11-04-2012, 07:52 AM
#70846 | |
Oddometer: 137
It has the same effect from a suspension point of view as lengthening the swingarm, a longer lever working on a given stiffness spring. If you are doing more than an inch expect to need a new spring and revalve on the shock, unless things are already too stiff for you. From my experience on a DRZ I would say that the carrying capacity decreases around 20- 25pounds per inch of lowering. Disclaimer--I don't claim to be a suspension expert, this is just my observation. For more knowlegable info talk to Race Tech or Rick at Cogent Dynamics..
Maynard " Youth is fleeting, immaturity is forever" |
11-04-2012, 09:32 AM
#70847 |
Oddometer: 2,551
Thanks Maynard, good point; my stock spring is just (barely) enough (6.x). I had already been thinking about a 7.x something or other.
11-04-2012, 09:46 AM
#70848 |
Mostly Harmless
Oddometer: 1,703
Choke Problem...
Hey folks... got a new one for you.
I have an FCR_MX carb (from MXRob) on my DR650. For as long as I've had the bike, the choke knob won't stay all the way out. I have to sit there and hold it in place til it warms up enough, or just ride it and deal with the lean surge. I had always thought it was the IMS tank that was responsible for this, and this morning I went out to do something about it. I was going to use a sanding wheel on my Dremel to grind a smidge away from the backside of the tank so that it'd clear. But I discovered that the tank isn't the problem. It's the choke knob itself. It just won't stay out. Is there an adjustment or anything I can do to make the thing stay put? I had considered putting the handlebar-mounted choke lever back on (I got the cable from the PO), but since I have 5" of rise in the bars, I'd probably need to order a longer one, and that's $40 I don't want to spend. Rob
'96 Suzuki DR650, '10 Kawasaki KLX250S, '01 Yamaha FZ1 The Lane Sharing Works Blog | My SPOT Page |
11-04-2012, 09:54 AM
#70849 |
Oddometer: 837
Maybe a new choke unit,mine does this too,no biggie for me though.Doesn't need to be on long,just enough to get it going and than I wait till the Vapor reads a least 100.I just take it easy for the first 10-15 min.
97dr650 bad ass FCR-MX pumper ,plus other goodies
11-04-2012, 10:32 AM
#70850 |
Asperger
Oddometer: 2,047
Steering Damper
I am considering a couple weeks in Baja, probably riding to the southern-most tip and back. I'm considering the need/want for a steering damper. Any thoughts on the necessity of this? I don't "want" one, I'm more concerned with the "need" for one, if that makes sense. I realize people ride without them, but I'm wondering if it'll make enough of a difference that it'd be worth the hundreds of $ toward the the ease/pleasure of the ride.
Also, I am considering the Ralle-Moto RM2 (I think that's the model). Any gooder ones I should consider?
http://breakingbooks.wordpress.com http://www.kenmarshallmetalworks.com/ 2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco. |
11-04-2012, 10:48 AM
#70851 | |
Hooked Up and Hard Over
Oddometer: 7,444
Frank Reinbold "Every bike I ever had, was the best bike I ever had, when I had it" *2010 FOREVER WEST* NEW ENGLAND AND CANADA OFFROAD F800GS 14 DAY IDAHO ADVENTURE KTM 950 TRANS AM TRAIL WEST TRANS AM TRAIL VID CLIP THE DEAN OF WESTERN ADVENTURE ROUTES |
11-04-2012, 04:11 PM
#70852 | |
Old Traveler
Oddometer: 463
I have heard this before but question it changing the ratio. Changing the length of the links only moves the pivot point of the "L" linkage, changing only it's pivot point, no difference in the length of it's arms. I have installed lowering links, only one inch, on several bikes and haven't noticed any change harder or softer. I also would like to have a real suspension person answer this question.
TravelGuy. Quote:
TRAVELGUY DL1000 '05 black DL 650 '07 ( lives in Costa Rica ) DR 650 "08 .
11-04-2012, 05:58 PM
#70853 | |
Oddometer: 1,603
A guy over at DRriders actually plotted out the DR650 linkage ratio. Turned out it is very nearly linear. Certainly not what I would have expected as the main reason linkages are used is to provide a controlled progressive action to the shock. A progressive linkage would become a bit stiffer by installing lowering links. In addition, by lowering the suspension you decrease the available travel. All things being equal, shorter travel will require a stiffer spring to resist bottoming.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
11-04-2012, 06:27 PM
#70854 | |
Asperger
Oddometer: 2,047
11-04-2012, 06:55 PM
#70855 |
Old Traveler
Oddometer: 463
This implies reduced travel movement length. If you have sufficiant clearance from hard parts there would be no difference in length of travel correct?
TravelGuy In addition, by lowering the suspension you decrease the available travel. All things being equal, shorter travel will require a stiffer spring to resist bottoming.[/QUOTE]
11-04-2012, 07:39 PM
#70856 | |
Oddometer: 1,603
11-04-2012, 08:33 PM
#70857 | |
Oddometer: 1,649
For me, every now and then, I hit something, and think it could have been worse if I didn't have a damper, but otherwise they go unnoticed. |
11-04-2012, 08:46 PM
#70858 | |
on the road o'dreams
Oddometer: 5,381
I've been a few times to Baja on my DR650. It has NO steering damper. But I did not ride too many bad sandy sections. I did dirt roads where I could, and a fair bit of pavement. Suffice to say ... the very best of Baja involves LOTS OF SAND. TIP: Try to ride early AM when sand is damp ... or pray for rain. (unlikely) A steering damper takes riding sand from a NIGHTMARE to a DREAM! ![]() Bits and pieces of Baja look like this ... but this road is only 12 miles long ... then it turns to deep sand. The Vstrom had to turn around. ![]() This is more like it ... That DRZ has a damper ... what a pleasure. ![]() Certain mountain sections go on like this for miles. No problemo. ![]() Hundreds of miles of THIS ... deep and tough. |
11-04-2012, 08:59 PM
#70859 |
Oddometer: 273
2 things
Hello,
Bought lowering links from ProCycle and the holes were just about 1/2 inch closer than the ones I have on. Switched them out and noticed no difference. The ones I had on said E32 on them, do not know if they are stock. Any Ideas? Also bought a 520 13 tooth front to run with stock chain. Many people said no problem. The part that screws into sprocket has only has 2 holes for bolts into sprocket where as my other one, ProCycle, has 3. 2 bolts OK? Heirhead Not very good at riding bikes and worse working on them!!!!!!!!! |
11-04-2012, 09:06 PM
#70860 |
UberNoob
Oddometer: 69
I'm confused how a damper helps in the sand? Does it take the vague sensation of parallel ruts and ridges out of the bars enough to give a more planted feeling?
I could definitely see using one if you where going to be bombing down planted rock roads all day long. A damper has been on my to-do list for long time...just not on the DR. Sent from my Nexus 7 using Tapatalk 2
My Smugmug, it's how I roll. |
