Old 06-06-2012, 08:47 AM   #65491
suguzzi
Greybeard
suguzzi's Avatar
Oddometer: 37
Corbin
Originally Posted by Ride-til-sore! View Post
Well I put on a new Seat Concepts seat and if feels great compared to the stock one when starting out on a long ride but an hour or two on it my butt seems to be hurting as much as my old Gel seat with a Walmart cover on it? Now what? Is it to soft or what? If I throw another pad on top of it I may not be reaching the ground! I have been riding bikes for years so it's not like my butt is that out of shape but I'm not Dolph Lundgren either!
When I first got this seat I thought that I had found my long ride answer. It is great for short rides but no better on long ones! Suggestion?
I have a Seat Concept on my DRZ and found the same issue as you are having, but I have a Corbin on my DR and do not even think about the seat. I have done 550+ mile days without any problems. Even though they are heavy and a bit pricey it is well worth it IMHO.
suguzzi is offline   Reply With Quote
Old 06-06-2012, 09:08 AM   #65492
mxbundy
mxbundy's Avatar
Oddometer: 959
Try a firmer foam.
Bundy
The 80`s..........ah yes...back in the days when men looked like women, women dressed like whores and the music F@#KING ROCKED!
Check out http://seatconcepts.com/ , your ass will appreciate it!
http://advrider.com/forums/showthread.php?t=621311
mxbundy is offline   Reply With Quote
Old 06-06-2012, 09:21 AM   #65493
carcajou
Resourceful Weasel
Oddometer: 103
Need a Part Pronto
Hello Fellow Inmates
I was installing a FMF Q4 Exhaust upgrade, and have bungled the connector between the mid pipe and the header pipe. Non of the local dealers or online dealers have it in stock and it looks to be a 10 day wait for the pipe. I will be out of state for the rest of the month and am planning to depart July 1st to ride the Continental Divide Trail north to south. I kinda wanted to have the DR back together by this weekend instead of getting back from my trip throwing the bike back together and taking off. The part is a stock part for my 2009 DR 650 part number 1053526 and is called Connector, MUF
So does anyone know where one is in stock I can have rapid shipped to my house or does anyone know a substitute? It really is the gasket between the midpipe and the header pipe so there is not an exhaust leak. Thanks Roger
"Beaten paths are for beaten men." - Erik's Mom.
carcajou is offline   Reply With Quote
Old 06-06-2012, 09:24 AM   #65494
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
it's not that one or another is better just different foam density works for different people. for many corbin is just too hard. seat concepts also makes a harder foam option. i'm happy with my sargent. it's softer than corbin, but not sure about how it compares to seat concepts or saddlemans.
i'd contact jeff as he's the one guy who stocks them all and would know
http://www.procycle.us/bikepages/dr650.html#bodyframe
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 06-06-2012, 09:26 AM   #65495
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,461
All the Corbin saddles I've had and tried are very hard.
If you want hard, borrow a Corbin and experience the wide board. I have a custom Corbin and I'm a heavy guy, its never softend up. But, it works ok. At 300 miles my but needs a long rest, a nice casual lunch works well. I put 300 miles on this week in one sitting.
Sent from my GT-S5690L using Tapatalk 2
sagedrifter is offline   Reply With Quote
Old 06-06-2012, 09:33 AM   #65496
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
the stalling just above idle is from too rich a pilot jet tuning.
awhile back people found the traditional ways of fine tuning the pilot screw resulted in it being turned out too far the creating a rich bog just off of idle. try using 1 turn out and see what happens. turning up the idle helps but then you deal w/ another DR issue, 1st gear clunk and the solution is to turn the idle down so there is a trade-off happy point in there somewhere for you.
as for surging it's an issue for some because of the open airbox and air the pulse waves coming into the carb. some have it some don't. some have found putting a better filter on the carb vent helps (small round thing tucked up in there). others have put mesh screen on top of air opening or put back in the backfire screen (which procycle found makes no difference either way in or out)
Originally Posted by Seventy One View Post
I recently installed the Pro-Cycle jet kit in my stock '09 DR650 and want to know if the pilot jet should also be changed.
I read through the BST40 Bible thread and it says that the pilot jet should be increased from the stock 145 to 147.5 if running a cut air box and aftermarket exhaust. The Pro-Cycle kit did not include this.
Is this the part I need? http://www.motorcyclecarbs.com/MIKUN...__P2617C26.cfm
Also, I seem to have misplaced my instructions for the Pro-Cycle jet kit. Could someone scan them and post 'em for me? I just really need to double check a few things. The bike runs pretty well but does have a little surge at 55-65 mph and an annoying tendancy to want to stall (just above idle) when warm. Thanks!
Alaska
Old 06-06-2012, 09:35 AM   #65497
Ride-til-sore!
still 20 in-my-mind
Ride-til-sore!'s Avatar
Oddometer: 383
Do you feel that one is firmer or softer then the other? Seats are and odd thing to tack down. It's like how do people ride all day on a 10 speed seat? I'm thinking that some times it's where the seat rides like more on the boney middle part of your butt or on the outter fattier part that makes a differeance?
Ride-til-sore! is offline   Reply With Quote
Old 06-06-2012, 09:49 AM   #65498
suguzzi
Greybeard
suguzzi's Avatar
Oddometer: 37
The Corbin is quite a bit firmer than the seat concepts. I better add that my seat concepts is also the lower model, which may have some impact on it"s long range comfort. I also run a Corbin on Guzzi Norge and like it as well, but must say the fit to the tank on the Norge seat is pretty shabby work for the price of the seat. I guess my old ass requires a firmer seat.
Old 06-06-2012, 09:53 AM   #65499
procycle
procycle's Avatar
Oddometer: 2,463
ProCycle has them in stock
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 06-06-2012, 11:20 AM   #65500
procycle
procycle's Avatar
Oddometer: 2,463
Originally Posted by Bob808 View Post
On a side note, I need to put my engine back together and need to get a complete gaskets kit. Do you recommend the Athena one? It's the only one I can get locally for about 144$. Seems kinda steep. I'd get one online but I need to be sure that it won't damage the engine. I've red some horror stories with Athena gaskets for other bikes.
Athena makes the OEM gaskets for Aprillia, Ducati and others. They are high quality gaskets but certainly kinda pricey compared to other options. You certainly are not going to cause engine damage from a gasket.
Old 06-06-2012, 11:36 AM   #65501
Mikey Boy
Mikey Boy's Avatar
Oddometer: 266
Ok inmates, looking for some knowledge. I had an electrical fire on my 2011 DR. I bought a used harness (in great condition) and replaced the old one. All the lights are working but when you press the starter nothing happens. It doesnt even turn over. There is an orange power wire that goes from the forward connector to the ECU that is missing. It seems that there are some differences in the wiring of the 96+ DRs. Has anyone had this problem? Its the orange wire with a black tracer.
2014 Tiger 800xc
1985 Honda Elite 150D
Mikey Boy screwed with this post 06-06-2012 at 11:45 AM
Mikey Boy is offline   Reply With Quote
Old 06-06-2012, 12:06 PM   #65502
Ride-til-sore!
still 20 in-my-mind
Oddometer: 383
Did you check the fuse? If you had a fire it may have blowen?
Old 06-06-2012, 12:06 PM   #65503
ER70S-2
ER70S-2's Avatar
Oddometer: 7,265
The manual doesn't show an orange/black anywhere. There's an orange, orange/white and orange/yellow. Looking at my DR, there's an orange/white and orange/yellow at the CDI.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 06-06-2012, 12:20 PM   #65504
Mikey Boy
Mikey Boy's Avatar
Oddometer: 266
It is an orange/balck wire. The old harness had 6 wires in the front connector and the new (used) one has 5. It comes off the main start switch and is orange with a black tracer. Apparently there are 4 different wiring schematics. I am trying to find the right one now.
2014 Tiger 800xc
Old 06-06-2012, 12:35 PM   #65505
Mikey Boy
Mikey Boy's Avatar
Oddometer: 266
I dont see an orange/black wire anywhere either on the schematics. The guy at the shop must be trippin.There is a yellow/black wire that goes from the start switch to the clutch lever position switch? That might be it. Would that make sense?
2014 Tiger 800xc
Mikey Boy screwed with this post 06-06-2012 at 12:47 PM
Times are GMT -7.   It's 06:21 PM.
