Old 12-05-2012, 09:08 PM   #71626
Chill
Chill's Avatar
Oddometer: 311
Originally Posted by opium89 View Post
Can someone tell me what function this bearing serves? This is the stator/generator cover......
I think (and this is a bit of a guess) that it is something to do with the starter motor. It lines up with the starter motor so I would presume that it supports the pinion gear that is driven by the starter.
Chill is offline   Reply With Quote
Old 12-05-2012, 09:19 PM   #71627
opium89
opium89's Avatar
Oddometer: 1,136
Originally Posted by Davis53 View Post
I think it is the support bearing for the starter shaft and gear. Yes, you need it.
How is it going to support anything if the starter shaft is bigger on the outside diameter than the inside diameter of the bearing? It's either going to prevent the starter shaft from going in that slot on the cover, or it's going to run right up against the inside race of the bearing. This really isn't making much sense to me at the moment. The inside diameter of that bearing is just a hair under 12mm. The starter shaft is 14mm. Quite simply, it ain't gonna fit! I also just confirmed that the part numbers for a 1999 and 2000 are the same. Lists the bearing as 12x28x8.
Here's something that's a bit odd...the breakdown of the starter in the parts fiche shows that it has a bit of a tip....If the starter actually had that tip, and it was 12mm, the bearing would make perfect sense. In my case, the end of the starter is completely flat and ends at the splines...like so:
UPDATE: I just fitted the new bushing and starter clutch next the the starter shaft. The starter shaft doesn't even exceed the width of the clutch. My verdict is this bearing and clip are COMPLETELY unnecessary. Does anyone disagree?
Tea parties are for little girls with imaginary friends.
opium89 screwed with this post 12-05-2012 at 09:41 PM
opium89 is offline   Reply With Quote
Old 12-05-2012, 09:34 PM   #71628
procycle
procycle's Avatar
Oddometer: 2,251
The bearing only applies to early models. I think 96 and 97. Early models had a starter with a longer shaft that was machined to fit the bearing. Somewhere along the way Suzuki apparently decided it wasn't needed. Current models have a short starter shaft but the cover still has an empty pocket machined for the bearing.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 12-05-2012, 09:45 PM   #71629
opium89
opium89's Avatar
Oddometer: 1,136
Makes more sense. I wish they would at least update the damn parts fiche. These parts all being special order and all. Oh well, what's $15.00 between (Suzuki dealers) friends, right? Thanks for the info.
Old 12-05-2012, 10:11 PM   #71630
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by TrophyHunter View Post
Grifter - Did the adjustable Tusk handguard mounts fit your bars? I have tapered bars and the mounts won't fit around the "still tapering" section. They have mounts for larger bars but they don't have adjustment...plus it adds to the cost. I used some old large bar mounts I had laying around for the time being.
I like the adjustability of the standard Tusk mounts so I'll grind 'em out when I set time aside. I could use longer screws but the contact points 'tween the mount and the bar would be minimal.
I used my Dremel to make them fit. I did not have the Fat Bar Tusk kit so just ground out the standard kit a bit. You know most Bark busters never are a pristine fit on a tapering fat bar anyway. You have to kind of improvise it. Mine have been pretty good. Here is a pic:
Lots of adjustment.
Old 12-06-2012, 03:20 AM   #71631
TrophyHunter
Oddometer: 2,167
Thx for the verification, Grifter. I'll keep grinding..... :)
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 12-06-2012, 04:10 AM   #71632
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,530
So, just for the record, if my 96 needs a starter, can I use the newer short shaft version?
Old 12-06-2012, 05:28 AM   #71633
macrae85
Oddometer: 391
Originally Posted by dogjaw View Post
Tis a Galfer from Kientech; stops the DR like a champ...
Ta much!
macrae85 is offline   Reply With Quote
Old 12-06-2012, 09:31 AM   #71634
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,845
Replacing bars - grips?
I am replacing my bars. Will I need to replace grips, or will the left one come off?
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 12-06-2012, 09:46 AM   #71635
mrprez
KJ4WMZ
Oddometer: 1,265
I had to cut mine off.
Sent via morse code
mrprez is offline   Reply With Quote
Old 12-06-2012, 09:51 AM   #71636
procycle
procycle's Avatar
Oddometer: 2,251
Dunno. I don't see why not but the long shaft with bearing support looks like a much more robust design. If I had to replace a starter I would seriously consider getting the old style and adding the support bearing.
Old 12-06-2012, 10:42 AM   #71637
sunthechip
Oddometer: 123
I installed a new horn yesterday ( I haven't had a working one for at least 6 months), then I turned the power on and pressed the horn switch, but there was no sound, so I checked the electrical connectivity.
When I bypassed the switch with a screwdriver the multimeter would read 13V where the horn plugs in, so the switch was the problem.....
I dissembled the entire left hand control and cleaned the inside of the horn switch with a pipe cleaner, turned the power on, pressed the horn switch, and the multimeter read 13V.
I thought it was all fixed, so I reassembled the control unit to the handle bar, turned the power on and pressed the switch to see if it was working properly ........NOPE.
So then I disassembled the entire control unit AGAIN to figure out why the switch wasn’t making contact.
It turns out the horn switch was not flush with the plastic exterior of the control unit, so I wedged a piece of a zip-tie in the crevice and brought the crooked end of the horn switch forward and flush.
I reassembled the unit (halfway this time) and tested the switch... BINGO, 13V on the multimeter.
2 hours later everything works and the horn fires up nicely...
sunthechip is offline   Reply With Quote
Old 12-06-2012, 10:45 AM   #71638
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,530
Good point - newer is not necessarily better.
Old 12-06-2012, 02:09 PM   #71639
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 8,990
It's a superceded part #
http://www.ronayers.com/Fiche/TypeID...STARTING_MOTOR
and the shorty is the only one avail. Sell you a collector's item outta my '96.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 12-06-2012, 02:43 PM   #71640
procycle
procycle's Avatar
Oddometer: 2,251
The long shaft starter is still used in their ATVs. It's available from several aftermarket suppliers.
Times are GMT -7.   It's 09:53 PM.
