Old 09-12-2012, 07:06 AM   #69016
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,095
Is a used rear shock assembly worth anything? My bike has 4,500 miles and I'm considering selling the complete rear shock assembly with spring. Is there a market for it and if so, any idea what it's worth?
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 09-12-2012, 07:14 AM   #69017
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,963
Originally Posted by Flashback View Post
The DR is an OFF-ROAD machine and A STREET machine all in one. 80 mph on the highway then bombing the rocky single track and rutted trail with ease. What other bike can do that? That is all.
Well, in all fairness the XR650L is pretty comparable, and my 690 does both MUCH BETTER. But, I do like my DR for what it is.
Old 09-12-2012, 07:34 AM   #69018
neo1piv014
ADV in training
Oddometer: 627
I've heard that the XR650L is better offroad just because of the additional ground clearance and the larger diameter rear tire. Still, the DR650 is more than capable of everything I'm capable of. What makes the DR so awesome is that it's so cheap and easy to work on. I'm sure the KTM isn't going to be as easy or cheap to repair when it goes TU.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 09-12-2012, 07:58 AM   #69019
procycle
procycle's Avatar
Oddometer: 2,469
ProCycle will pay $100 for it (or $150 store credit).
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 09-12-2012, 08:06 AM   #69020
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,280
Not to start a heavy heated argument but I see a lot of people on here raving about the 800XC as a replacement for the DR650.
I say...NO WAY IN HELL is it even comparable. And it'll be a cold day that a street bike even comes close to competing with the DR.
Why???
Simply because it weighs more than 100lbs more, is shocked/strutted for street use, and gets horrible (low 40's) gas mileage before adding things like panniers.
I used to have an 800GS which is a hell of a better off-road adventure bike than the 800XC (better shocks, lighter weight, better gas mileage) and the 800GS was STILL about 100lbs too heavy without accessories.
So I challenge anyone who is touting the "XC" as a replacement for the DR to step up and give us some proof. Seriously. I just don't think the XC has any chance of being anything more than another street machine.
Wow, are you sure we're talking about the same bike?
The Tiger 800XC weighs in at about 470 wet. That's about the same weight as a current-gen KLR650 wet (based on actually weighing a friend's 2009 model full of gas and no accessories). yeah that's about 100 lbs heavier than the DR, but you get 3x the cylinders among other things.
Suspension... I call baloney here. The stock suspension is lightyears ahead of the DR650's stock suspension. Rework both, and the Tiger is still ahead. Av_mech here on advrider had his 800XC's suspension redone by Sasquatch and said it's a huge improvement over stock.
The reviews I've read on the F800GS vs the 800XC is that the BMW is very top-heavy by comparison. It also sits taller, which sucks for those of us with short legs. I also rode the 800GS an hour after I rode the 800XC and wouldn't have taken one if they gave it to me. Didn't like anything about it, especially the vibration. The Tiger was smooth as silk.
Now, the DR's huge advantage over either of those is its simplicity -- no electronics to fool with.
And since I don't have $15k to buy and properly outfit an 800XC, I will upgrade my DR650 instead... once I finish the suspension, it'll get a 790 kit, and then it should be pretty darn good.
But let's remember that the 800XC is the OFFROAD version of the Tiger 800 line. The regular 800 is the street model. The 800XC has more suspension travel, and spoked wheels (21" front).
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 09-12-2012, 08:19 AM   #69021
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
Originally Posted by Feelers View Post
i do believe the same carb on the KTM 640 comes from the factory with 2 slide holes, so there are known oem performance advantages NOT just shade-tree tuner work. my bike has a drilled slide and shimmed needle (oem but thinking about ktm one) and my bike runs better setup that way. DR is just setup lean from the factory to keep the epa people happy. it's not optimized for performance.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 09-12-2012 at 08:27 AM
Old 09-12-2012, 08:24 AM   #69022
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
the tiger is the top heavy one not the gs. the engine sits higher as does the gas. most all find the gs better in the dirt than the xc but like the xc motor over the gs. the xc has had a few technical issues but nothing like the problems gs guys deal with. the suspension on the xc is good, but the people have found the gs usd forks to be old-school junk and for looks only. i'd say a properly setup DR will do better than both in the dirt but will fall way short going down paved roads.
the perfect do everything bike has yet to be built though some say the 690 KTM comes closer.
Rob
Alaska
Old 09-12-2012, 08:30 AM   #69023
neo1piv014
ADV in training
Oddometer: 627
Originally Posted by wee-twin View Post
Search: The BST-40 bible by Laramie lc4 on ADV. I just went through my carb on my recently acquired DR and this was helpful. Drilling the slide has nothing to do with making it lighter.
This BST-40 Bible post is the first thing I've read that makes the carburetor make sense to me. Very helpful. Thanks!
Ride videos
'01 DR650
Old 09-12-2012, 09:00 AM   #69024
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
at a $1000 more than the DR what does everyone think of the 650 Terra?
it's only $500 more than the 2013 KLR...who knows what Suzuki is doing for 2013???
this is hard to overlook: 58 horsepower
i'm glad BMW did this bike and priced it this close and what they offered in the bike.
it should get Suzuki, Kawi and Honda off their asses and update their old bikes!
plus maybe to get Yamaha to finally bring the 660 Tenere to the US.
i'm sure plenty of Japanese company execs are looking at those prices and saying uh oh,
there goes our price advantage.
http://www.dealernews.com/dealernews...nd-tr650-terra
http://www.motorcycle-usa.com/827/13...-1st-Look.aspx
Alaska
eakins screwed with this post 09-12-2012 at 09:09 AM
Old 09-12-2012, 09:41 AM   #69025
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,963
Not true, I do all my own work. Pretty much all thumpers are easy to work on, and KTM's are cheaper parts wise then Japanese parts in my experience.
Old 09-12-2012, 09:44 AM   #69026
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,982
Got any examples of prices?
Emmbeedee is online now   Reply With Quote
Old 09-12-2012, 10:42 AM   #69027
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,963
I chose Surdyke Yamaha and Ron Ayers for the pricing as they both pretty much teh cheapest places I've found for OEM parts
Sure complete valve kit (all 4 valves, springs, guides, and oil seals) for a 690 $197
For a DR $218
Camshaft
690 - $145
DR - $226.62
Crank for the 690 is $492
For the DR $541
Just pointing out the myth that KTM parts cost some exorbitant price, when in reality they are in line with Jap parts prices.
Old 09-12-2012, 11:41 AM   #69028
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,982
It would also be interesting to see how long getting these same parts would take - having a price listed is not quite the same as having the parts in stock. I'd figure a bike which was produced exactly the same way for 16 years would be easier to find parts for than one which had a shorter production run.
Old 09-12-2012, 12:00 PM   #69029
Richguzzi
Richguzzi's Avatar
Oddometer: 63
Pricing looks great, HP is good, but at 405lbs for the Terra, I would have to pass as the DR is already heavier than I would like it.
Next...
2012 DR 650
1986 Cagiva Alazzurra Tracker/Fighter/Cafe/Brat/Bobber project
1971 Moto Guzzi Ambassador
Slow old grey haired guys with arthritis and other ailments rule!
Richguzzi is offline   Reply With Quote
Old 09-12-2012, 12:01 PM   #69030
Richguzzi
Richguzzi's Avatar
Oddometer: 63
2012 DR 650
Times are GMT -7.   It's 08:17 PM.
