Old 05-15-2012, 12:41 PM   #64336
XPLRN
XPLRN's Avatar
Oddometer: 186
DR650 Operator Lowering Brackets
Originally Posted by XPLRN View Post
Almost four years ago a local machining/fabrication guy came up with a unique drop bracket configuration for the operator foot pegs on the 1999 and newer DR650. This configuration utilizes the Suzuki designed vibration isolation feature. This drop bracket configuration is best for folks that ride mostly street/gravel roads and are not doing that much 'stand up' riding off-road. This is due to the lowering of the foot pegs beneath the frame and the vibration isolation feature was designed for a mostly seated rider.
Anyways he's still got 6-7 bracket sets from this one time CNC production run and wants to get rid of them.......first come first serve..........when they are gone that's it. He has reduced the price to $60 shipped vs. the $75 previously (Paypal fees extra). The guy that had him design and manufacture these drop brackets posted up a review of them...........read thru the links below for more info, pictures and his contact info if interested
http://www.advrider.com/forums/showpost.php?p=7817999&postcount=16710
http://www.advrider.com/forums/showp...ostcount=16712
Originally Posted by plugeye View Post
boy what a deal for about 1/2 what its worth & you gotta find your own hardware
Actually it is a deal for the right DR650 riders. folks that ride mostly street/gravel roads or jeep trails and need a bit more leg room. These operator drop brackets are the only parts available that are designed to utilize the Suzuki designed vibration dampening feature.
The operator lowering bracket kit I installed on my bike had the hardware included...... it sure helps the bike ergos/knee joints for people with longer legs.
XPLRN is offline   Reply With Quote
Old 05-15-2012, 12:52 PM   #64337
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,143
Originally Posted by Go Irish75 View Post
Never had a bolt back out of a header before. I guess some high temp Loctite like the 272 wouldn't be a bad idea in there.
Mine stay in place with anti-sieze.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 05-15-2012, 01:05 PM   #64338
deathu
deathu's Avatar
Oddometer: 77
Aftermarket ignition switch
Hi,
I just managed to buy a used DR650SE a few days ago.. these bikes are VERY rare here in Europe, it took me over 6 months to find one in my area. The bike is not in a good shape, but given the fact that since the day I first rode one i knew this was the DS bike for me, I had no alternative but to buy whatever DR650SE I manage to find..
Now to get to the point of my post, one of the many things I need to sort out on this bike is the ignition switch, which is operational but in a very bad shape. I have to "play" alot with the key to be able to turn it on. Once turned on, it won't retain the key inside. I'm thinking about replacing the ignition switch entirely, but for some reason I can't find any aftermarket one for sale, and the OEM one seems overpriced at over 130$. Does anyone know of an aftermarket ignition switch for the DR650SE? - OR - does the ignition switch of any other Suzuki model fit the DR650SE?
For some reason, I only seem to find aftermarket alternatives for the older, pre-1996 DR's.
deathu is offline   Reply With Quote
Old 05-15-2012, 01:18 PM   #64339
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,702
Black Acerbis tank on the 2012 grey.
Sent from my SCH-I800 using Tapatalk 2
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot screwed with this post 05-15-2012 at 01:35 PM
DockingPilot is offline   Reply With Quote
Old 05-15-2012, 01:31 PM   #64340
dljocky
Oddometer: 865
That looks nice!
dljocky is offline   Reply With Quote
Old 05-15-2012, 02:27 PM   #64341
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
No Luck
Man I'm having terrible luck today. Both front fork seals blown. SHIT! Gotta 1500 mile trip in 2 days and no time. Anyone have the specs on how much oil goes in front forks, PLEASE? Dammit...........
Staring straight into the shining sun....
Just cause I'm wrong, don't make you right / Needtobreathe
Our OBDR Trip http://advrider.com/forums/showthread.php?t=712724
Our UTBDR Trip http://advrider.com/forums/showthread.php?t=816500
asrvivor is offline   Reply With Quote
Old 05-15-2012, 02:36 PM   #64342
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,196
Wiring Questions
I have a set of those Denali LED lights (from Twisted Throttle) on my DR650. They're currently wired up using the wiring that came with them and their own switch. I would like to eliminate this wiring and connect them to the high-beam switch so they only come on when that switch is activated. My headlight has been replaced with a low-beam-only HID model so I have a "spare" prong coming off of my high-beam connector.
Not being an electronics type, and not being able to read a wiring diagram very well, I was wondering how I can go about doing this? Is it just a matter of connecting the power leads from the lights to that "spare" prong?
Thanks.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 05-15-2012, 02:37 PM   #64343
Olas
the darkness
Olas's Avatar
Oddometer: 4,058
l
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas screwed with this post 07-27-2012 at 07:38 AM
Olas is offline   Reply With Quote
Old 05-15-2012, 03:29 PM   #64344
Escaped
Escaped's Avatar
Oddometer: 488
Just changed the fluid in my front forks - it a little over 16 ounces in each fork. It really a measurement thing, level of oil to top of fork, then volume of oil. Make sure you get all or at least most of the old oil out.
2006 DR650 54,407 miles
DR650 - Eyes open all of the time
Escaped is offline   Reply With Quote
Old 05-15-2012, 03:33 PM   #64345
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Thanks guys. Got a Pm from PPCLI-Jim. Steeeered me in the right direction. I love this site. Never fails, you get everything packed for a big trip and BAM something starts leaking. At least it did it in the drive way. Could have been worse. Although I would have rode the thing the entire trip leaking oil. Who needs shocks really??? lol
Old 05-15-2012, 03:35 PM   #64346
BergDonk
BergDonk's Avatar
Oddometer: 3,719
Originally Posted by deathu View Post
Hi,
The stock ignition switch contains a resistor that goes in seriies witht he power circuit to the CDI I believe. Its a security measure to make it hard to hotwire the bike. Some one posted a tutorial a while back on how they sorted it, including what value the resistor is. Once that is sorted, and switch arrangement can work, although you'll lose the steering lock too.
Steve
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 05-15-2012, 03:39 PM   #64347
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,712
For a stock setup:
10 weight Fork Oil
19 oz. required per fork
Oil Level Setting: 165mm (6.5") from the top with springs removed and the fork completely collapsed.
But, before you tear it apart, try cleaning the seal with a thin piece of plastic - it has worked for me in the past, for thousands of miles without the leak reoccurring.
'04 R1150GS, '97 R1100GS, '99 DR350, '02 DR650, '03 DR650
A Few Days Solo to Copper Canyon
A Maine Rider’s Arizona Day Trips
A Few Days Solo in Baja
kobukan is offline   Reply With Quote
Old 05-15-2012, 04:04 PM   #64348
Monroe
Monroe's Avatar
Oddometer: 682
Originally Posted by Olas View Post
that looks like a beautiful day and place to be on the bike
Monroe is online now   Reply With Quote
Old 05-15-2012, 04:18 PM   #64349
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Fork Seals:
find a piece of 35mm film (remember that?) or other very thin but strong plastic. Use it to gently work between the rubber seal lip and fork tube. Work it in there and try to clean out any grit or crud. Use WD40 to flush out crap. Wipe clean. Now ... rotate the UPPER tube within the lower tube (loosen both sets of triple clamp bolts) This can change the contact point and sometimes stop the leak. Clean out crud best you can with the film, be careful not to damage the seal lip. Delicate.
Fork Oil:
If you've only lost a bit of oil and the leak is NEW, then don't worry about it now unless you want to remove forks, drain and re-fill. Just unscrew fork caps with forks on bike, add a bit of oil (based on how much you've lost) a little over or under filled will not hurt a thing. Use 10 wt. Oil. Don't smack yourself in the face when fork cap lets go. Hold down with hand as you turn it.
Header Bolts:
I believe the exhaust header bolts on the DR650 are probably heat treated to pretty high level and are pretty high quality. (Not sure) That is the hottest external place on your bike, so correct bolts are probably a good idea. I know the Suzuki ones are expensive and have to be ordered, but maybe something to think about for the future? Use Anti-seize on the threads. Mine have never loosened. DO NOT over tighten them ... if you strip the internal head threads ... it's gonna cost you.
Make sure your Chain, Sprockets, Tires and battery are ALL OK before you leave. Safety 3rd!
Old 05-15-2012, 04:30 PM   #64350
notarat
notarat's Avatar
Oddometer: 338
Hi,
I would comb through some of the online repair manuals for the DRZ400 and DR350 to see if their wire schematics match the DR650 in terms of connections. You can cut, splice, solder, then heatshrink so you can re-use your connectors.
I sent you a PM regarding an auction on fleabay.co.uk too listing a DR switch
notarat is offline   Reply With Quote
Times are GMT -7.   It's 05:27 AM.
