber washer's for caps that have failed, as I really do like them. Also, on my last trip when the cap started leaking when I fueled up, gas got all over my new enduro tank bag, anyone have ideas as to how to get the smell out of the bag? I've washed it several times, and currently, letting it air out in the sun.
dljocky is offline   Reply With Quote
Old 05-07-2012, 06:12 PM   #64072
ScottDill
TANSTAAFL
ScottDill's Avatar
Oddometer: 3,085
Mine did the same thing so I used a piece of rubber fuel line in place of the PU tube it came with. The rubber is much grippier and keeps it all attached without use of glue.
ScottDill is offline   Reply With Quote
Old 05-07-2012, 06:22 PM   #64073
truck6driver
The Fireman
truck6driver's Avatar
Oddometer: 5,824
Might be looking at a 1999 DR650SE this week. Other than the usual stuff is there anything specific to the DR that I should look for?
Ray
truck6driver is offline   Reply With Quote
Old 05-07-2012, 06:36 PM   #64074
silverwolf
silverwolf's Avatar
Oddometer: 267
Sounds exactly like what happened to my drz. Those connectors are trouble. The best way to check is to put a multimeter on the battery and start the bike and then poke at the connectors to see if you see a difference. Definately good to check all those before digging into regulator rectifier issues.
silverwolf is offline   Reply With Quote
Old 05-07-2012, 06:43 PM   #64075
ER70S-2
ER70S-2's Avatar
Oddometer: 2,612
Ray
Here's the DR's dark side. The most important to you is reading post #21 and all of both links. The two case halves are machined as a pair and must be replaced as a pair. If it happens, it will be less expensive to find a complete replacement motor and they're becoming hard to find.
Other than that.............................................. 31,781 miles and counting.
Oops, guess you'll need the link.
http://www.advrider.com/forums/showthread.php?t=636395
Old 05-07-2012, 07:00 PM   #64076
LexTalionis
Inciteful
LexTalionis's Avatar
Oddometer: 415
Originally Posted by ER70S-2 View Post
Feel free to post those anywhere they'd help. Thanks for the kind words. Don't forget o-rings to help seal the pedal shaft, for between the outside of the frame and the pedal. I didn't think of the idea until after the project was done so I don't know what diameter the shaft is nor what thickness o-ring might fit best. I have 36 pages of DR notes and posts in a word.doc, not like I can find anything though, indexing something that random has escaped me.
Happy to be of assistance to you!
In a Word document, separate each note / post by a hard horizontal line (hold down Shift and press "_" three times); add a reference word peculiar to the topic at the top or bottom of the note / post so you can use the Find feature, then scroll through all the found reference words. Alternatively you could devise an alpha-numeric sequence peculiar to each topic for the search function, but a sequence not otherwise used in the Word file, as in AA1 = motor topic, AA2 = suspension topic.
Or do like I do (pic of a portion of my harddrive tree):
Lex
The older I get, the better I was.
LexTalionis is offline   Reply With Quote
Old 05-07-2012, 07:08 PM   #64077
poppawheelie
Oddometer: 278
Dawn detergent seems to work better than others for getting out the gas smell. I haven't seen one of those locking caps, but I'd suggest cutting a new gasket from rubber inner tube. It won't deteriorate in gas. I soaked several gasket materials and a bit of rubber inner tube in a jar of gas (with ethanol) for over a year as a test, and it stayed solid.
Back to the smell. Hey, I love the sweet smell of gas! Doesn't bother me a bit, on my clothes or anywhere. Wifie doesn't like it though.
Old 05-07-2012, 07:13 PM   #64078
poppawheelie
Oddometer: 278
Ah, good idea! I'll remember that. I knew there had to be a better way than Super Glue (can't remove).
Old 05-07-2012, 07:52 PM   #64079
ER70S-2
ER70S-2's Avatar
Oddometer: 2,612
205'd by scodill. Just drill two holes and carry zip ties.
A tapered nipple on super slippery plastic. I'd carry a short piece of hose (long enough to go down the steering head. The hose in the pic is 1/2" O.D. and fits) and 3 zip ties, in case the Super Glue lets loose on a ride. Everybody carries zip ties, right?
Drill holes in opposing knobs on the cap (blue arrow), large enough for zip ties (ignore the red notes on this pic that I stole on the internet). Drill 'em before ya need 'em. My zip ties are 3/16". The little one on top didn't feel very secure: 1/10"
Crude mock-up. However, it would get you home without a gas bath. Safety wire would be less 'rednek', but shorter lived.
Lex
Thanks Lex, the learning never stops. The screen shot is a great help.
Old 05-07-2012, 08:00 PM   #64080
ER70S-2
ER70S-2's Avatar
Oddometer: 2,612
Damn, I would have lost a lot of money on that bet, ethanol or not.
Times are GMT -7.   It's 10:18 PM.
