05-23-2012, 10:16 AM
#64906 |
Oddometer: 436
The inner "teeth" on the retainer are rotated in the slot on the countershaft so that they are behind corresponding notches on the countershaft. Ones the bolts go through the retainer into the threaded holes in the sprocket, the whole assembly is locked in place.
05-23-2012, 10:18 AM
#64907 | |
Oddometer: 504
Hmmm....
So now the bigger question, what harm am I doing or risk am I taking in running a clip on type retainer by itself? I rode the bike home from Arizona like this and obviously been riding it this way since last year. I've been on a bike when a chain broke and can remember very well what they was like, what's gonna happen in this case?
" ...said James in my opinion, there's nothing in this world beats a 52' Vincent and a red headed girl..." "1952 Vincent Black Lightning" Richard Thompson |
05-23-2012, 10:21 AM
#64908 |
Oddometer: 436
Here is a better picture to explain it
![]() I haven't heard of a ton of issues with running the clip. More so than running the bolts though, thats why I run the bolts. |
05-23-2012, 10:24 AM
#64909 |
Oddometer: 504
Thanks again...
I get it now.
I checked the ProCycle site and they refer to running the clip only, sounds like it's a very minor concern. I don't like the side to side play that's there but as someone else said maybe it's actually better for keeping the chain aligned? Think I'll source a bolt on retainer and put it on but I won't be as worried as I was a couple of minutes ago... Wonder if running 2 circlips would do anything useful?
05-23-2012, 10:25 AM
#64910 |
Oddometer: 436
Running the clip makes front sprocket changes quicker. If you don't change front sprocket size often I would use the stock bolt/retainer setup. Just my opinion.
05-23-2012, 10:32 AM
#64911 | |
Oddometer: 2,538
Fixt. |
05-23-2012, 10:35 AM
#64912 | |
Oddometer: 1,597
The clip method of retaining a front sprocket is appropriate for bikes that were originally designed for it. They will have a shoulder on the shaft and the clip will hold the sprocket firmly against that shoulder.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
05-23-2012, 10:57 AM
#64913 | |
Oddometer: 504
Hmmm....
It would seem to be a bad idea based on what you wrote above. And while I've got you, do you guys have a stock retainer in stock or just the aftermarket stainless steel ones? Should have checked before my last order with you guys...which arrived very quickly by the way.
05-23-2012, 11:01 AM
#64914 |
Oddometer: 436
If you posted a WTB thread in the fleamarket you could probably get one dirt cheap from someone who switched to a clip.
05-23-2012, 11:05 AM
#64915 | |
Oddometer: 504
Looks like replacing the clip with the stock stuff will run over $25 plus shipping, none of my local dealers have any of the stuff in stock.
05-23-2012, 11:17 AM
#64916 | |
Road Captain
Oddometer: 9,307
Pain in the Butte Ranch Durango, Colorado - Calculated risk or forbidden fruit? |
05-23-2012, 11:19 AM
#64917 | |
Oddometer: 436
I bet you could get it from someone here for around $10 shipped including the damper. |
05-23-2012, 11:23 AM
#64918 | |
Oddometer: 440
WITH GREAT HORSE POWER....... COMES SHITTY GAS MILEAGE .. AND HIGHER INSURANCE PREMIUM.... 2007 DR650 SuperMoto with almost all the goodies..(it never ends ya know!) Take a look at my cool sticker-bombing project |
05-23-2012, 11:29 AM
#64919 |
Oddometer: 436
Have you checked your fuses yet?
05-23-2012, 11:38 AM
#64920 | ||
on the road o'dreams
Oddometer: 5,373
The Circlip type fits in a slot on the shaft and clips in place. That is what holds the sprocket, I believe. I've not used this on my DR, but have on other bikes. It's OK I guess, but a few issues with it. You've done everything right! ![]()
