11-27-2012, 11:18 PM
#71611 |
horizon calling
Oddometer: 239
Yep, the dyno is old and crotchety, and the 02 and C02 numbers are highly suspect (in-pipe sensor may be at fault). Would that affect the hp or torque ratings? If so, back to the drawing board.
Wandering re-establishes the original harmony which once existed between man and the universe. --Anatole France |
11-28-2012, 05:08 AM
#71612 | |
Awesometown
Oddometer: 400
Thank you! I will do bars and wheel first, and decide on the seat based on whether I get knee pain. I'm more concerned about that than flat-footing (my legs are pretty long).
'76 Xl250 '04 XR250R '09 DR650 '10 TR450 |
11-28-2012, 05:25 AM
#71613 | |
Kool Aid poisoner
Oddometer: 5,061
Looks good!!
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
11-28-2012, 08:29 AM
#71614 |
Oddometer: 181
Shouldn't we be seeing around 40 or so ft-lbs for the torque as well?
11-28-2012, 09:54 AM
#71615 | |
Oddometer: 617
Sit down and hang on!
Attitude ~ The difference between Ordeal and Adventure James |
11-28-2012, 10:10 AM
#71616 | |
Life behind "Bars"
Oddometer: 6,352
Depending on your weight whether you can still use the stock rear spring. I sent my rear shock to Cogent and had the upgrade. (Cogent has a damper adjustment) I bought .47 Racetech springs and the Cartridge Emulators. Did the fork work my self. That all cost about $750. Great improvement. (really great) I was able to still use the stock rear spring. If you are over 190lbs, you will want to get a heavier rear spring. That included will put right about $1K. It is the very next thing you should do after a skid plate, handguards and a DJ kit. Makes it a different bike! Maybe even do it before the DJ kit ![]()
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit Rusty Rocket screwed with this post 11-28-2012 at 10:50 AM |
11-28-2012, 10:26 AM
#71617 |
Asperger
Oddometer: 2,141
Yep, I'll need a new rear spring. Doesn't Cogent just rebuild your shock using Racetech components (maybe I'm way off)? I wonder why people use him if they can buy the Racetech shock shaft assy, or do the Gold Valve for even less? Not knocking Cogent, but I just don't understand what he does that Racetech doesn't offer as an assembly, or as a Gold Valve kit? Why would sending it to Cogent be better than the shock shaft assembly? Maybe Cogent isn't using Racetech components/Gold Valve?
http://breakingbooks.wordpress.com http://www.kenmarshallmetalworks.com/ 2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco. |
11-28-2012, 10:54 AM
#71618 | ||
on the road o'dreams
Oddometer: 5,503
Most custom seat makers can build a "Tall" version, raising you up at least an inch, maybe two? Should help transitioning from seated to standing. What is your thinking on the 18" wheel? It WILL raise the bike up quite a bit, depending on tire you use. Other than that, what is the advantage? Where will you source the wheel? Will the bearings (Hubb and wheel) hold up with an 18" wheel? Also, fewer 50/50 and street based dual sport tires available in 18". Your choice. If doing "all dirt" then the 18" makes more sense. In the end, Ergos are quite subjective. Mess around, try different things, go riding, make adjustments as needed! Quote:
FMF I'm not an FMF fan ... I know them well, have used their products on dirt bikes (and street) since the late 80's. My DR650 came with an FMF pipe ... the rivets started coming out at 4000 miles. I sold it. Also, it was TOO LOUD ... and needed constant repacking. FMF pipes fall apart. IMO? JUNK. The current hot set up for the DR650 is the Titanium GSXR pipe. It's not as light as the FMF but is super high quality ... will last forever, NOT TOO LOUD. Flows pretty well too. |
11-28-2012, 10:56 AM
#71619 | |
Knuckle dragger
Oddometer: 1,364
HP and Torque are mathmatical. HP= Torque x rpm / 5252 Torque= 5252 x HP /rpm A DR making 40 ft lbs of torque at say 6000 rpm would have almost 47 HP...which would be nice...but probably not possible in stock form. edit: 5252 is a constant number in the math...if you look at a dyno chart HP and Torque ALWAYS cross at 5252 rpm...if it doesn't something is wrong. Mongle screwed with this post 11-28-2012 at 11:02 AM |
11-28-2012, 11:14 AM
#71620 | |
Life behind "Bars"
Oddometer: 6,352
see the red knob in the photo: not there with a RaceTech mod. you live with the damping as it comes. Cogent is adjustable.
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
11-28-2012, 11:15 AM
#71621 | |
Oddometer: 2,610
205'd by Rusty
![]() Quote:
![]() Reusing our stock shock body keeps the remote oil resevoir, additional oil capacity adds to cooler running and longer service life. I have 27,xxx miles on my Cogent.
2004 DR650: 47,033 miles of The last 314 miles were done with my super, hot rod, whiz-bang, blue KLIM Dakar gloves. Good thing I lost one of my 10 year old Joe Rocket gloves; I didn't know I could ride so fast. |
11-28-2012, 11:20 AM
#71622 | |
Life behind "Bars"
Oddometer: 6,352
The old saying (If I remember it correctly) Power, light-weight, reliability; choose any two.
11-28-2012, 11:41 AM
#71623 |
Asperger
Oddometer: 2,141
Per Racetech and Procycle's site the Racetech has that same knob, with rebound adjustment.
11-28-2012, 11:49 AM
#71624 | |||
Oddometer: 1,146
HC is also quite low, perhaps unrealistically so. Unfortunately it is the infrared part of the bench that reads CO2, HC and CO. I therefore suspect that the CO readings are inaccurate as well. A leak on the vacuum side of the pump would produce high O2 and low HC & CO2 (perhaps the drain valve in the first water trap is open). What doesn't seem to jive is that a leak on the vacuum side should also produce low CO, but the CO is in fact too high. That either shoots my theory to hell, or indicates that the CO is in fact much, much higher than the reading (!). Quote:
Regards, Derek |
11-28-2012, 12:27 PM
#71625 | |
Oddometer: 2,610
