Old 07-28-2012, 07:21 AM   #67891
JagLite
JagLite's Avatar
Oddometer: 599
Talking Seat Concepts
Originally Posted by Thumper Dan View Post
I'm going to get me one of these for the DR maybe next week. Is the defualt option Carbon / Gripper the best cover to use??
I believe Seat Concepts probably needs some more pics a just a little bit more info on the website so people know what they're getting. But i've only heard good things about the comofort of their seats.
I went for the Gripper top with carbon sides on my DR and I like it very much.
When I got their seat for my TW200 I did NOT got the gripper top as I thought I would like to be able to slide around on the seat more and with the puny power the TW has I certainly wasn't going to slip off the back during acceleration.
But, after a few rides I would rather have the gripper top like my DR. Oh, well, next time.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 07-28-2012, 08:29 AM   #67892
TrophyHunter
Oddometer: 920
Seat Concepts - I have the Carbon sides, Gripper top. It's grippier than the stock seat and took a bit to get used to. I wouldn't go back.
www.dualsportmoto.com
2005 DR650
2013 HD Road King
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 07-28-2012, 11:23 AM   #67893
KS Jay
Milwaukees Best
Oddometer: 252
Originally Posted by Motodeficient View Post
Anyone know of a good polish to clean up the stock seat? I know I don't want anything that's slippery.....
But I got some white paint overspray on my seat. Not a ton but when I tried to get it off it sort of just got absorbed by the seat and now it looks worse
Any ideas? I guess its a good excuse to get a seat kit but I don't want to spend any more money on the bike right now.
Did you try a little lacquer thinner on a rag?
06 DR650
KS Jay is offline   Reply With Quote
Old 07-28-2012, 12:18 PM   #67894
PhL0aTeR
10:90
PhL0aTeR's Avatar
Oddometer: 511
Send a message via Yahoo to PhL0aTeR
Originally Posted by Rusty Rocket View Post
Ill have to remember to search a 99 vs 06..... I got 27 from the 06 fiche, but 99 had the size.... Go figure...
2006 Suzuki DR650
PhL0aTeR is offline   Reply With Quote
Old 07-28-2012, 12:31 PM   #67895
ER70S-2
ER70S-2's Avatar
Oddometer: 2,556
Originally Posted by PhL0aTeR View Post
Hmmmmm, hooda thunk?
2004 DR650: 46,358 miles of
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 07-28-2012, 12:42 PM   #67896
Tech23
Tech23's Avatar
Oddometer: 414
If you look at the Suzuki part number structure it appears that the bolt dimensions are in the part number...
01547-06203 (BOLT6X20) Not 100% certain on this with Suzuki, but I know Honda parts numbers are structured this way for bolt dimensions. If you look at the part numbers in the illustration for bolts #25 01547-06353 (6x35) and bolt #26 01547-06303 (6x30) Suzuki may very well be using a Honda style part number structure.
http://www.ronayers.com/Fiche/TypeID...RANKCASE_COVER
Tech23
CRF 150/230/ Supermoto Conversion
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
Tech23 screwed with this post 07-28-2012 at 12:53 PM
Tech23 is offline   Reply With Quote
Old 07-28-2012, 01:50 PM   #67897
acap650
acap650
acap650's Avatar
Oddometer: 354
Procycle choke conversion
My choke cable finally snapped from corrosion, seems a bit premature on a 2008 but others have had it happen. It kept getting sitffer so I knew something was up. Ordered a new oem cable but it was backordered so I got the Procycle kit, not the knob version since the IMS tank blocks easy access, but the one with the short cable. After installing it I thought what a nicely executed replacement - it looks like a factory part.
All was well until I rode the bike the next day and found that as soon as the engine started to warm it would not idle. I had to screw the idle stop a few turns and the idle mixture all the way in to max lean or it would stall. Well I've had stalling issues before so I thought maybe I'll just clean the pilot jet, I know according to the current carb best practices one should just replace it but I cleaned it anyway. But wait, a clogged pilot would cause a lean condition and this was the opposite so out came the new choke and to my surprise the plunger did not match the original.
As you can see the oem plunger and guide pin is longer, by about 3mm or 1/8 inch. This told me that when the choke was in the off position it was still partially on and may be responsible for my stalling problem. So I removed the new plunger and installed the original plunger and spring. I backed out the idle stop and set the mixture screw to 1.5 turns out and it ran nearly perfectly. After a good warmup ride I tweaked the settings and all is well again.
I'm just wondering if anyone has had issues with the choke conversion or did I just get the wrong part, maybe for a different carb? I still commend Procycle for a nicely finished part and their excellent shipping practices but maybe they should check the current batch to see if they all have the wrong plunger.
acap650 is offline   Reply With Quote
Old 07-28-2012, 01:59 PM   #67898
Paddle007
Oddometer: 290
TM40 issue
I have been going around and around with a friends new to him DR with a TM40 carb. Fuell economy has been poor with some odd running issues. First issue was no adapter ring which created a vacuum leak at the intake. Could only make it idle and not die/ hiccup with a huge slow speed jet. But fuel economy was under 40 mpg. No go
I was back at the beast today and focused on the fact that there was no audible change in idle quality or speed when the idle mixture screw was in or out. My air/fuel meter would barely change. How odd. Decided to remove the extended mixtures crew for an inspection. Maybe a fudged o-ring? This is what I found.
B
O crap, it's stuck in bottom of the idle circuit where it feeds fuel downstream of the slide.
Finally got it out by grabbing a very small drill bit with a small vise grip pliers, inserting the bit into the hole visible in the throttle bore. Had to apply pressure to the vise grips with another pair of channel locks to get the booger out.
We have a replacement mixture screw coming but now a small rotation of the "shortened" screw has an affect on idle quality and fuel trims. I think we finally have beaten the beast down. Geez, something so small can create so much grief.
Paddle007 is offline   Reply With Quote
Old 07-28-2012, 03:37 PM   #67899
TRAVELGUY
Old Traveler
Oddometer: 463
I had no problems with my install of that a few months ago. My DR ran perfect before and after the change.
TravelGuy.
TRAVELGUY
DL1000 '05 black
DL 650 '07 ( lives in Costa Rica )
DR 650 "08
TRAVELGUY is offline   Reply With Quote
Old 07-28-2012, 04:32 PM   #67900
HerrMnnn
Inactive
HerrMnnn's Avatar
Oddometer: 477
+1
Carbon/gripper is what Seat Concepts recommended to me, and they were spot on. Great seat.
HerrMnnn is offline   Reply With Quote
Old 07-28-2012, 05:19 PM   #67901
Thumper Dan
Oddometer: 214
Originally Posted by HerrMnnn View Post
+1
So to clarify; is the carbon gripper............top of seat is gripper and sides are carbon OR the other way around?
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks
Thumper Dan is offline   Reply With Quote
Old 07-28-2012, 06:19 PM   #67902
HerrMnnn
Inactive
HerrMnnn's Avatar
Oddometer: 477
Sides carbon, top gripper.
Old 07-28-2012, 10:00 PM   #67903
P-P
P-P's Avatar
Oddometer: 87
Nice catch! So what is the little bottle that is mounted on your frame for?
Just say NO! to CaliFornication!
P-P is offline   Reply With Quote
Old 07-28-2012, 10:08 PM   #67904
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,769
Looks like a home made chain oiler.
NordieBoy is offline   Reply With Quote
Old 07-29-2012, 12:26 AM   #67905
Eddieb
Eddieb's Avatar
Oddometer: 759
Very interesting
I've just installed the same Procycle choke cable setup on my FCR when I installed the FCR 2 weeks ago. While the bike runs sweet throughout the rev range I can't get it to idle at all. I've tried all sorts of combinations of Idle mixture and speed settings to no avail.
I'd been thinking maybe I set something in the carb up wrong as I installed the needle/jets etc myself but maybe it's my cable.
02 & 05 DR650's
67 Ducati 250 Mark 3 Narrow Case
94 Beta Techno 250
Facebook Adventure Riding NZ Group
Facebook Adventure Riding NZ News
Eddieb is offline   Reply With Quote
Times are GMT -7.   It's 09:03 AM.
